Workcentre pe 120 has paper jam 1 - -however, there is not paper jamed.
  • terry om Aug 12, 2008
    THANK YOU!!!!
    It took a few minutes to locate the sensor - - - but it is WORKING!!
    THANK YOU!!!!!!!
    Terry O
  • pe120 Jan 05, 2009
    Where exactly is that sensor? And what should be done with it?
    I have removed the tray and looked on the bottom of the machine, but I could not find any sensor.
  • 2,072 Answers
There is a sensor on the bottom of the machine that comes out of the latch.
Posted on Aug 12, 2008
  • Rick Kasper Aug 12, 2008
    Your welcome. Glad to have been able to help.
I need need a picture on how to remove a paper jam in xerox 4118 machine right now please
Well open the printer where you can(the closest point to the jammed paper) attempt to remove the jam by attempting to pull the Jamed paper in the direction it would normally exit the machine.thats about as far as I can get you with the information I have--Good Luck.
Feb 01, 2013 | Xerox WorkCentre 4118 Network Kit - 1 x...
Xerox workcentre 5765 paper jam message but no paper is jammed
Check all the paper detecting sensors once more, may be there is something over the sensor.clean all the sensors with VIDEO 90. if after that problem persist please restart the machine and go for software and firmware upgrades.
Oct 20, 2012 | Xerox WorkCentre 5765 5775 5790 Fuser...
Mfc240 c gives unable to print see troubleshooting guide 51 I have tried all I know to do
The message Paper Jam may appear on the display if the Brother machine is not feeding paper correctly, paper scraps have become stuck in the print head path, the paper is not loaded properly in the paper tray, the jam clear cover located in the back of the machine, is not installed properly or the PE Actuator is missing or damaged.
To solve this problem, please follow the steps listed below:
Note : images shown below are from the representative product and may differ from your Brother machine.
  1. Disconnect the machine from the power supply.
  2. Turn the unit around and remove the Jam Clear Cover from the back of the machine by grasping it at the Center and pulling it straight away from the rear of the machine.
    Caution DO NOT place the jam clear cover face down as shown in the illustration. You may damage the cover and cause paper jam.
  3. Look for any paper scraps, jammed paper or foreign objects in the rear of the unit. If anything is found, remove it.
    Be careful not to touch the feed roller.
  4. Remove the Paper Tray from the machine.
  5. Remove any remaining or jammed paper from the front of the machine.
  6. Look inside the machine, where the paper tray was installed and locate the white PE Actuator.
Caution Do not stand the machine on end. Ink may leak from the machine.
The PE Actuator looks like a 2 prong fork or tuning fork and is located near the rear center of the machine where the paper tray slides in. It is located between the 2 gray rollers.
  • If the White PE Actuator is in place, continue to Step 7.
  • If the White PE Actuator is missing, please contact Brother Customer Service from "Contact Us".
Using both hands, use the plastic tabs on both sides of machine to lift the flat-bed scanner until it locks securely into the open position.
  • Carefully examine areas 1 and 2 at the left and right hand ends of the platen area for paper scraps.
  • These scraps may have become saturated with ink and be difficult to see.
  • Use a flashlight if necessary to check thoroughly.
Aug 13, 2011 | Brother Office Equipment & Supplies
I have a samsung scx 4200 am getting the papaer jam error even when theres no paper jamed up there
Good Day Sir,
when paper jam occurs, Paper jam appears on the display.
Message Location of Jam
[Paper Jam 0] - In the paper input tray
[Paper Jam 1] - In the fuser area or around the toner cartridge
In the manual feeder
[Paper Jam 2] - In the paper exit area
hope this will help you. god bless
Nov 06, 2009 | Samsung SCX 4200 All-In-One Laser Printer
I have xerox workcentre xd105f, can't make copies, paper jamed and letter P on display
to remedy the P display error remove the paper tray and take any paper from under the tray and between the rollers, clean the rollers with alcohol or an acetone solution to remove paper dust and paper debris, refit the paper tray with the paper pushed below the tabs on the tray ensuring that the correct paper size is shown, IE: ltr ltr-r etc.
power the unit off and on and you should be back in business.
If this remedies the problem please rate the solution accordingly
Jun 19, 2009 | Xerox WorkCentre XD105F Laser Printer
I have xerox workcentre xd105f, can't make copies,paper jam
P will flash on the screen when the paper tray is empty, paper misfeeds or the paper tray door isn't closed all the way. Make sure both (if you have 2 paper trays) are loaded, that the paper isn't folder and wrinkled, and ensure that the tray doors are closed firmly. Then hit start on the workcentre to continue any unfinished jobs.
Jun 19, 2009 | Office Equipment & Supplies
Xerox Workcentre 24- Paper jam in the fuser
Shut down. Unplug!!! Remove fuser to remove jam. Fuser may be or be going bad.
Apr 22, 2009 | Xerox WorkCentre M-24 Color Copier
Workcentre 24 wrinkled paper when copier used
Its a jaming and cutting shits leave some litle bit peace of them///finde of them and remoove
Mar 24, 2009 | Xerox WorkCentre M-24 Color Copier
Paper jam
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this, is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 10, 2009 | Brother Multi-Function Center MFC-240C...
Paper jam
Remove the paper following the procedure below.
(1) Load a single sheet of the same paper in the Auto Sheet Feeder in portrait orientation.
Do not load it in the landscape orientation.
(2) Turn off the machine.
(3) Turn on the machine.
The paper is fed and then pushes out the jammed paper as it ejects.
If you cannot remove the jammed paper or the paper jam error continues after removing the paper, contact your Canon Service representative.
James Mac
Sep 09, 2008 | Canon PIXMA MP600 all-In-One InkJet...
