KitchenAid KERA205P Electric Kitchen Range Logo
Anonymous Posted on May 08, 2011
Trying to set Sabbath cooking mode, no instructions in manual
Sal De
Level 3:
  • KitchenAid Master 2,699 Answers
  • Posted on May 08, 2011
Sal  De
KitchenAid Master
Level 3:
Answers
2699
Questions
0
Helped
1003093
Points
8029
Copy and paste this site......http://www.retrevo.com/search/v2/jsp/pdfViewer.jsp?doc=404215aeb4c28c12002f177f0d2004f4&page=20§id=41&q=KitchenAid+KERA205PSS+sabbath+mode
Testimonial: "worked like a charm! I thought it did not have a delay setting, and that I needed to use the Sabbath Mode for that - Glad to find out it does have it"
  • Sal De May 08, 2011
    copy and paste this it will take you to a site where you can down load the manual..........http://www.retrevo.com/search?q=KitchenA...
1 Related Answer
Anonymous
  • 8197 Answers
  • Posted on Mar 14, 2009
SOURCE: Sabbath display makes oven inoperable
http://www.ajmadison.com/ajmadison/itemdocs/8113P383-60.pdf
Good Luck and Please Rate FixYa!
I have a GE ENERGY STAR 24.7 Cu. Ft. French-Door Refrigerator Model #: GNE25JGKBB. Sabbath mode does not turn on.
There could be a few reasons why your GE ENERGY STAR 24.7 Cu. Ft. French-Door Refrigerator, Model #: GNE25JGKBB, won't go into Sabbath mode.
You can try a few of the following:
Control lock inspection
Check to see if the control lock is off.
You won't be able to switch on the Sabbath mode if the control lock is activated.
Verify the water filter's condition:
Verify that the water filter is clear and out of date.
The operation of the Sabbath mode may be hampered if the water filter is blocked or past its expiration date.
Verify the control settings:
Make sure the appropriate control type is installed in your refrigerator.
You should adhere to these directions for models with Figure B controls.
Look in the manual:
Verify that you are correctly adhering to the directions.
Refer to the manual once again for additional thorough instructions if you need clarification on any steps or have any other concerns.
Contact GE for more help if you've tried all the above suggestions but still have trouble turning on the Sabbath mode.
They may need to send a professional to fix or replace the refrigerator, or they may be able to offer you further troubleshooting tips or steps.
It's important to note that some models do not have sabbath modes without icemakers; if this is the case for your model, the sabbath mode option is unavailable.
What does SAb. Bath mean on an stove clock mean
During the Sabbath, or Shabbat, and religious holidays in Judaism, there may be restrictions on certain activities that can extend to the use of appliances. Restrictions may include turning appliances on or off, using control panels or activating lights and sounds. Sabbath Mode allows people to use their household appliances without violating their religious laws. When appliances are put into Sabbath Mode, certain features may be modified or disabled to accommodate these needs.
Our guide explains how Sabbath Mode affects cooktops, ovens and refrigerators. Keep reading or jump to an appliance category to learn more:
  • What is Sabbath Mode on a stove or cooktop?
  • What is Sabbath Mode on an oven?
  • What is Sabbath Mode on a refrigerator or freezer?
  • What is Sabbath Mode on a wine refrigerator?
You can cook on your stove when it's in Sabbath Mode, but additional features and functionality are disabled. When your stove is in Sabbath Mode:
  • Cooktop burners can still be operated.
  • Sounds such as tones or chimes are disabled.
  • Displays will not indicate temperature changes.
  • Timers are disabled.
  • Cooktop Lockout, a feature that prevents unintended use of the cooktop, is disabled.
  • Energy Save is disabled in select models.
  • Start, Cancel and Off keys, as well as Warming Zone on/off (select models), remain enabled. All other keys are disabled.
When in Sabbath Mode, your oven will disable its automatic shut-off function to stay on longer than 12 hours. This means that the oven will stay in a Bake mode until shut off, which will allow you to use the oven for cooking or warming food. It is important to remember that certain features will need to be enabled or disabled before using Sabbath Mode. This includes the following:
  • Oven Light: Turn your oven light on or off before engaging Sabbath Mode. Your oven light will remain as it was set until Sabbath Mode is turned off - it will not be affected by the Oven Light switch or by opening or closing your oven door.
  • Warming Drawer: If you plan to use your warming drawer, it must be turned on prior to enabling Sabbath Mode. Adjust your warming drawer settings prior to turning on Sabbath Mode, as these settings cannot be changed once the Mode is engaged.
While your oven is in Sabbath Mode, only the Bake setting can be enabled - all other oven settings, including temperature displays, sounds and cleaning cycles, are disabled.
