Question about Canon 730i Laser Printer
Auto delete memory
In summary, I want to either auto clear the memory after a successful transfer via email or increase the memory by hard drive or memory card. Currently at 40mb. Can the memory on the Canon LC 730i be cleared after a successful transfer? I had the machine set at one point not to save in memory. This is a problem if the network goes down, because the email transfer only retries 3 times and then the fax is gone. Only record is the transmission confirmation which is a partial first page. Later, I turned on memory retention and now when the memory becomes full, the transfer of email starts to fail. If I delete some of the older faxes in memory, the newest faxes that have not transferred begin to transfer. Can I increase memory beyond the 40MB or even add a hard drive to manage these faxes via the internet interface?
I have all the manuals and software, but no answer is clear on the above.
2 Suggested Answers
SOURCE: canon laser class 730i memory full
Reset the memory
Under the one touch key pad
hit the: Reg Data
hit # key
scroll on key pad until you come to all mem clear #12 and hit enter
Posted on Apr 14, 2008
Lost Facebook when trying to speed up tablet very slow
How can you 'increase your speed via Google'. Google is just a search engine and a portal to gmail, YouTube etc.
To increase your speed on the tablet you need to delete apps you don't use, music you don't listen too and transfer images to a computer. Also clear your temporary internet files and history. Reboot the tablet often to free RAM memory.
To get Facebook back, just go to the App Store and redownload it.
Oct 02, 2015 | DURAGADGET Portable USB Tablet Mini...
There is no local channel,cable only international..i lost my manual,
Hello
Here is the procedure for auto tuning. Pleas go through it. Connect the antenna to the rear antena socket marked as &% ohms antena and continue.
If you have already run the Auto Tuner as part of the quick setup earlier in this guide, please
skip ahead to "Channel Summary" to continue setting up your television. In Auto Tuner Setup,
the TV automatically scans through all available channels, memorizing the active ones and
skipping over blank ones or channels with weak signals. This means you scan using the
CHANNEL +/- buttons), you will receive only clear active channels.
Press the MENU button
?† To AUTO TUNER SETUP
?® To operate
?® To choose CABLE or AIR
Press the OK button to start
Initial Setup
Auto Tuner Setup
Programming will take approximately 1 to 2 minutes. The auto tuner is finished when the
message PROGRAMMING OVER! appears onscreen.
Channel Summary
Channel summary allows you to customize the line-up of channels received by your TV. You
can add or delete channels from the line-up or prevent any unauthorized viewers from watching
any or all 181 channels.
?† To CHANNEL SUMMARY
?® To operate
The Channel summary screen will now be displayed with
the channels set to scan marked with an "?". You can delete
channels from the scan by removing the "?". If any channels
were missed during auto tuner setup and you wish to add
them, you may by placing an "?" next to the channel number.
?† ?® To the SCAN column
Press the OK button to include or delete from scan
Press the MENU button when finished
You can block access to a channel by activating the channel lock.
?® To operate
?† ?® To the Lock Column ( )
Press the ZERO button to lock or unlock that channel
AUTO TUNER SETUP
CABLE
If you wants any codes, contact me through Fixya. Ok
I'm quating these procedure from the manual I've with me, and it is for JVC AV32S565.
Nov 08, 2010 | JVC AV-32S575 32" TV
Saving images from S5 Pro directly to laptop hard drive -how?
Hello Brian,
Are you writing to the camera memory because your card is full?
I'm not sure what USB auto/fixed is meant to do but try this.
Connect you camera to the pc as normal and switch the camer on.
The camera may ask you if you want USB or pictbridge, choose USB.
XP Then tries to offer you the best way to get at the photos. Rather than use the transfer option us the open as a folder option.
If XP doesn't offer anything click and open my computer, look for your camera it will appear as a new hard drive.
Click on the new hard drive, normally with olympus you get a folder, the first is you camera memory, click on that you should see photo's and another folder.
Copy or cut and past the photo's to a new folder on your PC. The click on the last folder, should be you memory card, move those photo's as before.
Having copied all photos you can delete them from you camera memory and card using the PC. Just as you'd delete any file.
With luck you should be back in action, a whole card to fill................. Good Luck.
Mar 07, 2010 | Fuji FinePix S5 Pro Digital Camera
Emacine T5234
to add memory, for increased virtual memory it is to delete msic data from the hard drive, if it is your hard drive low on space you should purchase another hard drive and make the new hard drive as the slave to store more, on it. if not have a bigger hard drive installed, obtain a USB external hard drive. to add increased more memory you have to open the pc, add another sdram/dimm/ddr memory card.
Dec 28, 2009 | Computers & Internet
My memory card is full and I want to transfer to my computer. I tried to transfer to internal memory but it says there isn't enough space. Anyway to transfer all at once instead of tagging individual...
Connect you camera to the computer using the USB cable. It will be shown as a removable drive(If the autorun is enabled windows should list the option to transfer pictures.Choose this option if it does so). Open the drive and and transfer the pictures to your computer.
Hope this helps,
Sai.
Dec 24, 2009 | Kodak ZD710 Digital Camera
Canon A560 will not erase pictures
Two possible solutions.
1. Apple users have reported that the switch on the memory cards performs the file lock function in either extreme positions Lock/Unlock. In some cases they have achieved success in centering the Lock/Unlock switch allowing access to the read/write operation of the memory card
2. Connect to PC
Access drive via windows explorer
Right click on drive (MEMORY CARD)
Select properties
Confirm that RO (Read Only) is not selected.
Selected RO
Try reading card
Repeat properties un-select RO
Try deleting files
If not successful card is likely defective
Hope this helps?
Mar 12, 2017 | Canon PowerShot A560 Digital Camera
Capacity
if you right click on the drive in my computer you can format it this should clear the memory and fix your issue.
hope this helped
please rate well
Mar 04, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
I lose all my text messages and phone numbers
This is probably because it is running out of memory. Blackberries will automaticall delete your SMS/Emails Logs when it has run out of memory.
Check by going to Settings/options --> Status --> File Free Memory.
It is very low, then you will have to hard reset the device to clear the cache. By pulling out the battery while the device is on, leave it out for 30 seconds and put back in. This should increase the memory. Otherwise delete some apps of the device or clear out emails/sms to make space.
Dec 12, 2008 | AT&T Blackberry Curve 8300 Smartphone
It flashes h 4 on and off
Solution: Perform a Fault Reset 14 bttn_print.gifMake Printable bttn_email.gifEmail this page elem_1_spacer.gif
  1. Find the pink Clear button on the Control Panel of the WorkCentre.
  2. Find the button below the word Auto.
  3. Press these buttons in the following sequence: [Clear], [Auto], [Clear], [Auto] NOTE: All of the lights on the Control Panel should go out and the LED Display should go blank. If the lights do not go out, then repeat step 3 until they do. It may be necessary to increase or decrease the pace of the [Clear], [Auto], [Clear], [Auto] sequence.
  4. Press the [10's] key one time and the [1's] key four times to enter '14' in the LED Display, as if you were to make 14 copies.
  5. Press the green [Start] button.
  6. Press the pink [Clear] button two times.
  7. The WorkCentre should now warm up and come to ready.
  8. If the above steps do not clear the error code, repeat steps 3 to 6 a second time.
Jul 12, 2008 | Xerox Office Equipment & Supplies
Canon 730i Laser Printer Logo
old marine
old marine
