General Electric DHDSR46GGWW Gas Dryer Logo
Posted on May 07, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My GE DHDSR46 gas dryer won't start, what should I
Dan Webster
Level 3:
  • General Elec... Master 8,221 Answers
  • Posted on May 08, 2011
Dan Webster
Level 3:
Answers
8221
Questions
5
Helped
2379120
Points
25840
505 is the thermal limit.
Looks like this:My GE DHDSR46 gas dryer won't start, what should I - themobilian_2319.jpg
Hunt for junk and clean that out, then replace this fuse if it is bad.
My GE DHDSR46 gas dryer won't start, what should I - themobilian_2320.jpgmages/themobilian_2320.jpg" alt="themobilian_2320.jpg" class="h_mi" />
See the white button to the right of the driver?
Thats the door switch, if open, that dryer won't run.
More Here
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Ge dryer model dhdsr46
There should be two tabs on the back wall that look like metal strips. Those are the sensors and they rely on the clothes to touch them every so often to get and idea how moist they are. The sensor is most likely not the case. You should check the wires to it but it is probably the control board
Jun 17, 2013 • Dryers
GE gas dryer won't start
you need a new motor
Apr 11, 2012 • Dryers
2answers
Everything lights up, but won't start when start is button is pushed. Lights turn on when door is opened.
There are 5 possible causes for this. Click here for the Service Manuals=> Trouble Shooting Guide and click here=> NGD7200TW Parts List and click here for your user manual=>NGD7200TW User Manual
For any Whirlpool Related manuals please contact me=> HERE Need Adobe Reader? Click Here sea_breeze_3.png
I will be here should you have other questions, Thanks, Sea Breeze
My dryer won't start. I unplugged it and plugged
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
WON'T DRY CLOTHS..NO HOT AIR
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101;'';';
Jun 27, 2011 • GE Dryers
I have a GE front loading dryer model # DBVH512EF0WW. It's about 1 1/2 to 2 years old. It has worked perfectly up until this point. When we push the start button, it just beeps twice, but does not...
heatman101
Dryer not getting hot
if you not technicail dont try,,,unit needs to be plug in for some tests...warning,,to start im thinking unit runs but dont heat..chech your operating thermastat first ,,next check yiur hi limit thermestat..they should be closed,,if good check your ignitor there should be 110 present..
GE dryer DHDSR46
check to see if you have 240 volts at the dryer
Top General Electric Dryers Experts
ADMIN Andrew
ADMIN Andrew
Virgil Watts
Are you a General Electric Dryer Expert? Answer questions, earn points and help others
