Question about Dacor ECD230 Epicure Electric Double Oven
Dacor Oven Having trouble finding the High Limit switch on a Dacor double oven
Depending on your model it is usually at the top behind the "grill" of the oven that is not working. Take out the screws aournd the oven latch (usually for cleaning) and slide out the grill. The limit switch is either over the latch or to the side. If it popped, just put it back with a screw driver. If that is not the issue, then it it could be a bigger issue.
Posted on Nov 20, 2008
I want to re-set high temperature limit control,
if you open the oven door all the way, then, look under the control panel (where the top of the oven door seats) you will see a plate that has 6 to 8 screws holding it in place.Remove the screws of that plate with a phillips screwdriver.You will possibly need a flashlight to look inside the space where the reset switch is located... but it is THERE. Make SURE that you TURN OFF the circuit breaker or... UNPLUG the range... B4 you proceed to reset. Look for the Red Button on the back side of one of the limit control switches. Press it in till it clicks. (sometimes you'll hear it... sometimes you wont). Plug baack in ro reset your breaker switch, Turn on your oven and see if it works. If it does... then replace the vent plate close your oven door and now your cook"n with gas...well... electricity really.
May 13, 2010 | Dacor ECS130 Epicure Electric Single Oven
High limit switch trips and needs re-set
After grilling or cooking at higher temps leave the oven light on so the cooling fan continues to run for approx 1/4 hour, or whatever setting will keep the fan running...
Apr 22, 2010 | Dacor ECS130 Epicure Electric Single Oven
Dacor double oven, lower oven works fine, upper oven doesn't turn on at all
I had the same problem after auto-cleaning my oven just before Thanksgiving. The cause was overheating...and the tripping of a heat sensor switch.
The switch (reset button) is located about 3 inches behind the door locking mechanism.
Removing the front panel (4 screws) that the door lock sticks through exposes the switch. Just push the little red button & your are back in business!!
Nov 14, 2009 | Dacor ECD230 Epicure Electric Double Oven
DACOR IS A PEICE ****
The hi limit thermostat probably tripped during self clean. It can be manually reset. Turn off the power and remove the grill under the control panel. There is a two wire switch behind the door latch press in the red button on the switch. Reassemble and turn on the power. If it works you can reset the cooling fan to run longer which could cure your problem. Press and release upper broil button, press and release the up arrow, then hold down the broil button until it reads COOL 000. Press the up arrow until it reads COOL 200. Press cancel. Done.
Jul 01, 2009 | Dacor ECD230 Epicure Electric Double Oven
Dacor Double Oven
HI - I just had the same problem - repairman came and reset the breaker in the oven which "tripped" (even tho I havent used the lower oven in months).  Read posts here on other Dacor ovens which explain how to get to the reset switch to avoid having $150 in repair costs - I have not tried that myself tho but good luck!
Nov 08, 2008 | Dacor ECD230 Epicure Electric Double Oven
Dacor ECPS130 fan won't shut off
Hi, Dacor has a Technical Manual that may help you with your problem. It has a ECS wall mount oven but does not list a ECPS. Is your listing of the model correct? Here is a link to download the Technical Manual. https://www.scribd.com/doc/14008662/Dacor-Technical-Manual
Hope it helps.
Mar 20, 2017 | Dacor PCS130 Preference Electric Single...
My Dacor wont heat, broil or convection after self cleaning. No heat but everything else works The bake, broil, and convection elements on my Dacor CPS130 electric wall oven will not heat.  The oven has...
like another person stated-from the front behind the door, take off the 6 screws and the cover by the latch. there is an "oven hi temp limit switch" It is crome with 2 heavy black wires connected to it. On the back side of this is a small red button which will reset the limit switch. I had the same issue (everything worked except the any of the heating elements) and quickly resolved.
Jan 07, 2008 | Ovens
My Dacor ECD230 stopped heating???
The high limit switch has tripped on this unit. Remove the vent panel behind the door and there will be a button in there behind the wires. Press this button with the circuit breaker turned off and that will rectify the problem. You still might need a servicer out to take a look at the unit though
Nov 21, 2007 | Dacor ECD230 Epicure Electric Double Oven
I also have a Dacor Model PCS130. This solution worked AND saved me from spending $50-$105 for a service technician to come out just to look at the problem. The high temperature sensor tripped when I kept the door open part way while broiling (never listen to friends who don't have the same oven as yours). Afterwards, I couldn't get the oven to go above the prebake temperature of 135°F using any of the settings (bake, broil, convection bake, etc...). I called Dacor customer service and they told me about the high temperature sensor but wouldn't say how to reset it. They suggested I call a third party technical service company and gave me their numbers. But, I'm glad I found this site... All you have to do is open the oven door and you'll see the grille/grate/steel cover plate where the door latch sticks out of. If you look inside, you can see the electronics that operate the door latch as well as the temperature sensor unit a little farther back. You can even see the RED reset button. But, it's a little too far back for you to press it without removing the cover plate. 6 screws is what holds my cover plate in place. Once that's off, you can reach in and press the RED reset button (I pressed it twice just to make sure) and you'll hear it click. Screw the cover plate back in place. Close the oven door and test it out. It took my oven about 5 minutes to heat up past 135°F so I was unsure if the problem was fixed or not during that time. But, once the oven heated up sufficiently, the temperature began climbing fairly quickly and I was able to breath a sigh of relief. It works! This is such an easy fix, I don't know why Dacor customer support doesn't just tell us how to do it ourselves instead of paying for a service tech to come out and do the same thing. Even better, maybe they should make the reset button more easily accessible (like on the control panel) if they're concerned about people getting in and messing up the other electrical connections when trying to reset the high temperature switch. Computers are far more technically advanced than your oven and THEY have reset/reboot buttons right in front.
Nov 11, 2006 | Dacor ECS127 Epicure Stainless Steel...
Dacor ECD230 Epicure Electric Double Oven Logo
224 people viewed this question
Top Dacor Ovens Experts
Dan Webster
Dan Webster
Vitaliy Gins
Vitaliy Gins
ashburton
Are you a Dacor Oven Expert? Answer questions, earn points and help others
