Question about Motorola Mobility ROKR E6 Smartphone
Folder locking In myMoto Rock-R e6 how can I protect a cetain folder/file with password, because I want to make it unaccessible from othes.........
In my moto rokr e6 i protect a cetain folder with password how can i do ?
Posted on Sep 08, 2008
Tip
Create a password protected folder without any special software
In an earlier post I had written about how to create an invisible folder. That’s a method to create a merely invisible folder with no real protection.
Now, here we will see how to create a folder that will not just be invisible, but also require a password to reveal it and open it. The best part is that you don’t need any special software to do this. Just plain old Notepad is all that you need.
Here is the code that you need:
cls
@ECHO OFF
title Folder Personal
if EXIST “Control Panel.{21EC2020-3AEA-1069-A2DD-08002B30309D}” goto UNLOCK
if NOT EXIST Personal goto MDLOCKER
:CONFIRM
echo Are you sure u want to Lock the folder(Y/N)
set/p “cho=>”
if %cho%==Y goto LOCK
if %cho%==y goto LOCK
if %cho%==n goto END
if %cho%==N goto END
echo Invalid choice.
goto CONFIRM
:LOCK
ren Personal “Control Panel.{21EC2020-3AEA-1069-A2DD-08002B30309D}”
attrib +h +s “Control Panel.{21EC2020-3AEA-1069-A2DD-08002B30309D}”
echo Folder locked
goto End
:UNLOCK
echo Enter password to Unlock folder
set/p “pass=>”
if NOT %pass%==pwd123 HERE goto FAIL
attrib -h -s “Control Panel.{21EC2020-3AEA-1069-A2DD-08002B30309D}”
ren “Control Panel.{21EC2020-3AEA-1069-A2DD-08002B30309D}” Personal
echo Folder Unlocked successfully
goto End
:FAIL
echo Invalid password
goto end
:MDLOCKER
md Personal
echo Personal created successfully
goto End
:End
Now here is what you need to do:
Just copy the above code and paste it into Notepad. Save it by giving it any name you choose. Assuming, the file is called secret.txt, change the extension to ‘.bat‘ so that the new name becomes secret.bat. What you get is a batch file. You could actually save one step by saving the file in Notepad directly as secret.bat by enclosing the file name like this: “secret.bat” . This batch file is the one that you need. You can edit this batch file to change the folder name and the password. To change the name of the folder that is created, change the ‘Personal’ (in bold in the above code) to any another name you choose. Likewise change the ‘pwd123′ (in red in the code) to anything else.
Now let’s see how to use it. Place the file in the location where you would like to create your protected folder. Run the batch file by double clicking on it. This will create a folder named Personal in the same location as the batch file. You can now open this folder and place any files in it. Once you are finished, run the batch file again. You will be asked whether you want to lock the folder. Entry ‘Y’ (for Yes) and hit Enter. The folder becomes invisible. To retrieve the folder, run the batch file again. You will be prompted to enter the password. Enter the password, hit enter and voila! the folder appears.
Important: The batch file acts like a key to open the locked folder. So once you have created and locked a folder, do not keep the batch file in the same location since anybody can open the batch file and view your password. So I would suggest that you keep the batch file in a separate and safe place or better still keep it on your pen drive or flash drive. That way when you want to open the folder just copy the batch file to the location where you have your protected folder and run it.
Do remember that the above method is not intended to act as a substitute for the numerous free and commercial softwares that are specifically designed to provide security and encryption to your data.
Update: I got comments saying the code does not work. Of course I did check it before posting it here. But I have identified the problem. The problem is with the straight double quotes used in the code in this post. Once you copy the code you would also need to change each of the double quotes with your keyboard double quotes. That might seem a lot of work for some. So I thought it would be easier to give away the batch file itself. You can download the file here. (Use right-click and ‘Save Target as’ or ‘Save Link as’).
on Mar 20, 2008 | HP Pavilion a1410n (ER890AA) PC Desktop
How can we unprotect our drive with folder lock professional
Folder Lock Professional encrypts your files to protect them. If you mean you want to decrypt your locked files, you will need to use Folder Lock Pro and supply the password. If you don't have the password, return or throw away the stolen laptop.
