Question about Lands Phones
DO I HAVE TO USE A USB DRIVE/MEMORY CARD,OR CAN I JUST USE THE XD,SD,MMC CARDS. MANUAL STATES TO COPY FROM A PC TO YOUR PHOTO FRAME INSERT A USB DRIVE/ MEMORY CARD INTO THE PHOTO FRAME. IS THE USB DRIVE AN ADAPTER FOR A CARD
    Master:
  • 788 Answers
You can use whatever the frame supports and has slots for. If it only has a usb port then you can use a usb drive or get a usb card reader for the card format of your choice.
If you get me the manufacturer and model of frame I may be able to determine what it supports.
Posted on Aug 12, 2008
SOURCE:
I tried to use a 16GB PNYcard in my picture fram and it would not work. It said "No Card" on the screen. What's the answer?
The slot marked SD/MMC/MS/xD is meant to be used for your regular memory card, such as the one you use in your camera. USB flash drives can be inserted into the USB port on the side of the frame.
To select from the various types of memory, press Exit until the memory devices are highlighted at the bottom of the screen, and then use the left and right arrow buttons to select the desired memory type. Press Enter to access the selected memory type.
QsMARTPARtS Technical Specifications Display (480x234) 7 inches TFT full-color Connecting High speed USB2.0 and 2.0 HOST computer Memory Flash memory: 128MB Power supply DC5V 2.0A-2.5A I AC ADAPTER Picture format JPEG Music format WMA Video format MOV / AVI, Motion-JPEG Memory card SD/MMC/MS/xD Language English, Spanish, French selection Control mode Remote control Supported Windows ME/2000/XPNista operating systems Warranty Smartparts, Inc. warrants its digital picture frames against manufacturing defects for a period of 90 days from date of purchase. For warranty claims, please visit our web site at www.smartpartsproducts.com or call 1-888-796-2749.
Smartparts Digital picture frame 7 User Manual
Nov 22, 2016 | Photography
Tip
Downloading picuters directly from your digital camera SD or XD card.
You can purchase a Targus card reader from Walmart which will plug into a USB connector on your computer. Directions on it's usage are included with the card reader. The package says it is compatible with SDHC SD/MMC, XD, Memory Stick, Pro Duo, and Magic Gate.I ran into a problem with the Targus TGR-CRD25 when trying to read an XD or SD memory card 1GB or bigger. Targus fixed it with a note on their web site: To operate plug card reader into
the USB port, go into "My Computer", click "Removeable disk drive", insert your memory card into the card slot and upload your data. Please remove your memory card before disconnecting the card reader.
on Dec 04, 2009 | Cameras
How do i download pictures to tablet
Pandigital photo frames are an ideal way to display your collection of digital photos. You can view photos with or without a computer using just a memory card, but it's always a good idea to transfer the photos you'll want to view frequently to the internal memory of your frame. This is also a handy way to back up your favorite images.
  1. Transferring Photos from a Memory Card
    • Your digital photo frame's built-in software will recognize six types of memory card: CF I/II, SD, MS Pro, MMC and XD. Locate the slot on the back of the frame (to the left of the stand) that corresponds with your type of memory card. These are labeled as follows: SD/MMC/MSPro/XD, CF I/II, USB and mini USB. Insert your memory card into the appropriate slot, power on your digital frame, and it will automatically begin a slideshow using every available image on your memory card. Note that only JPEG formats under 16 megapixels are compatible.
    Transferring Photos from a PC
    • Use the USB cable that came with your frame. Connect the mini USB end to the mini USB port on the back of your frame; connect the large USB end to your computer's USB port. Double-click the "My Computer" icon on your desktop or in your Windows "Start" menu. You'll see that your computer has automatically assigned a drive to your digital frame---look for a device called "Removable Disk" followed by a letter (Removable Disk E:, for example). This is the folder that represents the internal memory of your digital photo frame; you will be dragging your photos into this folder.
      Next, open the folder in which you store your photos ("My Pictures," for example). Select the photos you want to transfer to your frame. Drag them to the drive associated with your digital photo frame---this is the "Removable Disk" drive you located within the "My Computer" folder. Every photo you selected will then be copied onto your digital frame.
      After the files are copied, disconnect your digital frame properly. If you don't, your frame's internal memory could be damaged. Look for the system tray in your desktop's lower right-hand corner. Left-click the icon that shows a gray box with a green arrow on top of it. Select "Safely Disconnect Hardware." A dialog box will appear, asking you to select the device to disconnect. Select the digital frame and click "OK." When the dialog box appears, click "Close." You'll see a message in the lower right hand portion of your desktop telling you it's safe to disconnect your frame.
