Question about HP Expresscard TV Tuner For Windows Vista (RM436AA#ABA)
Channels How many channels should I be able to view using the HP tv tuner?
  • 7 more comments
  • sstgwt1 Aug 12, 2008
    This is an anaolog/digital tuner. I can only view 5 different tv stations.
    USA, It has the standalone atenna
    Sorry, Florida
    digial....I am getting maybe 4 of the listed 15. Shouldn't I be able to get all that Verizon is putting in the house?
    I am sooo confused. The laptop is in a room that does not have a cable tuner box. I thought the tuner with antenna was stand alone that's why I bought the expresscard. :(
  • sstgwt1 Aug 13, 2008
    Thanks. I think I have it. I bought this thinking I would get all the channels my other tv's get.....but it will only pick up air channels, which appears to be only 5.
  • Anonymous Aug 13, 2008
    i'm able to view only 5 channles....i want to view all 15 channels
  • Tim Babcock
    Tim Babcock May 11, 2010
    Do you have this plugged into rabit ears or cable?
    What part of the country do you live in?
  • Tim Babcock
    Is this the Digital/Analog model or just the analog model?
If this is the same one I have, you should be getting all of your cable channels.
Posted on Aug 15, 2008
  • HP Master
  • 2,794 Answers
Take a look at this guide
See if the channels match in your market area.
Posted on Aug 12, 2008
  • Tim Babcock
    Tim Babcock Aug 12, 2008
    If you have a cable plugged into it from the coax of your Verizon, you should be. Make sure that the splitter you are using is approved for digital cable use. Radio Shack carries some that will.
    You shoul have one line split into your cable tuner box and the other should be plugged into the Expresscard.
  • Tim Babcock
    It is a standalone unit as long as you have an antenna plugged into it. You will only get over the air channels that way.
    If your using Verizon as your cable provider and you want to connect your computer to the cable tv system, you will have to get a splitter into the cable connection in your wall, take a line from the splitter and plug it into the tuner card using the coax adaptor. Make sure the Express card is set in analog mode when you plug it in. You can probably get the first 150 channels that way.
    There is a setting on the card to switch between analog and digital channels. Depending on what mode the card is in, you can get more or less channels that way.
Can i use laptop to watch tv
Hi, Yes you can buy a small device that is a TV Tuner Card which avarage around $50 more or less and some cards even have a recording ability that would be a little expensive, once you install the card and software, hook up your antenna (if none on the card) and follow the instructions to watch TV... Though if you have high speed internet you can also watch TV on the net, there are thousands of channels and you will find many links to softwares you buy to watch these channels, but the best is a free web site http://wwitv.com/portal.htm
Best of Luck
Feb 04, 2011 | Computers & Internet
I just need to know how to link up my Allegro DVD/VCR REMOTE CONTROL to my Phllips Magnavox Television.
TUNING This DVD+VCR is equipped with a frequency synthe- sized tuner capable of receiving up to 181 channels. These include VHF channels 2-13, UHF channels 14-69 and CATV channels 1-125. Auto Channel Programming 1. Choose the SOURCE SELECT option, then use b / B to select TUNER. Use b / B to switch among TUNER, LINE1, and LINE2. 2. Choose the AUTO CHANNEL SET option, then use b / B to find channels. • The tuner will automatically cycle through all available channels (TV/CATV) in the area and place them in the tuner's memory. •After the AUTO CHANNEL SET is complete, the TUNING menu will hide and return to the TV screen automatically. 3. Make sure the TUNING BAND is set appropriately (TV or CATV). • TV : If you are using a standard antenna to receive channels. •CATV : If you are using basic cable to receive channels.
