Is their an adapter that can be used to connect my ATP3 speaker to my PC. The speaker connection cord has an s video type connection. I believe this speaker come from a Mac computer that had s video connections.
You'll need some type of amplifier to drive the speakers. The Samsung TVs mostly have a line out and a headphone out, but that wont drive speakers unless they are powered speakers like PC speakers or a powered sound bar. (Like the Pioneer SP-SB23W soundbar/subwoofer) If you have some of these get a mini 1/8" stereo plug to RCA plug adapter from BestBuy or similar. If you have PC type speakers, You'll need a 1/8" mini stereo patch cord to go from the line out to the speaker input. (Set the audio out on the TV to variable so you can control the volume with the TV volume.)
No the sound does not travel through the vga cord only HDMI has bidirectional with sound.. You gonna have to use the speakers on your laptop for sound or buy some amplified ones.. good luck
I've had intermittent speaker problems with these models and it was caused by slight abuse, ( stress on the speaker jacks at the main board located in the main subwoofer cabinet). The problem can lead you to believe its the speakers or the wires but in my case it was a loose solder joint on the main board in the subwoofer. I had to take the subwoofer apart and carefully re-solder the connections of the speaker jacks. I've had no problems since. I've also been a little more careful not to push the jack side of the connection against the wall, kicking with my feet etc..
The cord you are looking for, that plugs into the "input" of the speaker and the speaker output (green) audio connector of your sound card looks like a plug for a pair of headphones. It will have the same type of connector on both ends, the male connector.
it is a 3.5mm male mini stereo plug at both ends.
Headphones have two type of plugs, the 3.5mm or the 1/4 inch jacks. The headphones for personal audio devices like an mp3 player, ipod or the like have a 3.5 mm, most older and some newer receivers have the bigger 1/4 inch jack for headphones.
so look at a pair of headphones, notice the plug on it, and then find one that has that same plug but on both ends of the cord.
If you need more help let me know, and if you found this advice helpful a "FixYa" rating would be appreciated.
Obviuosly,the tiny wires inside the insulations have more often than not,red and or white colors and you might have erroneously reconnected them through soldering.Yet,you didnt get the desired result.Visit an electronics spareparts store nearest you but make sure you bring the damaged cord with you,Inquire from them for a compatible cord which you can use as a replacement because if you continue using tis damaged cord might severely affect the entire system.Thanks.
hi i used to have the same problem opening the satellite speakers of atp3 (left satellite, the cord was pulled and snap from the inside). i found out how to open them but there's a good and bad news. the good news is i know how to open them, the bad news is that it will cause some damage on your satellite speaker.a friend of mine used to have the same speaker he accidentally drop one of his satellite speaker (left one) and the bottom cover just crack open following the joint line. the satellite speakers of atp3 has no connecting screws , it is assembled using a sort of super glue. here is how i opened my satellite speaker. i used a flat screw driver (i sharpened it a bit to easily penetrate the joint) to shove the bottom cover of the speaker starting from the back part (near the cord) then slowly made my way around when the cover start to snap from where i started. you can remove the bottom cover this way but be aware that it will cause some damage on you speaker. i started shoving from the bottom back part because the damage is unnoticed when you reassemble it using a super glue and i use a black paint to hide the discolored plastic casing cause by force opening.