    Copying Photos to Your Frame's Internal Memory
    • You can use your frame's remote control to copy photos from your memory card or computer to the photo frame's internal memory. Connect your photo source (computer or memory card) and have your frame's remote control handy. Access the "Home" screen on your frame using the "Home" button on your remote control or by pressing the "Home" button on top of the frame. Next, choose "Photos" and press "Enter." You'll see all your photos in thumbnail form. Scroll through them with the up and down arrows. Press the "+" key to mark photos you want to copy (use "-" to de-select a photo). When you've selected all the photos you want to copy, press "Set Up," then "Copy Photo," "Enter," "Selected" and "Enter." A dialog box will ask you to confirm your selection; with the cursor on "Yes," press "Enter." The photos you selected will be copied to the frame's internal memory.
Dec 04, 2011 | PANDIGITAL 7270FW Tablet
How to load pictures to the frame
place images etc in any of the following formats
Supporting formats: jpeg,exif, mov,avi,mpeg1,mpeg4.
on one of the following cards,
Supporting cards: SD,MMC, MS,xD, CF,MD.Remote control. USB, 128Mb integrated memory.
or via usb cable onto the intergrated memory
when connected to pc and switched on will show up like a new harddrive or stick.
move pictures to this drive and they will be on frame internal memory.
or move images etc to sd card or usb stick,
insert card or stick into relevent slot or port on frame and switch on
images should be able to be viewed.
I hope this was useful.
Jan 24, 2011 | Kodak EasyShare SV811 (8858946) Digital...
I have a digital photo frame Coby DP-5588. I bought a sd card Kington 4GB when I insert the card in the photo frame appears a message "wrong Card" and it doesn't read the card content. What can I...
Your 4GB card is actually an SDHC card, not an SD card. While SDHC cards will fit into SD slots, they are electronically incompatible and will not work. You need to use an SD (or MMC or xD or MS), 2GB and smaller.
Dec 05, 2010 | Coby DP-5588 5.6-Inch (4:3) Clock &...
Have a aspire 5735 laptop need to know how to insert sd compact flash disk
If your laptop does not have a built-in memory card reader then purchase an USB multi memory card reader that can read a variety of memory cards such as SM/XD, SD/MMC and CF/Micro drives memory cards.
All you need to do is plug in the memory card into the card reader and then plug the card reader into the computer's USB port. The computer will see the memory card as an external memory device.
Aug 03, 2009 | Aspire Computers & Internet
Kodak EasyShare SV811 won't read SD / HD card
Compatible Card-Slots : SD/MMC; xD; CF;Memory Stick; Microdrive; USB
You might have too much data on the SD card. Try with less pics onto the card.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Jun 25, 2009 | Kodak EasyShare SV811 (8858946) Digital...
I cant transfer pictures from my PC to a Digital Frame
either transfer to a usb pen or a standard digital card and then insert in photo frame good luck
Dec 20, 2008 | PANDIGITAL (DPF802) Digital Picture Frame
Delete some foto on SD card
Using a Photo Recovery software is your best bet!..Adroit Photo Recovery worked very well for me - Try http://digital-assembly.com/products/adroit-photo-recovery/ Hope this helps
Aug 10, 2008 | Cameras
From cell to Pc
Hi Big Bran,
There are 4 methods to transfer pics n videos from mobile to pc. They are through :
1) Bluetooth
2) Infrared Device
3) PC suite via USB data cable
4) MMC reader. ( memory card reader)
I think u r new user of this mobile phone. For u, I recommend u to use Memory card reader. It is very easy and fast.
Process : Take out memory card of ur mobile and insert in the MMC reader. ( It is easily found in the market and they provide u with adapter like a micro SD memory card to insert ur mini Memory card in it ). Join the MMC reader fitted with ur MMC in PC. Now, it shows a new drive like as CD drives. Now copy or transfer pics or mp3s or videos via it like u do in other drives(pen drives, floppy drives).
I think u may have mini Memory card. For it to be fit in MMC reader, u need a small casing adapter which is like a micro SD memory card. INsert ur MMC in it, and ur drive will be shown.
Looking for ur kind feedback,
SAJAN ([email protected])
May 05, 2008 | Motorola Mobility RAZR V3
Lands Phones Logo
53 people viewed this question
Top Lands Phones Experts
Ekse
Marvin
Marvin
Are you a Lands Phone Expert? Answer questions, earn points and help others
