Question about Zenith XBR716
VHS to DVD
I recorded VHS to DVD, it plays fine on the DVD/TV however it does not play on computer.
    Champion:
  • 221 Answers
Your computer may not have the appropriate codecs. Codecs are basically translators
I would recommend the X-lite Codec package
Posted on Aug 12, 2008
6ya staff
SOURCE:
Anonymous
  • 21 Answers
SOURCE: Connect DVD recorder to Video player/recorder- transfer VHStodisc
hook the video output from vcr to dvd input at rear, then hook output from dvd to tv input. note; you can not record protected vcr movies you can only record tv shows from sattelite to vcr or dvd recorder. its best to record straight from sattelite to dvd recorder for picture clarity.
Posted on Jan 27, 2009
Benimur
Louie Role
  • 6966 Answers
SOURCE: DVD does not play on other players or computer
Hi and welcome to FixYa,
Your description indicates that the last step in the DVD recording has not been performed on these discs that were recorded on the Magnavox. This would be "finalize" or instruct the Magnavox that no other files would be written/recorded on the current disc. Thereafter, the Magnavox would complete the DVD disc making it playable in any other player. Normally, finalization would take a bit of time to complete.
Pls post back how things turned up. Good luck and thank you for using FixYa.
Posted on Feb 02, 2009
nandosnut
Mike C
  • 112 Answers
SOURCE: panasonic dvd recorder wont record or play
It is also possible that you are trying to record using an already used -R or an unformatted RAM disk.
Posted on Apr 20, 2009
Anonymous
  • 45 Answers
SOURCE: Can you record a playing vhs video to a dvd on sharp dv rw250?
Yes, you can do this if you have a VCR that has a channel on the VHS part of the unit that shows your DVD screen (see instruction manual for better explanation). The Sharp unit that you have might have this feature, if not then look at your instruction manual for how to hook up the VCR part of your unit to an external DVD player. Good luck to you!
Posted on Nov 04, 2009
gotograss
SOURCE: plays vhs tape in only black and white (no color).
my old series of ROOTS is playing in black and white and says on cover that they are in color
Posted on Feb 19, 2011
No sound when playing dvd, connection to vhs player
tried to record coming from other tape and replace the audio cord.
Sep 15, 2012 | Televison & Video
Want to record VHS to DVD on my Toshiba DVR620KU but do not want to connect to my TV set. Is this possible? My TV is older and does not have the input/output jacks. I just want to put in a VHS tape and a...
If the entire VHS is full then you can easily transfer the VHS contents to the DVD. The video will play while it is recording onto the DVD, but you don't have to have it hooked up to any TV for it to record. Now if you don't know how long the VHS content is that you want to record to DVD, then you will have to hook up the player to a TV so that you can press stop when you reach the end of the content you want recorded. At least this is true in the way that I use to transfer VHS to DVD:
1) Turn on the unit
2) Insert VHS tape
3) Insert DVD-+R or DVD-+ RW
4) Using remote, press VCR
5)Using remote, press play then pause the tape where you want to start recording.
6)Using remote, press DVD
7) Using the remote, press DUBBING. The VHS should start to play and the DVD should start recording
When using this method, don't hit the RECORD button!
I hope this helps!
Sep 05, 2011 | Toshiba DVR620 DVD Recorder/VCR
Can you record dvd from vhs on a go video DV2130
no its just dvd player you can not record.If still need record on dvd then first input in your computer via tv/tuner card as a audio and video in put.then play vhs and record dvd from computer.
Oct 17, 2010 | GoVideo Go Video DVD/VCR Combo
Plays vhs tape in only black and white (no color).
Jul 03, 2009 | Samsung DVD-VR375 DVD Recorder/VCR
Don't know how to copy video to DVD
blank disk to dvd tray....VHS in deck....PUSH PLAY ON VHS...and RECORD on DVD BURNER....if it is a burner...they weren't all burners....it has to say DVD WRITABLE or some thing in that mannern
May 10, 2009 | Panasonic PV-DM2792 Triple Play 27 in....
VHS to DVD-R dubbs fine: but won't play on SONY DVD player.
Please finalize burned DVD to play in another dvd player.
Apr 16, 2009 | Panasonic DMR-E75V DVD Player/VCR
Getting a dvd player to record vhs to dvd
The RF converter takes the Red/White/Yellow as INPUTS and converts them to either channel 3 or 4. You need to go the other way. You need a tuner or another VCR to convert from RF (channel 3 or 4) to a standard AV signal (Red/White/Yel).
Dan
Mar 19, 2008 | Sanyo VHR-5431 VHS VCR
Can't view DVD's burned from the tv on a DRC8335 RCA DVD recorder
If you do not finalize the disc then you can not play it back. Go back to your instruction manual and look under 'setting options'. There should be a choice to 'finalize disc before ejecting'. The recorder will not finalize a disc until it knows when you are done recording, so you have to tell it somehow.
Jan 02, 2008 | RCA DRC8335
The insigina combo
i would check the tv TO DVD/VHS COMBO connections OR REPLACE OLD AUDIO VIDEO CABLES especially if the tv plays clearly.
Dec 11, 2007 | Insignia IS-DVD1001 DVD Recorder/VCR
Zenith XBR716 Logo
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
