Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Our Master Mechanic model 601MM garage door opener goes up about 8" and down 6" when you go to open it. I have checked the safety and they both have the green light and if you hit the button and put your hand over the stop area it will stop it. What could it be thats making it just go that little bit and come back down. I have unhocked the door and it doesn't make any difference
  • 504 Answers
I WOULD CHECK THE RPM SENSOR
IF IT IS BAD OR THE CUP HAS MOVED OUT OF THE SENSOR YOU WILL GET THE EXACT SYMPTOM YOU DESCRIBE.
Posted on May 31, 2010
How to program Clicker Keypad with Master Mechanic 501MM
Master mechanic 601mm on the buildmark - YouTube
? 2:14
www.youtube.com/watch?v=ga8yaYi0brY
Feb 18, 2012 - Uploaded by RGDMan
Master mechanic 601mm on the buildmark .... Reset Garage Door Keypad Code PIN & Remote Control Opener - Duration: 2:51. by ... Chamberlain CLICKER Universal Remote ControlProgramming Video - Duration: 5:21. by ...
Sep 28, 2015 | Building Materials
Need to program car remote control with garage opener
your owners manual has a description in it about how to do this. the controls on the opener can be set with the controller from the manufacturer, then the car. need to read the manual
Feb 24, 2015 | 2014 Ford Escape
I have an access master door opener..it goes up about 6 inches and stops, hit switch again, goes down, hit switch again goes up about two feet, hit switch again goes down, third time switch nothing until...
Door sensors have nothing to do with door opening. Only closing. It sounds like you have a bad gear in the motor unit. Remove the cover and it will be obvious if the gear is bad.
Feb 15, 2011 | Sears Craftsman LiftMaster Chamberlain...
Product Lift Master Professional Line 1/2 HP Security + Model # 1265LM Door goes down intermittently. Door will go down approx. 8 - 10 inches, stop and then retract. Remote in hand, I press the...
Check alignment of the obstruction sensors .... they shoot a light beam across the doorway about 6 inches above the floor. One is mounted on each side of the door track near the floor.
Aug 29, 2017 | liftmaster Chamberlain Garage Door Opener...
Access Master 1/3 HP garage door does not close, blinks
Most likely your door sensors are out of alignment. Make sure they are pointed directly at one another.
Apr 10, 2010 | Sears Craftsman LiftMaster Chamberlain...
My garage door bucks like a bronco
You have a door problem. The reason the door is reversing to the open position is because when it bucks the safety senses something wrong. Release the door from the opener and operate it by hand. You should find something.
Jun 23, 2009 | Sears Craftsman LiftMaster Chamberlain...
Pressing remotes the door won't go u[
It sounds like you have the lock enguaged. When it is flashing it locks out all remote access. Hold the lock button for 3 seconds. The green light should go solid. On the issue of closing, it is most likely a safety eye issue. Hold down the wall button. If it closes it is the safety eyes. Holding the button overrides the safety eyes. Make sure that thelight on both eyes are both lit.
Jan 27, 2009 | Sears Craftsman LiftMaster Chamberlain...
Door opens only 6 inches and stuck
I would try jumping a wire across the white & red terminal to see if your safety sensors are working Properly! If your door opens you have a loose connection or faulty sensors.
Oct 22, 2008 | Sears Craftsman LiftMaster Chamberlain...
Chamberlian 2280 Whisperdrive
Check the light beam safety at the door's bottom, to see if something is getting in the line of sight.
Jul 25, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
1,094 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
