Fitting pioneer head unit(DEH P6100R) into my transit van, unsure of memory wire and and what cable it should be attached to. i'm crimping these my self as previous owner cut off connecter
robotek
  • 1512 Answers
SOURCE: pioneer deh-30mp
Hi again Kingt005
go to here and enter your town details and it will locate the nearest Pioneer dealer to you. They will be able to sell, or order in for you the harness you need. Even ring them first to be sure that they are a car audio dealer. They may even do it for you over the phone:) A FixYa rating is a great reward for my efforts to help you so far. Good Luck...thanks for using FixYa.
regards
Graeme(down under)
Posted on Mar 14, 2008
  • 151 Answers
SOURCE: hi i just bought a
Take unit and car to a installer befor you set your car on FIRE.They will be able to put on the right blocks for car and head un it.
CABLE GUY.
Posted on Jul 02, 2008
petraman7
  • 1175 Answers
SOURCE: Lost cable between changer and head unit for CDX-P25
http://www.hermanelectronics.com/HermanStore/homepage.asp
www.vancebaldwin.com
www.partstore.com
Posted on Jan 12, 2009
SOURCE: what color is the memory wire for pioneer deh-3700mp?
to the battery?
or the constant battery wire in your vehicle
Posted on Jan 21, 2009
smarthome2
  • 1114 Answers
SOURCE: What is the orange wire for on the pioneer DEH-2800MP?
If you have a blue with white on it or a solid blue lead, I'm at a loss, however the manual even states that colors may change w/o notice. Best way to tell is to use a meter, black probe to ground and red probe to the orange. Put it on DC voltage then turn the ignition to acc. then turn on the deck, my hunch is that it's your amp remote turn on wire for an external amp or it can be used for a power antenna. Voltage should be 12.2-13.8dcv. Hope this helps
Posted on Jun 24, 2009
Pioneer DEH-3300 UB
Apparently, you have no power at the 12 volt battery/memory wire at the radio harness of the vehicle. This wire is white with blue in color.
Also, based upon your description, you have connected the battery/memory wire and the accessory wire of the radio to the 12 volt accessory (switched) wire of the vehicle. This wire is white with red in color.
Check the radio/ stereo fuse of the car. You may have blown the fuse during your installation.
You have no memory at the radio because when you turn off the key, you lose all power to the radio.
Also, I mentioned the wire colors just in case you used an aftermarket radio wiring harness. Make sure that the yellow from the Pioneer unit is going to the battery power source and, the red of the Pioneer is going to the switched power source.
Sep 12, 2012 | Pioneer Car Audio & Video
I need to know what wires are for what on my Pioneer Head unit model number deh-p2900mp.
black=negativered=live yellow is for memory witch should be conected to a permenent live blue is for electric areal and the rest are for speakers
Apr 04, 2011 | Pioneer DEH-P2900MP CD Receiver...
Pioneer DEH-P390MP will not turn on
Check the fuses in your car and on the head unit first, and then check for 12 volts to the power wire and acc wires. Check your ground wire for an open line. If everything checks out, it may be time to invest in a new head unit.
Jan 18, 2011 | Pioneer DEH-P390MP CD Player
My head unit pioneer DEH-2100ib does not memory after swichoff
the connections between the unit and cars battery are wrong!you must connect the yellow cable with the continuous battery+ cable and the red with the acc switched battery+cable.there is already made adaptors.try to a local accesory shop.tell the brand and model of your stereo and the model year and brand of your car and they must have the right stuff for you!
Jun 06, 2010 | Pioneer DEH-2100 CD Player
Aux location on head unit of pioneer deh-p7500mp
there should be two aoxzilurey wires on the back you stereo red and white! plug in your male wire to the female on the back of your stereo
Feb 23, 2010 | Pioneer DEH-P7500MP CD Player
I own a Pioneer DEH-9650 and want to connect Apple ipod touch.
Hi I was wondering were can i buy any one of these head units, i really want the Pioneer Deh-p9650. but i cant not find one place were i can buy it. i usto have the 8400mp like 6 or 7 years ago but i sold it and now i want a nother 1... i would really like to buy the Pioneer Deh-p9650mp so if any one can point me in the right direction i would be more then greatful.
thanks
DEH-P9650MP ??
Sep 14, 2009 | Car Audio & Video
Cannot eject or turn off power on my pioneer deh-p8600mp
when you take the unit out of your car and looking at the top of the unit there are two black screws. Remove those then remove the entire cd player cage by the 4 CHROME screws on the four corners of the cage the two in the front are in the two holes in the ver front (**use magnetic screw driver for this**) then disconect the two wire plug and the ribbon cable from the bottom of the cd player cage **BE GENTLE** there are two black tabs on either side of the ribbon cable. THEY ONLY MOVE ABOUT 1/8TH ON AN INCH using a jewler flat blade screw driver gently slide the clip out to un crimp the ribbon cable then once the cage is removed you can open the face. To open the face there is a white gear wheel on the rightn hand side of the unit you can rotate it with your thumb with a little effort. Rotate accordingly..... at that point you shouldnt have any problem but let my know if you do..
Dec 10, 2008 | Pioneer DEH-P8600MP CD Player
Pioneer DEH-P7000BT Car CD/... Problem with installation of USB & microphone
The glovebox is the easiest. I managed to find a "hole" to run the cable through from the compartment to the rear of the head unit. Use a flashlight to help you find possible places to run the cable through. Either shine flashlight from glovebox into console or vice versa. Look for where light shines through to find place to run cable. Use a wire hanger to run cable through the hole if it isn't accessible by hand.
For mic, I just removed the drivers side A-pillar trim and placed wire in there. Attached mic to visor. Some wire is visible, but not much.
Aug 28, 2008 | Pioneer DEH-P7000BT Car CD/ MP3 Player
Pioneer DEH 3700 ground problems/system noise
Very common with pioneers. their is a ground loop fuse-located inside the head unit, that has to be repaired at the factory. Or, the best way-just like you said, is to ground the rca's, solder a thin wire to each rca, easiest and cheapest way. I had it happen to me with a 4800.
Mar 23, 2008 | Pioneer DEH-3700MP CD Player
Pioneer deh-40mp
well there is easy to find installation manual and find out for sure... :)
if my memory is good, upper hole is for aux and other beneath - remote...
Oct 13, 2007 | Pioneer DEH-30MP CD Player
79 people viewed this question
 Grubhead
Grubhead
