Question about Bunn GR10 Coffee Maker
Coffee pot leaking
My new coffee pot leaks, I think Bunn wants to go out of business. I have gone through 3 pots in like 3 years, I can't afford to keep trying thinking they will be as good as they once were. And they sure were good a quit a long time ago. I hate the mess, but refused to buy another, and now they made them I believe even less friendly for one to work on them at home as far as fixing the leaking.
  • 189 Answers
Your brewer has a 3 year warranty. If you will call customer service with the model and code date and it is less than 3 years old, we will replace it with a new machine at no cost. If it is over 3 years old, we will replace it at a reduced price.
Posted on May 19, 2010
Bunn coffee maker only gives half a pot of coffee
VPR has a semi-sealed tank that keeps +1 pot of water heated and ready to brew. Pouring in a full pot of cold water will fill the top tray and allow a slow trickle of cold water into the top which forces hot water to over flow into the brew basket. This continues until all the cold water drains into the heater tank. So the brew is matched volume per volume. UNLESS the tank was empty or not filled prior to brewing. Follow the brewing instructions from Bunn (on line for *FREE* download at Bunn.com)
* If it leaks (from the bottom) only when you pour in water. Then your pouring it too fast and over flowing the fill tray. slowdown, watch the level in the tray. do not fill past the lid.
* If it leaks just sitting (not brewing) then there is a hole in the tank. Call for service.
* If it leaks after filling the tray half way. then the top of the tank has a leak, loose, cracked, or missing gasket. There is quite a few gaskets on the lid. Call for service.
* Final; Leaks are always bad around electrical equip. Best to unplug and call for service to be safe.
Aloha, ukeboy57
PS, Check the pots in the office. Make sure they are all the same size. Decanters come in 3 sizes; 10 cup, 12 cup (standard), and 3L (3 litters). Check the decanter brand as each brand is a bit different in size. All metal decanters are usually very small (8 cup). What ever size you use, just make sure they are all the same.
Mar 08, 2013 | Bunn VPR Coffee Maker
I have had my Bunn for 5 years and have loved the convenience of the 3 minute coffee, plus the coffee is always great, but for the last 6-8 months it has been leaking from the bottom. I go to work very...
Most likely the problem is in the water intake area. I have the same problem, I took my machine apart, removing the top revealed a plastic water chamber which leads to a connector that lets the water go into the heating chamber. The seal had become brittle, and the plastic water chamber also was degenerating where it met the heated water chamber. I replaced the rubber seal and that worked the first time, however, I think the plastic has now deteriorated to the point that I will need a new reservoir piece and a new seal. It's probably time to send in the unit for repair.
I think one repair for a 25-30 year old coffee maker sin't such a bad deal!
Feb 14, 2010 | Bunn NHB Coffee Maker
My bunn coffee pot is leeaking water out the
Please get the model and date code located on the bottom of the brewer. The machine has a 3 year limited warranty. If the machine is 3 years or less, the machine will be replaced at no cost. If it is over 3 years, then it can be replaced at a reduced cost.
Nov 08, 2009 | Bunn NHB Coffee Maker
My bunn coffee maker is leaking water out of the
Please get the model and code date located on the bottom of the brewer. The machine has a 3 year warranty and if it is 3 years old or less, it will be replaced at no cost. If it is older than 3 years old, it will be replaced at a discounted price. Once you have this information please call customer service.
Oct 24, 2009 | Bunn NHB Coffee Maker
Bunn coffee maker leaks all over the counter. What
there's probably a 'silicon rubber' hose that feeds hot water to the 'grounds basket'- it may be loose, or damaged. is it leaking water, or coffee?? we have a bunn 8-cup, which has a pre-heated water tank that brews a pot in about 3 min. energy waster, but when you need coffee, you need coffee!!! is your filter holder properly centered? is the carafe lid hole clean and un-obstructed?
if it's leaking water, and not too costly to replace- you may consider replacing it with a new one!
good luck!
Oct 09, 2009 | Bunn GRX-B Original 10-Cup Home Coffee...
My Bunn coffee pot leaks water theres always a puddle of water under the pot.coffee pot is over half full
It sounds like you have a broken seal/gasket. Please get the model and date code located on the bottom of the machine and call customer service. The machine has a 3 year warranty so if it is 3 years old or less, it will be replaced at no cost. If it is over 3 years old, it will be replaced at a discounted price.
Sep 13, 2009 | Bunn NHB Coffee Maker
Leaking a half cup of water from the bottom while brewing
Call bunn for replacement gasket free of charge per recall.
Jul 13, 2009 | Bunn 10 Cup Home Coffee Brewer
Bunn thermal coffee pots not keeping coffee hot
If might not be the thermal pot, it is possible it is the machine itself. If you have a candy or meat thermometer, place it in the pot as soon as the coffee has completed brewing. The temperature should be at 175-185 degrees. If it isn't, then the machine needs replaced. If the temperature is correct, then please call customer service with the model and date code to get the thermal carafe replaced. If the temp isn't correct, and it is 3 years old or less, the machine will be replaced for no cost. If it is over 3 years old, it can be replaced at a reduced price.
Jul 12, 2009 | Bunn Coffee Pots: Thermal Carafe
Bunn Coffee Pot Leaks Water
I obtained Bunn washer seal repair kit from buy-it-now-store.com for $6 plus $7 S&H and it solved the problem.
Mar 06, 2009 | Bunn NHB Coffee Maker
Bunn Coffee machine only makes 1/2 pot
What's happening is that it isn't leaking, it's boiling over. You need to turn down the thermostat under the top lid. Also, before you brew coffee, add water to the tank and let it pour into an empty pot. Once it stops brewing, let it heat up for a few minutes then make your pot of coffee.
Jan 02, 2009 | Bunn Pour-Omatic Coffeemaker, 10 Cup White
Bunn GR10 Coffee Maker Logo
69 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
gbob59
zimcloud
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
