I am having a problem with quality on with my VOIP, Avaya phone. My upload speed through cable modem is over 2000kbp/s. Would this quality lie with Avaya or my cable modem for some reason?
  • eric_barajas Aug 13, 2008
    No using xp on desktop....
    Problem Solver:
  • 6 Answers
Are you using vista? my friends sound quality is really bad when using teamspeak
Posted on Aug 12, 2008
  • Anonymous Aug 13, 2008
    it could be transmit rates between your pc and the "internet". vista automatically optimises this. the way i've been using to find out if mine are wrong is using pcpitstop.com and either using full tests (also gives recommendations to other options) or to just do the internet test. when complete you are required to access the registry to change the setting.
    are you plugged straight into the modem with the phone?? or via pc?
    the above would only work if plugged in via pc.
    i can get good sound quality using normal GPRS which is about 4kb/s! i would say that it would be with the phone as opposed to the modem.
SOURCE:
Tip
How to reset your VOIP modem
If you are having trouble connecting to the internet, please try these steps.<br /><br />1.Unplug the power to your modem. This is the box from your cable or DSL provider. <br /><br />2.Unplug the power to your VOIP phone adapter. If you don't have one skip this step. <br /><br />3.Unplug the power to your router. Wait 45 seconds, then Plug in your modem and wait for lights to stabilize on a specific pattern. (Usually takes about 1 minute) <br /><br />4.Plug in your VOIP phone adapter (if you have VOIP service) and wait until you have a dial tone on your phone again. If you don't have VOIP or know what VIOP is, skip this step.<br /><br />5.Plug in your VOIP phone adapter (if you have VOIP service) and wait until you have a dial tone on your phone again. If you don't have VOIP or know what VIOP is, skip this step. <br /><br />You may need to restart your computer for this to work :)<br />
on Mar 16, 2011 | Computers & Internet
Avaya 5610SW IP is this a voip
Yes it is...
Here is a user guide if you need:
http://support.avaya.com/elmodocs2/ip_office/R3.2/5610_user.pdf
But this set is only good on your network unless you have programming to make the set work outside the network, this is done via VLANS which then the phone can be anywhere in the world so long as they have a high speed internet connection.
Sep 11, 2009 | Avaya 5610 IP Phone
Unnatural voice quality
I think you answered your own question. DSL is not going to be very condusive to an IP phone.
Go to www.speedtest.net and see what your upload/download speeds are, my guess is there isn't enough bandwidth for the home data and voice....
Mar 22, 2009 | Avaya 4610SW IP Phone
DSL loses signal during VOIP call.
hi,
i worked for verizon for two years and I encounter this problem many times,to tell you honestly,its not with you internet connection since if you'll notice,while you are connected to the internet and you make a call or call someone,its interrupted... Obviously,its the phone itslelf,the signal comng from the phone is different from the signal of the internet...thats the reason why you need a modem to convert the signal coming from the phone line to make it work for internet,,,what I suggest is you change the DSL plan from the Dry Loop to the regular dsl with the phone...
thanks and God Bless
Mar 20, 2009 | Westell Wirespeed LiteLine 6100...
MagicJack VOIP sound cuts in and out
Unfortunately you tend to get what you pay for... I have Cable and speedtest at 20mbps / 6mbps im running an athalon II black ed 3.1 overclocked and even with my torrent client down it still breaks up my voice..... VOIP SUCKS..............................
Feb 22, 2009 | Lands Phones
Connect fax from 6210 to phone via cable modem (VoIP)
In Order to use a Fax functionality of the router you need to connect the small RJ11 cable for telephones on the printer port. These printers do not suppoer VOIP Fax. To use VOIP as fax you can purchase a online VOIP subscription where you can scan and fax the documents.
Feb 04, 2009 | HP OfficeJet 6210 All-In-One InkJet...
Download's speed
Speakeasy — Speed Test Test your internet connection speed!go to:
http://speakeasy.net/speedtest/
Speed Test — About Broadband Speed Here's some information to help you understand your results. There are a lot of things that factor into your speed test results. Download and upload speeds, backbones, networks, latency, ping times, and DNS servers.
Download
Download is a measure of how fast your connection delivers content to your computer or local area network.
Upload
Upload is the measure of how fast content is delivered from your computer or local area network to others on the Internet.
To achieve optimal delivery of T1 or SDSL services, download and upload speed should match or at least be very close. This is very important for applications like VoIP, email, on-line gaming and other interactive programs. Upload speed is even more important if you are operating an email, web or file server at your location.
Kbps
Kbps transfer rate = kilobit per second transfer rate. There are 8 bits in a byte, so we would divide kbps by 8 to get KB/sec transfer rate.
Apr 10, 2008 | Conexant Cnet 5614RV V.92 56K Internal...
Webcam
If the image quality is poor while transmitting video over the Internet using video enabled programs such as MSN Messenger, Yahoo! or AOL Instant Messenger, your connection speed to the Internet directly affects the image quality of the transmitted video. Corporate LAN, DSL/cable modem connections will result in the best image quality experience, while dial-up connections may result in choppy and overall poor quality because of the slower connection speed. Even broadband connections such as DSL/cable modem may experience choppy video at times because of Internet traffic or slow upload speeds. If the image appears clearly in the camera software, most likely your Internet connection may be responsible for the poor image quality in your video program.
Feb 28, 2008 | Logitech Webcam
VOIP will no ring
Just "VOIP Phone" is not enough information to help you. There are many hundreds of different phones, connections, & setups you could have. What type of phone (make, model number)? Is this a VOIP phone connected through a home network, cable modem etc.. for home use? Is it a single line phone connected to a VOIP box connected to your cable modem? Is it a VOIP phone system connected to regular copper phone lines? Are you using a VOIP phone at home connected to a VOIP phone system at work?
Nov 17, 2007 | Lands Phones
Open Questions:
Computers & Internet Logo
42 people viewed this question
Ekse
Alun Cox