Oct 15, 2010 | Allegro DVD/VCR ABV511
Get dish network to work with hp SR5505F COMPAQ PRESARIO COMPUTER
You can not change channels on Satellite with your TV tuner card. The satellite box decodes the sat signal (it is sent encrypted) you can run S-Video/RCA/HDMI depending on the video card input, but you will be required to change the channel on the Dish box. The TV card can only change channels on broadcast (over the air) channels, you can attach an antenna and it will use the NTSC tuner to change analog channels (if they are still available) and the ATSC tuner to change digital/HD broadcast channels. This card (from your description can ONLY deal with broadcast TV, You will need a TV card with a QAM tuner for unscrambled digital cable. There is no solution for directly interfacing with Satellite on a PC or Mac (DirectTV or Dish) the signal from the satellite is encrypted and requires (at least for DirectTV, a fairly complicated decryption setup to function, this is handled by the tuner box/card combination. Sorry your setup will not support changing the channel on the PC, you may be able to find some kind of software that can utilize an IR transmitter to change the channels on your satellite box, similar to the way a Tivo or other DVR can talk to cable boxes, but that is the best you will be able to do as far as channel changing.
Jan 09, 2010 | HP Computers & Internet
CAN NOT GET CABLE CHANNELS , WITH DIRECT CABLE WITH USING THE CABLKE BOX MODEL 20DL74
Yep! I agree - your tuner on the TV is not made for Digital reception.
You will still need to use the Verison Cable box to view any channels.
The newer TV's have the digital Tuners built in. Note: Plasma's are faster locking on to channels than LCD's.
Blessings,
A/V Media Guy.
Nov 19, 2009 | Toshiba 20DL74 20 in. EDTV-Ready LCD...
On my cyberhome 1600 dvr want to view tuner of dvr on tv screen
Take your TV for a check by a good technician. Some IC have short circuited in the accident that occured.
Rate this...
Mar 22, 2009 | Cyberhome DVR 1600 DVD Recorder
No sound on only two channels (6 & 55)
I'm stoopid. I pressed the Audio button on the remote control and discovered that the selection was set to SAP however no secondary audio was present resulting in no audio. It's no my TV so I am unfamiliar with the remote functions.
Thanks
Aug 23, 2008 | Toshiba MD20FN3 20 in. TV/DVD Combo
Dual toner card
You will have to install each tv turner software not different folder in the program files folder.
During the installation of the drivers and software you will be prompted with the directory where the software will be installed, on this page you should select say for eg:
for the first tv turner card C:\program files\ hp tv turner
for the second tv turner card say c:\program files \hp tv turner 2
this should be done for every directory mentioned during the installation.
other wise both the card will try to use the same driver and software files, there will be a clash, thus one one tv turner card will be viewed.
Jan 09, 2008 | Microsoft Windows Vista Ultimate Edition
Viewing
When you watch TV with a Cable Box or a Dish Network Box you are using a tuner inside that box. The signal that comes out of that box only contains one channel, the one you're tuned to. So you can take the output of the Dish Box and send it into your ATI tuner card, but you cannot change the channel to anything other than what the DIsh Box is set to. I'm sorry, but that's just the way it is. I use a Hauppague tuner card that has what's called an "IR Blaster". By hooking this device up to my Cable Box and I can used my computer to change the channel on the Cable Box itself.
If you had cable, you could run the cable into the TV tuner and watch the analog channels. I have Time Warner in my area and they still broadcast about 50 channels in analog. I cannot use the tuner card to watch any of the digital channels. This probably does not help you, but I thought you might like to know.
I want you to know that I don't get paid to offer these suggestions. I know it's a strange hobby, but I like to help when I can. Even though I cannot solve your problem I hope I provided helpful information and you will give this solution a positive rating. I've noticed that many times this type of question goes unanswered because nobody wants to get a bad rating when a problem has no solution. Thanks and good luck.
Jan 02, 2008 | ATI TV Wonder 650 (DNH100715331) Video...
How to set up TV tuner on HP laptop to receive freeview channels.
better contact HP service center as it is still under wtty. I can guide you but no use wreking your brains over what can be done in minutes by HP technician.
Sep 22, 2007 | HP Pavilion dv9000z Notebook
HP Expresscard TV Tuner For Windows Vista (RM436AA#ABA) Logo
79 people viewed this question
Top HP Televison & Video Experts
Tony
Computer Links
vbalag
Level 1 Expert
Are you a HP Televison and Video Expert? Answer questions, earn points and help others