Jan 14, 2014 | Dell Computers & Internet
How can I password protect folders / files on my sandisk cruzer glide 128gb
Use the software that came installed on the drive. Use it to secure the whole disk. To access it you need to enter a password. Be careful though. The drive may not be accessible on Linux or Mac.
Mar 04, 2013 | SanDisk Cruzer Glide 128GB USB 2.0 USB...
Requard floder password
. Install VeryAndroid File Protector on your Android phone.
Go to the Market (on your Android) and search for VeryAndroid File Protector. Download and install it on your phone directly.).
2.
Run the VeryAndroid File Protector on your phone and you will see this screen:nlpvlrzmaaaaaaaelftksuqmcc
3.
Here you can select the file/folder you want to encrypt and protect. Click the file or long click the folder and you will see this screen:
4.
Click Encrypt File, enter your password then click "Encrypt" to continue:
5.
Done. Now the file/folder have been encrypted and locked.
Nobody will be able to access these protected contents without your password.
Feb 14, 2012 | Samsung S5620 Cell Phone
How do I password protect my eGo
Right click in your drive select new folder
Place all data files you want to password protect inside your new folder
Right click on your new folder select properties select the sharing tab
Scroll to network and sharing at the bottom
You have many options to password protect many files and folders Windows 7
In XP right click on your folder select properties then click the sharing tab tick the box do you want to make this folder private
A message might appear if you have a password do you want to create a password
Or you might download one or more of these all are free password protection programs
http://download.cnet.com/folder-lock/3000-2092_4-10063343.html
25 MB
http://download.cnet.com/truecrypt/3000-2092_4-10527243.html
http://download.cnet.com/my-lockbox/3000-2144_4-10789387.html
Hope this helps you
Nov 19, 2011 | Iomega eGo 1TB USB 3.0 Portable - Ruby Red...
Password Protecting a File...I have in the past done done this but forgot how...I remember I went to File-Properties-Security-Protect and then entered the pw I wanted to use....That doesn't work so...
Welcome to Fixya. If you want to protect or a File or a Folder you can follow the steps below.
Windows XP Professional
1. Select the folder you wish to encrypt.
2. Right-click the folder and click Properties.
3. Click the Advanced button.
4. Check "Encrypt contents to secure data" option.
5. Click Apply and then Ok.
Windows XP Home
3. Click the Sharing tab.
4. Check the box Make this folder private
The ability to encrypt files and folders is not available in Windows Vista Starter, Windows Vista Home Basic, and Windows Vista Home Premium
If you want to protect a Word Document please click on the link below.
How to password protect a Word document
How to password protect a Word document 2010
If you have questions please let me know. Thanks for using Fixya.
Mar 07, 2011 | Computers & Internet
Folder lock
Below link helps u..
Encrypt my Folder is a new folder password protected software which can help you lock your files, folders with your personal password. Prevent people from viewing, editing, altering your folders as easy as 1-2-3. Encrypting files, folders is the best way to guarantee that nobody accidentally or. Free download of Encrypt my Folder 1.2.0, size 1.57 Mb.
Encrypt my Folder 1.2.0 http://www.fileguru.com/apps/w580i_folder_lock
Thanks Good Day...
Jun 19, 2009 | Sony Ericsson w580i Cellular Phone
Pass word protection
Best free password protection software downloads.
www.freedownloadmanager.org/downloads/password_protection_software_software/ -
Password protection software software: Password protect any web page, easily, Superb suite of hard-drive protection tools
Jan 07, 2009 | Computers & Internet
"Unlock code"
please give the solution of unlock the moto rock E6
Aug 04, 2008 | Motorola Mobility ROKR E6 Smartphone
Motorola Mobility ROKR E6 Smartphone Logo
151 people viewed this question
Top Motorola Mobility Computers & Internet Experts
David Payne
David Payne
 Paul Flint
Paul Flint
Level 1 Expert
Unlockingcom
Are you a Motorola Mobility Computer and Internet Expert? Answer questions, earn points and help others
