Question about HP 1020 Plain Paper Thermal transfer Fax
HP fax 1020
When receiving faxes, must always manually guide paper through. Otherwise, roller will not catch paper and error message flashes load paper at which point I depress start button and hand feed it in......does this roller need to be replaced due to the loss of friction? Please inform. Thanks.
WWR
    Renaissance:
    An user who is expert in 3 categories / brands.
  • HP Master
  • 1,362 Answers
Try cleaning with alcohol if it doesn't work then yes it needs to be replaced
Posted on Aug 12, 2008
Hi there, I have brother 1020 fax and clients are
No, the scanner block is defective. I think it's time for a new fax machine.
Apr 18, 2010 | Brother FAX-1020 PLUS Plain Paper
HP laserjet 1020 fax incoming fax, machine
hp laserjet is not a fax.It is only a printer.
Dec 09, 2009 | HP LaserJet 1020 Printer
PULLING THE PAPER IN WHILE FAXING OTHERWISE IT WONT WORK
it is a dust problem on the pinch rollers which dragin and roll the paper out.
a servicing is required . please also try to load more paper as some times the more paper you load , the easier the dragging in of paper is
single paper inserting for a fax gives such problems . also quality of paper for fax must be the one recommed by the fax company ..using another quality paper will make the paper jam.
datarecoveryfactory
Sep 06, 2009 | Panasonic GigaRange KX-TG2432 Cordless...
Busy, try later error won't go away
depending what rollers and how you did it, you probably have 'spun' a clutch out of position so it can't find it's 'home" position, and keeps on trying. If it worked before cleaning and now it doesn't you've definitely broken or dislodged something like that.
May 25, 2009 | HP 1020 Plain Paper Thermal transfer Fax
Will not fax or copy - Given error light
The thermal roll is basically a roll of 'carbon' like paper that is used to transfer the image to your paper (terrible technolgy, and a massive waste of money for the end user....but that's another story)...it likely needs replacing -it's only good for 300-400 pages.
Feb 24, 2009 | HP 1020 Plain Paper Thermal transfer Fax
Toshiba Super G3, e-Studio 170F
Fax display screen always reads, "Auto receive". When attempting to fax, the busy light flashes. Busy light stops flashing for 30 seconds, then starts flashing again.
Above is the default settings for the fax.
NGB0 indicates signal error or line condition error.
U need to check the phone line. U can hook any single line phone to the phone line, check for tones without background noise.
Sep 10, 2008 | Toshiba e-Studio DP170F Plain Paper Laser...
Hp fax 1020 will not feed paper in
About to junk my hp 1020. Has not fed paper for some time. Used to do it one at a time by hand, but now won't at all. Any suggestions?
Aug 28, 2008 | HP 1020 Plain Paper Thermal transfer Fax
HP 1020 fax
From manual: Insert document; press Scan & Fax button; dial number; press Start/Copy.  All pages will be scanned, number will be dialed, and scan will be transmitted.  If Memory Full displays, repeat procedure without using Scan & Fax button.
Jul 15, 2008 | HP 1020 Plain Paper Thermal transfer Fax
Can't print faxes due to error messages
Please check rear door area for paper, can you use manual feed slot? Power off machine with all jams removed and paper loaded, then power on, can you tell us exact error message/lights that are shown in this state?
Oct 15, 2007 | Brother IntelliFax-2820 Laser Fax
I can neither send or receive faxes
hi 003 - Recording paper jammed when feeding from the 3rd cassette. Remove the jammed paper. (1) Open the Printer Cover. (2) Remove the jammed paper. (3) Slide out the Paper Cassette. (4) Remove the jammed or wrinkled paper and reload the recording paper into the paper cassette. Caution: Make sure that the paper is set under the clips of the Paper Cassette. You can load about 500 sheets with standard weight paper (20 lb. or 75 g/m2). good luck
Feb 23, 2006 | Panasonic Panafax UF-885 Plain Paper Laser...
HP 1020 Plain Paper Thermal transfer Fax Logo
182 people viewed this question
Ben Johnson
