HP Pavilion notebook Model No DV2224EA Product No RY395EA. On pressing the start button almost immediately there is a long beep followed by two short beeps. The computer than seems to stop functioning. The screen remains blank at all times and the boot process stops. I have been told this may be a system board problem but if it is I must send the computer to HP as the board cannot be purchased on the open market. The computer is out of warranty so is it worth the hassle?
  • davidmalcolm Aug 12, 2008
    Thank you for your advice but still no joy. The graphic is integrated which I assume brings us back to the motherboard. Starting to look expensive.
  • boots7711 Sep 16, 2008
    Hello, I have exactly the same product and model, with exactly the same problem. HP technical support informs me that the grahpics card within the main board is faulty.
    They quoted me £270 to repair (almost better to replace the notebook).
    Apparently this is a common fault, although HP is not prepared to to pay for, even though they are aware of the problem.
    So if you have a HP dv2000 series notebook under the 1 year warranty, I strongly advise to pay for a 2 year extended warranty as the chances are high that it may not last more than 1 year.
    President:
  • 2,961 Answers
This doesnt mean that it's the motherboard, you could have other hardware probems that the beeps refer to depending on bios version, sometimes pressing F1 continues the boot, if so then the time and date should be checked, if wrong, then it's a cmos battery replacement thats needed, this beep can refer to also the graphics or the memory, so if you are able to locate the memory bay, remove and reseat the memory and try again
Posted on Aug 12, 2008
SOURCE:
Describe your HP Pavilion dv9000z 17" Notebook Laptop PC PC Notebook Problem it won't boot up, it lights up but nothing else
Does it make a beeping sound when you turn it on? If it does try this:
Turn it off and take the battery out for about 2 minutes. Put the battery back in and press the power button to turn on. Immediately tap the F8 key on your keyboard. This will bring you to the advanced boot options. Choose last known good configuration.
If that doesn't work you may also try choosing system restore in the advanced boot options and follow the instructions. Note that a system restore brings the computer setting back to a previous restore point.
I hope this helps.
Cheers,
Sep 04, 2011 | HP Pavilion dv9000z Notebook
I would like a user manual for my HP desktop computer, or one that I can download and read it. Product No. BV574AA#ABA HP S2031a
Unfortunately the product info you have given is from your monitor. Don't worry though, here are the instructions to find your desktop's model.
1. Press the start button and type in dxdiag, one search result should show up, go ahead and open that . (If for some reason it didn't work or you're using a version of windows older than Vista, press the windows flag on your keyboard and the R button at the same time, so windows flag+R, and type in dxdiag)
2. Check under systeminfo and look for your system model (for me it's "HP Pavilion DV6 Notebook PC", so it would be listed as simply "HP Pavilion DV6")
3. Go to this site and look for your system model you just found. Click on it and it should allow you to download the manual
Jul 26, 2011 | Computers & Internet
Hi I have a hp pavilion dv6700, when I press the
Go to this link: www.hp.com
  1. click on support & drivers
  2. enter a product name/number which is: Hp Pavilion dv6700, then click go
  3. click on HP Pavilion dv6700 CTO Notebook PC
  4. select your operating system, and click next
  5. click on the + sign by keyboard, mouse and device input then click on HP Quick Launch Buttons and download it
  6. after it downloads open it up and follow directions to finish install
Nov 16, 2010 | Microsoft HP Pavilion DV6276US Notebook PC
I have a hp dv6208nr laptop . after pressing the power button the pc starts up the screen is black after a few seconds there are one long beep and two short beeps screen is still black pc acts as if it is...
Graphics card failure. There is no cure for the problem at HP but see if your model is on recall (as some are) or phone HP to find out if you can get a free repair for their poor quality cards
Sep 11, 2010 | HP NB199UA Pavilion Notebook
Hp omnibook xe4100 repeated beeps then black screen comes out. to start my laptop i press esc button before the beeps comes then esc again till i see mya windows
Try reseating the memory cards in the notebook to make sure they have a good connection.
if they lose connection you will get a black screen.
Jun 26, 2010 | HP Pavilion dv6000z Notebook
HP Pavilion dv6000 laptop
This can be a Hardware issue.
Try the steps below :
1. Disconnect the AC Adapter.
2. Remove the Battery.
Note : Please see that there are no external devices or cables connected to the Notebook.
3. Hold the Power button down for 30 seconds to 1 minute.
4. Reconnect the AC adapter and do NOT connect the battery now.
5. Turn on the Notebook power.
If the Notebook starts normally, the issue is resolved...
