Question about Samsung HCM4216W 42" Rear Projection Television
SAMSUNG HCM4215W Rear Projection HDTV shuts down
Recently repaired the convergence problem with the tv; replace the two STKs, the pico fuse, and the fuse resistors. After converging, the set had a beautiful picture for about an hour or two, then it shut down. Turned it on again, and in 5 to 10 seconds it shut down again. Disconnected the wires from the convergence board and the set played continuously. Thought it might be solder issue, so I removed the main deflection board (on right side as you look in from the back) and checked for cold solders. Replaced the board, but still has same problem. I am at a loss as I don't have a schematic. Any ideas as to what this problem could be would be greatly appreciated. Thanks in advance.
    Novelist:
  • 132 Answers
Low ohm resistors are open or poor solder connections on the bottom of a convergence IC.
You need to look at resistors in good light with magnifying glass. Bad ones may show as discolored or burnt.
The repair needs someone that has the schematic for the convergence cct, and can replace the burnt resistors or replace the whole convergence board.
http://calgaryconvergencerepair.weebly.com/index.html
If you are near Calgary, call me, if not, find someone that has done it before, preferably many times.
easyab
Posted on Aug 15, 2008
I have a Samsung Rear Projection TV with an HDTV 1080i Monitor. I know the convergence is messed up because the blue would not move when I tried to adjust it on the menu. So, then I tried to make it
You will need to replace both convergence Ics and the pico fuses that blow when the Ics fail. You can get the replacement Ics and pico fuses from www.tvreairworld.com they also provide free tech support to help you install them
Oct 27, 2012 | Samsung HC-P4752W 47" Rear Projection...
Samsung 42" rear projection HD tv issue
pico fuses are those small on board fuses, usually soldered into place, that protect important parts of the board.
Feb 26, 2008 | Samsung HCM4215W 42" Rear Projection...
As I plan to do my convergence repair for my 46" projection tv,resistors are mention to be replace aside from the 2 convergence IC's as well as the 6 pico fuses ( 2 for the G board and 4 for the D board )...
Just replace Both of the STKs but CK all the pico fuses in front and behind STKs they are yellow or green 5amps 6amps For Parts Call Mats Electronic 1-800-628-1118 I have changed out alot and so far have never had to replace any resistors.
Nov 21, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Tv red light blinks off and on. Unplugged for an hour Tv worked for 10 monutes and then picture went to top left corner and got blurry. TV HAS BLINKING RED LIGHT AGAIN.
Replace Both of your convergence ICs one is bad ,but replace both STKs big black ICs also CK two resistors in same circuit 2.7ohms
Aug 11, 2009 | Samsung HCM4215W 42" Rear Projection...
Tv shut off and started clicking
Do you hear a constant chirp or click?
If so you will most likely need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
Jun 12, 2009 | Philips 60PP9363 60" Rear Projection...
No picture on samsung hlp5063wx/xaa
to test this set
unpug the 4 pin conector labeld + and _ 20v on the cg convergence module
if set turns on, the problem is that modual
repaie
replace bolth convergence IC'c stk392-040
also check all 3.9 ohm resistors and both pico fuses.
regards,
daniel.
Jan 16, 2009 | Samsung HCM4215W 42" Rear Projection...
HCM653W color convergence off
Ck low ohm resistors 3.9 omh and pico fuses they look like resistors but they are green or yellow 5amps, 6amps,sometimes after replacing STKs there is bad resistors or open pico fuses.
Dec 22, 2008 | Samsung HCM653W 65" Rear Projection...
AKAI Rear Projection TV PT5598HDIX has sound but no picture
double check your solder connections on stks,check pico fuses they go bad check connections . see if high voltage lead is connected .
I do alot of these and have run into same thing and i had bridged a solder connection.
I hope this helps
thanks doctor video
May 01, 2008 | Akai PT5598HD 55" Rear Projection...
Tv wouldn't turn on, unplugged convergence board, turned on, replaced STKs, still have convergence problem
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Feb 07, 2008 | Samsung HCM4215W 42" Rear Projection...
Samsung HCM4216W 42" Rear Projection Television Logo
190 people viewed this question
Henry  Thomas
Henry Thomas
