Question about Sharp AR-M277 Black and White Copier
Knocking noise i have a sharp ar-m277 and when ever it prints or copies it makes a knocking noise. what could this be?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Sharp Master
  • 1,362 Answers
Sounds like the developper
it may start to stiffen up.
remove the developper (toner cartridge and try turning the gears by hand, if it's practically impossible to do) replace.
Posted on Aug 12, 2008
Light copies
Clean the optical part components:glass,mirrors,lens,and change PC Drum.
Aug 13, 2012 | Sharp AR-M277 Digital Copier Copier
Due to a power surge, my Sharp AR-M277 won't turn
There is a 20A fuse on the AC power board it is most likely blown. Follow the power cable to the board the big white ceramic fuse is the main, check continuity with meter and replace.
Sep 02, 2011 | Sharp AR-M277 Digital Copier Copier
Our sharp ar-m277 is a network printer and my pc is the only one not able to print from it. this problem just happened out of nowhere. I have tried everything I know to fix it. Any suggestions?
check the network ip of ur computer .is it on network or not.if not then u have to check the LAN port of ur pc as it may be fried.sometimes it happens.then u can add a lan card to make it work ,not costly .
but first check ur ip.
Aug 15, 2011 | Sharp AR-M277 Digital Copier Copier
Does a Sharp AR-M277 use 1 or 2 bags of developer?
Hi, the Sharp AR-M277 takes 1 bag developer (type AR-271MD).
Jan 05, 2011 | Sharp AR-M277 Digital Copier Copier
How to scan a document using a Sharp copier model number AR-M277.
Requires optional network scan kit. When installed it comes with software for scanning
Jul 17, 2010 | Sharp AR-M277 Digital Copier Copier
I am trying to install my ar-m277 on windows vista operating system, and i can't even print
you may need updated drivers for that. check the support for that printer.
Oct 17, 2009 | Sharp AR-M277 All-In-One Printer
We own a Sharp AR-M277 copier, scanner, fax machine that we use on our network. The scanner feature worked great, however, after 500 scans it stopped working. Someone told us that it was just a trial &...
The machine was put in a demo mode for scanning. What you will need to do, is contact an authorized Sharp dealer and purchase an MX-NSX2 kit and that will enable scanning and also purchase you a copy of a program called Sharpdesk.
May 13, 2009 | Sharp AR-M277 All-In-One Printer
Scaner problem
Get a maintenence kit and change the drum.
You could try cleaning the unit 1st
Nov 20, 2008 | Sharp AR-M277 All-In-One Printer
Sharp AR-M277 Black and White Copier Logo
210 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