Sabbath Mode allows you to open and close the refrigerator or freezer doors without activating interior lights, sounds or other controls. While your fridge is in Sabbath Mode, water filter status lights are disabled and temperatures cannot be adjusted.
When Sabbath Mode is activated on your wine fridge or wine cooler, the exterior lights and display will be deactivated. This will make your appliance appear as if it is turned off, but your wine cooler will keep running as normal, and its temperature settings will remain unchanged. Learn how to activate Sabbath Mode on your wine refrigerator.
To learn more about Sabbath Mode or for further instructions, refer to your appliance's Use and Care Guide. To download or view your product manual, visit our Manuals and Literature page.
How to turn on sabbath control on my whirlpool stove
To Activate Sabbath Mode:
To use the Warm Zone and/or Warm Drawer during Sabbath Mode,
press the WARM ZONE and /or WARM DRAWER keypad before
activating the Sabbath Mode.
1. Press BAKE.
2. Press the "+" or "-" key to set a temperature other than
350F (177C).
3. Press START.
For timed cooking in Sabbath Mode, press COOK TIME, then
the "+" or "-" keys to set the desired cook time.
4. Press TIMER SET/OFF for 5 seconds. "SAb" will appear in the
display.
To Adjust Temperature (when Sabbath Mode is running):
1. Press the "+" or "-" keypad. Each press of a keypad will
increase or decrease the temperature by 25F (14C). No
temperature will appear in the display.
2. Press START.
To Deactivate Sabbath Mode:
Press and hold TIMER SET/OFF for 5 seconds to return to regular
baking or press CANCEL/OFF to turn off the range
2answers
What does 5ab mean on the oven?
Some ranges with a lot of features have a Sabbath mode, hence the letters Sab in the display although it looks like 5ab. Check your owners manual and it should tell you how to turn off the Sabbath mode. If you don't have a manual Google your model number and Sabbath mode.
Aug 28, 2011 • Ovens
I cancelled the clean proprocess and then the display shows 5ab and I can't get the oven to work or clock .. anything, no beeping
somehow you put it in sabbath mode,yes sabbath mode,a feature known as "Sabbath mode." According to the Jewish Sabbath law, raw food may not be cooked on the Sabbath, but food that was already cooked beforehand may be kept warm until mealtime. On Jewish holidays, food may be cooked fresh, but turning the flame on poses a problem given electrical requirements forbidden by Sabbath observers.try holding the clck button in for 3 to 5 seconds to take it out of sabbath mode
1helpful
My Kenmore oven won't work there is a PF 5AB error
The PF on your control indicates a power failure and should be removed by pressing the cancel button. The 5ab code indicates the range is in the SABBATH mode.
If a power failure occurs when the SABBATH mode is set, the oven will return to the OFF mode and will turn the power OFF to the oven.
To ENABLE SABBATH mode:
* Open the oven door
* Press STOP/CLEAR
* Press both the HOUR "UP" and "DOWN" arrow pad at the same time - and hold for 5 seconds.
SAB ON will disappear from the display.
To disable SABBATH mode: Repeat the steps above and SAB OFF will appear.
To set the SABBATH mode for use during the SABBATH/Holidays:
* Press BAKE
* Pres TEMP "UP" and "DOWN" Arrow pad to enter a different temperature other than 350 degrees. (Between 170F and 500F)
* Press COOK TIME
* Press HOUR/MIN "up" or "down" arrow to set cook time
* Press DELAY START to set a delayed cook time (optional)
* Press and hold TIMER OFF for 5 seconds
SAB will appear on the display indicating it is ready.
* Press START
* To STOP cooking - press STOP/CLEAR
* To exit the SABBATH mode and return to normal operation - press and hold TIMER OFF for 5 seconds.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
2helpful
How set sabbath mode??
to turn on or off the sabbath mode on your oven press and hold the sabbath mode button for 5 seconds that turn it on and then repeat to turn it off
1helpful
Code 5A6 appears when i tried to change the clock. stovetop works but the oven does not
You inadvertently set your range to "Sabbath Mode". The display actually reads "SAB". This is a feature that allows the consumer to disable certain features of the range in order to honor the sabbath. You cannot defeat it by unplugging the range or turning off the breaker either. You will either have to wait 72 hours for the mode to clear, or figure out how to turn it off.
All ranges differ in design and features. The instructions to turn Sabbath mode on or off differ as well. The instructions will be in your owner's manual.
If you do not have an owner's manual, or do not understand the instructions, please post back with your model number so that I may be able to povide you with better assistance. I hope this helps you.
7helpful
2answers
Hold the clock button "in" for 5 seconds to disable Sabbath mode.
Top KitchenAid Kitchen Ranges Experts
vince
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