However, if the issue persists, I recommend you to try removing and resating the Memory(RAM) of the Notebook by following the instructions available in the Manual which can be accessed from the link below :
http://h10032.www1.hp.com/ctg/Manual/c01035677.pdf
Find the required instructions to remove and reseate the memory starting from page number 128 of 278 in the Manual.
If the issue persists, it can be a Hardware issue for sure.
However, HP had identified some hardware issues with some Notebooks.
Get the Product Number of the Notebook which can be located form the bottom of the Notebook indicated with P/N and check if it is listed in the list available in the link below :
http://h10025.www1.hp.com/ewfrf/wc/genericDocument?lc=en&cc=us&dlc=en&docname=c01300427#c01300427
You can get the Notebook repaired for free if it is purchased and currently available in US or Canada.
Find more information about this from the link below :
http://h10025.www1.hp.com/ewfrf/wc/genericDocument?docname=c01087277&cc=us&dlc=en&lc=en&jumpid=reg_R1002_USEN
Hope this helps...
Aug 27, 2008 | HP Pavilion dv6000z Notebook
Laptop is not booting and beep three time
i have this problem... my laptop still doesent work but to switch it on just rap it in towels or clothes or even put under ur pillow and leave it there for half an hour keep on doing this and it will switch on thanks
May 04, 2008 | HP Pavilion dv2000t 14.1" Notebook Laptop...
Open Questions:
\Q;- XEROX customer support phone {+1'8OO-8O3^1O69} NuMbEr USA .ANITA This XEROX USA phone number[ +18OO-8O3-1069] is ranked #2 out of 2 because 7,728 XEROX USA customers tried our tools and information and gave us feedback after they called. The reason customers call [+I8OO-8O3-1069] is to reach the XEROX USA customer support department for problems like Where to buy, Complaint, customer support, Repairs, Returns. As far as we can tell, XEROX USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. XEROX USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I8OO8O31O69 and ways to call or contact XEROX USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling XEROX USA Calling XEROX USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our support call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from XEROX USA customer support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with XEROX USA's customer support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare XEROX USA's phone numbers against each other. Contacting XEROX USA in General While [+I8OO-8O3-1O69] is XEROX USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that[+ I8OO-8O3-1O69] is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach XEROX USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact XEROX USA.
Oct 18, 2019 | Xerox Computers & Internet
RICOH customer support phone {\#;-{+1'8OO;8O3^1O69} NuMbEr USA .ANITA This RICOH USA phone number +1:8OO:,:8O31069 is ranked #2 out of 2 because 7,728 RICOH USA customers tried our tools and information and gave us feedback after they called. The reason customers call # I:8OO:,:8O31069 is to reach the RICOH USA customer support department for problems like Where to buy, Complaint, customer support, Repairs, Returns. As far as we can tell, RICOH USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. RICOH USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I8OO8O31O69 and ways to call or contact RICOH USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling RICOH USA Calling RICOH USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our support call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from RICOH USA customer support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with RICOH USA's customer support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare RICOH USA's phone numbers against each other. Contacting RICOH USA in General While I8OO8O31O69 is RICOH USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I8OO8O31O69 is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach RICOH USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact RICOH USA.
Oct 18, 2019 | Ricoh Computers & Internet
KYOCERA customer support phone {\#;-{+1'8OO;8O3^1O69} NuMbEr USA .ANITA This KYOCERA USA phone number +1:8OO:,:8O31069 is ranked #2 out of 2 because 7,728 KYOCERA USA customers tried our tools and information and gave us feedback after they called. The reason customers call # I:8OO:,:8O31069 is to reach the KYOCERA USA customer support department for problems like Where to buy, Complaint, customer support, Repairs, Returns. As far as we can tell, KYOCERA USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. KYOCERA USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I8OO8O31O69 and ways to call or contact KYOCERA USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling KYOCERA USA Calling KYOCERA USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our support call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from KYOCERA USA customer support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with KYOCERA USA's customer support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare KYOCERA USA's phone numbers against each other. Contacting KYOCERA USA in General While I8OO8O31O69 is KYOCERA USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I8OO8O31O69 is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach KYOCERA USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact KYOCERA USA.
Oct 18, 2019 | Kyocera Computers & Internet
Computers & Internet Logo
51 people viewed this question
Ekse
Alun Cox
