Question about BellSouth Digital Answering System 2006C Digital Answering Machine
BellSouth Answering Machine Model 1188
Is there a way to get the BellSouth Answering Machine 1188 to ring more than 4 times before the machine picks up? Any help is appreciated. Thanks, Donna
  • amif Aug 29, 2008
    There is an option of "TS", is this the clue to ajust more rings before it picks up???
    Any help is appreciated. ((-:
5 Suggested Answers
SOURCE: bellsouth answering machine
TS stands for "Toll Saver"
It will ring 4 times if there are no new messages waiting, it will ring 2 times if there are new messages waiting.
This has two effects:
1) If you are calling home to check your messages, you can wait 2 rings. If there are new messages to check, then it answers immediately. If you make it to 3 rings, you know there are no new messages and you can hang up before you are billed for your call. This was more useful when you would use a pay phone or hotel phone to make a long distance call home. With a pay phone you would get your "quarter" back as long as there were no messages. With cell phones,it isn't as useful.
2) If you not home (which is implied by the fact that there are new messages waiting), it answers faster, so people calling you don't have to wait as long. This could also be viewed as a security risk... it tells your callers whether you are home or not.
- Ben
Posted on Mar 16, 2008
oldnovii
  • 667 Answers
SOURCE: instructions for model 1188
Hi Diana - To record your outgoing message, hold down your ogm button ( outgoing message) for two seconds and it will ask you to record a message. To play back your message, just push the same button and it will play your message. If you don't like it just do it again. If this solves your problem PLEASE rate this as fixed. If you need more help just add a comment and I'll be happy to assist you further. Thanks and have a good day.
Jeff
Posted on Jun 11, 2008
SOURCE: User manual for a Bellsouth answering machine model 1188
just push 3 to erase messages and 1 to play them
Posted on Jun 18, 2008
SOURCE: 1188 answering machine
I have model no. 1188 bellsouth digital answering machine. If you have to leave a message, the message I recorded is no longer there, there is a generic message saying please record your message. How do I go back and record my voice with my message. I cannot find my original manual.
Posted on Nov 02, 2008
  • 5 Answers
SOURCE: Bellsouth model 1188 digital ans machine
Press and hold the "clock" button. You will hear a beep and the display will begin flashing a number which represents the day of the week. 1=sun, 2=mon, and so on. Press the left and right arrow buttons to scroll through. After choosing the day, press the "clock" button again to set the hour. It will start with 12 am and go through 11pm. Press "clock" again after setting the hour to set the minute.You will be able to scroll through 0-59 to choose the minute. When finished, press the "clock" button again to exit the time setting feature.
Posted on Mar 14, 2009
BELL SOUTH MODEL 1188 .HOW DO I CHECK MY MESSAGES WHEN I AM AWAY FROM HOME
Usually you dial your phone number and put in a passcode setup in the answering machine. It may be written on the bottom or in the instruction manual.
Oct 06, 2009 | BellSouth Lands Phones
Would like more than 4 rings until machine answers
TS is the Toll Saver Option.Sometimes this will let it ring many times, before answering.
4 rings is the maximum setting. You might try the TS, then try calling to see if that helps.
Apr 28, 2009 | Lands Phones
Jan 26, 2009 | BellSouth Digital Answering System 2006C...
Oct 07, 2008 | BellSouth Digital Answering System 2006C...
Manual 1200
I was needing a copy of the manual for the Bellsouth Answering Machine and the model number is 1188
Jennifer M. Pate
Aug 07, 2008 | Lands Phones
Instructions for model 1188
Jeff
Jun 11, 2008 | BellSouth Digital Answering System 2006C...
Change time & day
Does your system have a time/code button? If it does, hold the button down for about 5 or so seconds until you hear the date, then use your arrow keys up above & change to appropriate date & time.
Apr 23, 2008 | BellSouth Digital Answering System 2006C...
- Ben
Mar 13, 2008 | BellSouth Digital Answering System 2006C...
Found my manual!
To set the time, press and hold the time/code button for 2 seconds. You will hear "TO SET CODE PRESS TIME AND CODE BUTTON."
Release the time/code button.
Press the 2 way/m button once. You will hear "SET DAY AND TIME, SUNDAY"
Press the << or >> button until you hear the correct day.
Press the time/code button once. You will hear "TWELVE"
Press the << or >> button until you hear the correct hour.
Press the time/code button once. You will hear "OH".
Press the << or >> button until you hear the correct minutes.
Press the time/code button once. You will hear "PM".
Press the << or >> button if you need to change to AM.
Press the time/code button once and you will hear the complete time and day setting.
To record an outgoing message, press and hold the ogm button. Release the ogm button and start to record after you hear "PLEASE RECORD AFTER THE TONE" followed by a beep tone. When finished, press the ogm button.
Make sure you put a battery in the answering machine so you don't lose these settings if the power goes out!
Nov 11, 2007 | Lands Phones
BellSouth Digital Answering System 2006C Digital Answering Machine Logo
230 people viewed this question
Top BellSouth Lands Phones Experts
Are you a BellSouth Lands Phone Expert? Answer questions, earn points and help others
