Question about Fujitsu AMILO Pro V1000 Notebook
Amilo Pro V2035 - Broken Headphone Jack Stuck inside Headphone socket
Hi. I am trying to help a friend with this problem. The tip of a headphone jack is broken off, and lodged securely inside the headphone jack. Furthermore in fiddling I managed to unplug the internal headphone lead. I need to get inside the note book to plug this back in. I have had all the screws out, but the note book still dose not come apart. Is there any logical steps for disassembly.
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 94 Answers
Also remove the battery and any other removeable plates below the notebook to check for additional screws. Check if there are any rubberized "feet" or plugs covering access to still more screws. Keep screws and their locations organized in case they are different length.
Posted on Jul 31, 2009
Problems with headphone jack
Replace the headphone socket of the TV. It has contact fault.
Jul 12, 2012 | Vizio M260VA 26 in. HD-Ready LCD TV
Yamaha CP 300 broken headphone jack
Some keyboards use the amp output sockets for headphone use.
You might need some adapters for your headphones.
If it fell in, you would see an empty hole. This would be unlikely because it is held on by two screws. If all fails, buy an amp with a headphone jack input. Plug the keyboard into the amp and use the amps jack.
Dec 15, 2011 | Yamaha CP300 Stage Digital Piano...
( no sound from speaker) i detached the grundig headphnes from my satellit 800 millenium -- the speaker remained 'silent' --otherwise, the radio appears to be functioning normally -- the radio functions...
it maybe that the cut off switch in the headphone jack has stuck as you place in a jack to the headphone socket there is a small switch that mutes the normal speakers and this should switch back on as you remove the headphones, this may have stuck. you will have to open the back and check the back from inside. try to short the mute and see if that is the problem. maybe squirt a small amount of contact cleanrer spray in the jack hole and insert and remove the headphone jack a few times this may resolve.
I hope this was helpful
Dec 12, 2010 | Grundig Satellit 800 AM/FM/SW Radio
My headphone jack broke inside of laptop how to
Unfortunately this can only be repaired by a shop.
Oct 30, 2009 | Acer Aspire 3050-1733 Notebook
How do I fix a bad connection with the headphone jack on my ipod touch? When plugged in, the music is static-y. It is definitely the headphone jack that is the problem.
Hi, this seems to happen on a lot of mp3 players , usually when you wiggle the headphone in the jack the sound cuts in and out, its the result of the headphone jack bending the metal contact inside the player or can be due to a build up of dirt/ grime in the socket.The problem generally gets worse as time goes on
if you have tried it with different headphones still get the problem and its still under warranty I would get on the apple site or down to you local apple centre and try and get a replacement.
Sometimes a spray of deoxit (plastic conductive lubricant /cleaner)
in the socket does the trick , but I would strongly reccomend trying to get a replacemnt
Jul 23, 2009 | Apple iPod touch
I need to dismantle the HP IQ770 to get at the 3.5mm headphone socket on the front - I have opened the casing and can remove power supply, HDD and DVD Drive but no obvious way to get any further without...
I too needed to get to the jack. We broke the tip off inside. I could not get to the jack, but I did find the plug for the front jack on the board. Unplugged it and the speakers worked fine, and the headphone worked off of the rear speaker jack (green).
Jun 24, 2009 | HP TouchSmart IQ770 PC Desktop
Amilo Pro v2065 shuts down when battery is plugged
you need do check:
1) no charging means adapter input problem, first check your adapter DC output voltage is ok
2) check DC jack socket on the motherboard:
--- DC socket any pin disconnected, you need use iron and flux to fix it
--- DC socket damage(broken),you have to change it
3) if DC socket connection normall, the DC/DC circiute near around DC socket some component damage, you need find a technacian to repair.
hope help you to deal it well
May 14, 2009 | Fujitsu Siemens AMILO Pro V1000 Notebook
Headphone jack broken speakers wont work
Yes, since the Headphone pin is stuck in the Jack, you are not getting audio from Speakers.
You should have noticed that connecting the headphones to the Jack will block the audio coming from the Speakers and the same is the current situation.
You can either try removing the blocked part using a Tweaser or get it repaired.
Jul 31, 2008 | HP Pavilion dv9000z Notebook
HEADPHONE SPEAKER WIRING
try using colored wire with the copper....colors act as sound carriers and copper acts as power only connect the copper one with ONly 1 color tho .......just try having everything on and just touching the wires together before sodering
Apr 05, 2008 | Hitachi DZ-MV730A DVD Camcorder
Fujitsu AMILO Pro V1000 Notebook Logo
449 people viewed this question
Top Fujitsu Computers & Internet Experts
Alun Cox
Computer Links
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
