Alpine CDM-7874 CD Player Logo
Posted on May 07, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
IM TRYING TO WIRE A PIONEER DEH-5 TO MY STOCK WIRES IN MY 1996 VOLKS JETTA. I CHECKED OUT THE WIRING DIAGRAM ON THE JETTA AND SOME OF THE WIRES DID NOT MATCH UP,LIKE FOR INSTANCE THE SWITCHED WIRE ON THE DIAGRAM SAYS THAT ITS THE ORANGE WIRE BUT IN THE CAR THERE ARE TWO ORANGE WIRES ONE WITH A RED STRIPE AND ONE WOTH A WHITE STRIPE SO IDK. THE OTHER ISSUE IS THAT IF I HOOK UP THE CONSTANT POWER AND THE GROUND WIRES FROM THE CAR TO THE HEAD UNIT. IT SHOULD TURN ON CORRECT OR AM I FORGETTING SOMETHING?
Jeffrey Turcotte
Level 3:
  • Master 8,991 Answers
  • Posted on May 07, 2011
Jeffrey Turcotte
Master
Level 3:
Answers
8991
Questions
7
Helped
4370337
Points
33683
Hi, the plain orange wire is the power wire. The constant wire is only for maintaining the station presets--it does not power the unit on. The other orange wires are for speakers. See the full color code below, and let me know if you have any more questions.
1996 Volkswagen Jetta Car Stereo Radio Wiring Diagram
Car Radio Constant 12v+ Wire: Red/White
Car Radio Switched 12v+ Wire: Orange
Car Radio Ground Wire: Brown
Car Radio Illumination Wire: Gray/Blue
Car Stereo Amplifier Location: If equipped, each speaker has an individual amplifier located at the speaker.
Left Front Speaker Positive Wire (+): Blue/Black
Left Front Speaker Negative Wire (-): Orange/Black
Right Front Speaker Positive Wire (+): Red/White
Right Front Speaker Negative Wire (-): Orange/White
Left Rear Speaker Positive Wire (+): Red/Light Green
Left Rear Speaker Negative Wire (-): Orange/Black
Right Rear Speaker Positive Wire (+): Blue/Light Green
Right Rear Speaker Negative Wire (-): Orange/Red
Wiring diagram for pioneer deh-p6200bt
do you need the wiring for the deck or for the car(or both)
4helpful
Pioneer DEH-17 wiring diagram or pinout connection
the groung wire was torn out of my deh1700 pin connector where does it go back
2helpful
Wiring A Pioneer DEH P6400
If the factory harness is still in tact, you can buy an adapter at Best Buy for about 20$ or ask to see one and write down the pins and wires then match it up and cut n splice to your new deck. Hope this helps
9helpful
Can not find a wireing diagram for a pioneer DEh-p2600
Pioneer follows the universal after-market color code, so if your CD player was made in the last ten years or so, the wires should go like this:
Yellow: Constant +12VDC (memory)
Red: key-switched +12VDC (accessory)
Black: Ground
Blue/white: amp remote or power antenna output
Speaker wires: The solid-color wire of each pair is positive; the black-striped wire is negative.
Left front: white
Right front: gray
Left rear: green
Right rear: violet
Hope this helps!
Kenwood ks-122 in-dash car stereo/cd changer
For your Jetta, you may need a different wiring harness.
You need to be able to trace the wiring from the two dins on the back of the Kenwood receiver, and une the wiring diagram for the 1996 Jetta.
Perform your cross reference here for the receiver wiring:
http://www.justkenwood.co.uk/editorial/inst_rec.asp
Here's the wiring for your Jetta:
http://www.modifiedlife.com/1996-volkswagen-jetta-car-radio-stereo-wiring-diagram/
From the jetta wiring, it looks like your Right Front speaker isn't connected.
Here's the wiring for your Delta 88:
http://www.the12volt.com/installbay/stereodetail/1724.html
Happy hunting!
Top Alpine Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Steve Sweetleaf
Steve Sweetleaf
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
