We have a very fast constant drip coming from a hose in the top eave of our two story home. We checked the drip pans for the AC (2 units) and all seems dry. Where is the water coming from?
  • 182 Answers
The water would be condensation taken from the house(humidity)
The water dripping outside is normal.
Posted on Aug 12, 2008
Goodman AC drip pan full and the filter is wet
so you used a hose to blow it out but nothing came out? if so the problem is in the piping. you must have 1/4 inch per foot of fall with no sags unless you are using a condensate pump
Sep 03, 2012 | Goodman Heating & Cooling
Water leaking around screw of ac vent in bedroom. it is a slow drip that is constant even when the ac shuts off
From what you described, it sounds like the drain hole in the condensation pan under the unit is clogged. Also, the unit may not be titled down enough at the rear of the unit. Generally, 1/4" to 1/2" is required, so that the water in the condensation pan will flow to the rear of the unit, where the drain hole is. These 2 things are where you need to start troubleshooting.
I hope this helped you and thanks for choosing FixYa.
Jul 21, 2011 | Heating & Cooling
My ac unit is now after 3 weeks of use dripping water inwards(even with a 1/4" slope of the unit to the outside) is my drip pan overflowing?
Yes, your drip pan is overflowing, because the drain hole near the back of the unit is clogged. There are 2 ways to address this problem.
1. Look out side the house, under the unit and search carefully for the drain hole or drain tube. If it's a hole, clear it using something like a pipe leaner. It it's a tube, use 2 pipe cleaners twisted horizontally together and carefully run it up into the tubing in a push/pull motion. This will help dislodge any clogs.
2. If you're feeling really lucky, turn the unit OFF and unplug it. Straighten out a wire coat hanger leaving a little hook on one end. Remove the front cover of the AC unit and slide the coat hanger under all the mechanical parts into the drip pan. Sweep it around carefully in the drip pan. all the way to the back of the unit. Be careful not to get the little hooked end caught on anything, by keeping it flat against the drip pan. Doing this, may dislodge any clogs.
And finally, if you're in a high humidity area, increasing the tilt to 1/2" may help improve the drainage.
Hope this helps you unclog the problem.
Jul 20, 2011 | Heating & Cooling
No water drips from back, after several hours of u...
First. if it's shutting off the microwave, then it's on the same circuit, which is not good. Secondly, as to the drain, check the hose to be sure it is not kinked or obstructed. Is the drip pan and hose seperate from the unit? There should be a small indent on the bottom that allows water to drain, check to see that it is clear. Hope this helps.
May 20, 2010 | Whirlpool ACE244XS Air Conditioner
I have a Weather King AC/Furnace in the attic that's dripping water into the drain pan. When we purchased our new house it came with this unit and it never dripped ater. Now, the water is dripping towards...
I assume it is dripping water when the AC is running. If you look at the attic unit, there should be a PVC pipe running from the unit - probably an insulated PVC pipe. This pipe probably goes across the attic to the edge of the house and drains outside. The drain pan may also have a drain pipe, but the one on the AC unit is the issue, and is probably plugged. Go outside and see if you can locate the AC drain pipe. See if the ground is wet below the pipe and if water is steadily dripping from the pipe (with AC running). If the pipe and ground are dry, the pipe is plugged. If you have a wet/dry vac, try connecting it to the drain pipe outside to see if you can **** the pluggage out. If you can get it clear, water should start dripping out of the pipe. This same thing happened at our house. I decided to cut the pipe in the attic, and add in a PVC isolation valve, tee, and water hose connection with plug, so I can valve out the AC unit from the pipe, remove hose connection plug, and hook up a water hose and flush the line to outside. Lowe's sells all of the PVC pipe fittings. The water pressure from the hose will always flush out the algae and crud to the outside of the house. I can also remove the plug and pour a cup of bleach down the drain pipe every couple of months to keep algae growth in check. I also cut out the trap (u-leg) from pipe in the attic and purchased a ready made trap a Lowes (the contractor who built our house had made a lousy homemade trap). I purchased a few PVC elbows and installed the trap on the drain pipe outside. By the way, our AC drain pipe comes out of our wall outside and drains near our outside unit. Our secondary drain pan drain pipe comes out outside from an eave on the side of the house. I don't know what you drain line looks like (it may have a port to add bleach, or some cleanout provisions, maybe not). If you choose to modify/improve it, then make a sketch of it, go to Lowe's and get the PVC parts you need + PVC pipe primer and cement. PVC cement dries fast. Remember, the pipe must flow downhill from you AC attic unit. You can use a regular wood saw to cut the pipe. I hope this helps you. You need to keep the drain line clear as algae will continue to grow in it. Pouring bleach in the line every month or two helps. You also need to check maybe once a month that the line is draining properly (check to see if dripping outside). You can get some serious water damage to your ceilings if the water backs up and overflows. I discovered that our drain line was plugged just in time as our drain pan drain line was also partially plugged and drain pan was about to overflow.
May 08, 2010 | Weather King 12AJA4201AH Air Conditioner
Dripping water from the pvc drain pipes of 2nd story eaves.
yes, that is your emergency drain pipe. You need to have the a/c drained cleaned out. It is probably jammed up with algea. A professional should be called to blow it out. or get ahold of your Mr. Fixit buddy. If you leave it like this your drain pan will eventually rust out and cause major interior damage to your home.
May 14, 2009 | Heating & Cooling
Trying to find drainage system/idea for ac unit
You can install a condensate drip pan under it and attach a hose to take the water wherever you wish. Drip pans are standard A/C components -- you should be able to get one at an HVAC supply store.
May 06, 2009 | Frigidaire FAC107P1A Wall/Window Air...
Constant oil dripping, rubber hoses (2), at back of oil pan
those are now hosees they are dust plugs and why the oil is comming out is cuz its leaking from above.the intake gaskest in rear top of engine are most likely your problem,possible rear main crankshaft seal
Mar 31, 2009 | 1997 Chevrolet Blazer
Collecting water on top of house boat from air conditioner
Thess units are designed to discharge the condensed water onto the roof under normal conditions. HOWEVER you should be able to have a sheet metal person make up a drain pan to fit under the unit.
You would ten need to add an additional gasket between the drain pan to roof and drain pan to A/C unit. The drain pan could have a hose connection attached to the drain pan. Try it, you might like it.
Also you may have to get longer screws to tighten down the A/C from below.
Jul 22, 2008 | Dometic Rooftop RV Air Conditioner
A.C. unit
One of the cause of water dripping in the indoor is restricted drainage. To Identify if your drainage is restricted.
- Turn "off " the circuit breaker and take out the face cover of the unit.
- Turn "on" the circuit breaker and start the unit, wait until the unit drips.
- When the unit dripped check the drain pan if overflowed with water.
- If the drain pan is full of water you need to flush the drainage with water to remove the restriction. If the pressure of water in your area is high you can use your garden hose to flush the drainage.
Another is dirty evaporator fins (icing), dirty drain pan, broken drain pan or incorrect installation.
Aug 16, 2006 | Carrier IBM UNIT 2380 79F4796 Drive Case
Heating & Cooling Logo
250 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
