Hp 6280c printer. Had a jam while printing transparency. cleared jam. Now print will not print. Cleaned heads. Ran test. Aligned heads. Printer printsbut color faded. Skips lines. Poor quality.
  • wmolloy Aug 12, 2008
    I had a jam while printing transparency. Print quality is poor. Skips lines faded, does not print all text. Changed ink, cleaned heads, aligned heads, and tested. Still bad problem with the print.
    I am using correct cartridge.
    Master:
  • 623 Answers
Make sure you are using the right cartrigde
Posted on Aug 12, 2008
  • 10,594 Answers
Ink might be finished, try to install new ink catreges.
  • 2 more comments
  • Shahid Electronics
    Shahid Electronics Aug 12, 2008
    Check the ERROR here and its price of cartridge is HERE.
    Well, in this case, pls check printer's properties, can be changed to defualt settings or some thing could be wrong with it because you been tested already all possible options.
    one day, my hp printer started same problem, no good printing result, I took out its cartridges pick cotton swab, dip it in water, and rubbed it on face of cartridge head, cleaned it with tissue paper and placed back cartidges. that trick worked and started good printing. I'm not sure to suggest you this trick but if you wanna try, go ahead. my theory was the ink got dry at heads, so water cleaned it.
    Shahid Electronics Aug 15, 2008
    I hope printer problem is solved :)
My printer is printing wavy lines and also has a faint line down the middle of the page.
It has to be because print heads are dirty. I find it is best to use the printer every few days whether you need it or not. Just print a test page to keep your ink from drying it the heads.
Mar 21, 2015 | Canon PIXMA MX472 WIRELESS OFFICE...
HP Officejet 6310 will not print cyan
The Cyan print head nozzle maybe blocked.
If deep cleaning does not fix it then you need a new print head.
The cost of a new print head is expensive and it maybe better to get a new printer.
Oct 15, 2012 | HP Officejet 6310 All-In-One InkJet...
Blocked cartridge on my c3150 hp printer
Inkjet printers need to be used frequently to prevent inkdrying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages,then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer thanreplace the print head.
Jul 07, 2012 | HP Photosmart C3150 Printer
HP 6180 Print Problem: I'm getting horizontal streaks when printing either in colour or black, Have cleaned the heads through the printers tool box and ued both levels of cleaning. Also aligned the pr
Fill an old black cartridge with hot water and scan and copy something with a lot of black on it. cleaned out my black ink clog after about 12 copies. Put new ink in and it's working fine. Oh yeah, use a syring minus needle to fill lower o-ring on back of cartridge.
Dec 26, 2011 | HP Photosmart C6180 All-In-One InkJet...
Printer has ink but wont print in color test page wont print in color, also aligned printer and it worked in color. cleaned printer head as well which printed all the colors. what else can i do? It seems...
Take color copy, test all colors are OK..Go to printer properties, printing preferences, finishing check is there any check mark on print in black cartridge only? mark on print color..apply..OK.. give print command..
Go to paint draw a color drawing, print it.> check colors if its not printing in color it might be drivers issue.. un install the drivers re install once again check..> if printed in color check the file which you are printed..take another file.. then test..
Oct 29, 2011 | HP Photosmart C6180 All-In-One InkJet...
HP DESJET 694C - NO LONGER PRINTS IN COLOR - TRIED SEVERAL CARTRIDGES, CLEANED PINS, ALIGNED AND REALIGNED - NO CHANGE.
Did you checked Printer Settings? May be option is check Marked that "Always print in Gray Scale" if yes then remove check mark.
Disconnect printer from computer and Try to press resume copy or start print button for 5 seconds to start Test Print directly from printer. it prints in color then there definaly a setting problen in your computer printer settings.
Last Option is to check or replace print head.
Mar 09, 2010 | HP Office Equipment & Supplies
My HP 6500 won't print blue. New ink cartridge installed, heads aligned, and cleaned. Still no blue. Any ideas.
Print test page in the software, if no blue try print head clean again, if no go return cartridge for replacement.
Is it genuine or refilled??
Jan 13, 2010 | HP Officejet 6500 Wireless All-in-One...
Printing lines not straight and letters shadowed. Help!
Open the cover over the print head and *carefully* inspect the clear thin plastic strip that runs from left to right near the print head. If you see any lubricant (white grease) on this encoder strip, it needs to be cleaned off.
1. With the cover open and the print head in the center, unplug the power cord. This will allow you to gently move the print head left or right.
2. With a cotton swab wetted with rubbing alcohol, *gently* wipe the grease spots from the encoder strip. (Be VERY CAREFUL you don't dislodge the strip.) You may need to move the print head to the left or right to get all areas cleaned.
3. Let the alcohol dry off completely. With the area clear of cleaning tools, debris, and fingers, plug the power back in.
4. Try a test print.
Jun 17, 2009 | Canon PIXMA MX700 All-In-One InkJet...
HP 3845 Inkjet won't print color under OSX
Try this test:
Let's say you want to print this present page (of fixya.com from Firefox or another web-browser), try File/Print and see if you have the tab Advanced to change to the color cartridge.
Oct 29, 2008 | HP Deskjet 3845 InkJet Printer
Televison & Video Logo
69 people viewed this question
Top Televison & Video Experts
Electro Med Services...
