How do you fit a replacement slimline dvd disc drive
  • 94 Answers
Assuming your talking about a drive for a laptop, it is fairly easy.
Make sure the tray is ejected then flip the machine over and look for the retaining screw for the drive, this is usually located central, about 5" from the edge of the drive, unscrew it and put the screw in a safe place.
Use the tray to pull the drive from the bay, you may encounter a very small amount of resistance, just give it a bit more pull.
When the drive is out, you will see a small bracket attached to the end of the drive. You need to remove this and screw it onto the new drive. Match up the holes on the new drive by using the old one as a guide, (there may be several holes on the new one) ensure you put the bracket on the right way up.
The front bezel will also need to be removed from the old and fitted onto the new drive -- NOTE not all bezels will fit, you may have to stick with whatever came on the new drive!
Now slide the new drive back into the laptop bay, again a bit of resistance may be felt, this is where the connecters meet, just give it a firm push.
Replace the retaining screw. Flip machine back over and power on the machine.
Providing you have not done anything wrong the machne will boot up and recognize the new drive. Carry on as normal.
Hope this helps.
Posted on Aug 13, 2008
How do i connect an AD-7710H to USB?
You can purchase a SATA to USB converter from a number of web sites, but it would be just as cheap to buy an external USB DVD writer.
Jan 18, 2014 | Sony Ad 7710h Internal Dvd Writer Dual...
Bought a Targus slimline usb dvd player to attack to my acer netbook. It will not play any dvd's. It keeps saying my disks may be corrupt. What do I do?
There is either a problem with your discs or the targus unit so first:
put in a disc and if it says that it's corrupt then take it out and try to play it in something else that you know works.
Then if it does play, it's the targus unit's fault. If it does not play then your discs are bad.
May 10, 2011 | Targus 8x External DVDROM Drive External...
Console work but disk wont spin for slim ps2
The most common reason for the games not reading discs is a bad drive. The following website sells the drives and does installs:
This drive should fix any reading issues you are having with your games, or issues inserting your games or ejecting them (or lack thereof). This is the entire DVD drive assembly mechanism replacement for your game including a new laser. If your discs are not ejecting, or you cannot insert a disc -- or you can insert a disc but it will not load, this is what you need to get your game going again!
Take care.
Aug 20, 2010 | Sony PlayStation 2 Slimline Console
The disc can not be read
You need to replace the dvd drive laser. Remove the old laser and find the model number. It should be something like 400-b. Search ebay.
Nov 03, 2009 | Sony PlayStation 2 Slimline Console
My HP s123w Slimline Pavilion will not start up. Every time I turn it on, it goes to a black screen stating "DISC BOOT FAILURE, INSERT SYSTEM DISC AND PRESS ENTER" and I do not have the system disc. Any...
Take the floppy disk out of the drive... this sounds like the classic error when the boot order includes the floppy disk first, and a blank or data (not bootable) floppy diskette gets left in the drive.
There could be another type of drive set as bootable. CD's and DVD's don't normally do this - they usually cause a prompt "press any key to boot from CD..." or similar.
You could go in the computer setup and set the hard disc drive to be the 1st in the boot order and also solve this problem.
Otherwise could be your C: drive got damaged somehow. Virus or otherwise.
Jul 07, 2009 | HP Pavilion Slimline S3123W Desktop PC -...
Makes sounds'lazer disk ain't working dosnt spin
if this happens with more than one disc, your dvd drive is burnt or about to burn you may have to replace the drive.
May 05, 2009 | Sony PlayStation 2 Slimline Console
Features of PS2 slimline.
Jan 13, 2009 | Sony PlayStation 2 Slimline Console
Mini dvd-rw slips off place in player
You have a possible few reasons why your machine is not seeing your disc:
1. Your machine can't hand;e the smaller size disc. Even though there might be a "spot" for it, it does not guarantee the machine is designed to use it.
2. Is "DVD-RW" supported on your machine? Was the session "closed" when the disc was burned? If it is in "multi-session" your PC might not be able to read it.
3. What is your burning software? If you're using just the OS "burner software", might I suggest something else that does the job like Nero, Alcohol 120%, or other software that stated it can read/write your needed format.
Dec 02, 2008 | HP PAVILION SLIMLINE S7520N AMD Turion 64,...
Slimline disc will not spin
See man u have taken it from a wrong person go back to him and return him the ps2.................
Aug 09, 2008 | Sony PlayStation 2 Slimline Console
Im clueless
This sounds like a problem with the DVD player drive and laser. The Drive chip on the slim can overpower the lasers focus and cause heat to build up around the lasers lens. This does absolutely melt the laser lens and its mount. I suggest you replace the entire DVD drive.
If you are not comfortable doing this, click on "Repair Directory" at the bottom of this screen. On the next page, Click on "Video Game Consoles". Select a good Repair shop.
Dec 15, 2007 | Sony PlayStation 2 (PS2) Console
Computers & Internet Logo
49 people viewed this question
David Payne
David Payne
