Question about GE Microwave Ovens
MICROWAVE IS TOTALLY DEAD;IT IS GETTING JUICE FROM PLUG THAT IT IS HOOKED UP TO. IT IS COMPLETELY DEAD
  • GE Master
  • 9,098 Answers
A microwave can be dead for many reasons.
It may be the fuse, which is usually located behind the grille or on the floor of the oven behind the control panel or between the door switches.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open.
Then when it cools, it closes the circuit and allows power through again.
When checking thermostats, if it has a hood fan thermostat, that should read open, as opposed to the others, which should read closed.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker (or GFI) when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
You should do a continuity test on the fuse while it's in the holder (with the microwave unplugged, of course) then turn the fuse by hand or take it out and put it back in, then test it again.
If you remove the fuse, then press the meter leads against the ends, it can allow internal contact to be made and make a bad fuse appear to be good.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Posted on Aug 18, 2008
DEAD! No lights nothing.
Appliance is totally dead. No response to any key or lights ...
https://www.ifixit.com/.../Appliance+is+totally+dead.+No+response...
iFixitSep 19, 2013 - Replaced oven cavity thermal cutout - No joy. What could cause total loss of power?? - GE Microwave Oven Monogram Advantium 120.
Notes on the Troubleshooting and Repair of Microwave Ovens
repairfaq.cis.upenn.edu/sam/micfaq.htm
Feb 24, 2015 - On-line microwave oven repair database; The simplest problems; Repair ... Totally dead oven after repair; Dead controller; No response to any ...
Oct 15, 2015 | Microwave Ovens
KitchenAid microwave went totally dead
i suggest you go to wal mart and purchase another one after you check your power outlet with another item before you do replace it or try plugging it in else wjere if none of the suggested things i have said works, i suspect its dead, i know of no one who repairs the things,, due to there usually throw away cheap made to start with,, good luck..
Aug 06, 2012 | KitchenAid Microwave Ovens
Microwave oven is completely dead
i believe you would have to take the entire microwave caseing off to access the back of the plug
Jul 12, 2012 | KitchenAid KCMS2055SSS Microwave Oven
Microwave is totally dead but has power to it.
the kliestron is most likely bad or the stertup solenoid is stuck. also could be the control module needs replaced...
Nov 12, 2009 | Hotpoint RVM1325WW Microwave Oven
Microwave LG LMV1630 st is totally dead after power outage
yes it s a large ceramic fuse and you have to remove the outer cover to access this. it will be on the top of the M/wave frame either front L or front right. Cost is about $40.00
Please rate our help to keep the sevice online
Aug 20, 2009 | LG LMV1630ST Microwave Oven
GE PROFILE SPACEMAKER P/NO 8114-334-730 MICROWAVE TOTALLY DEAD!
Sorry Seanna, but I have been getting a lot of problems with GE microwaves. You can call customer care at 800-432-2737, but out-of-warranty repairs are very expensive. Sounds like your problem may be door latch circuitry which requires service. If your unit is old, consider replacing it as prices are very reasonable.
Ray
Dec 15, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Dead unit
first WAIT sometimes the control board gets wet , it may dry out in a few days and will work again . but while you wait un plug it . a live board thats wet might not last long if powered up ...... if still no good see if the light works . if it does the board is bad if the lights dead too , then theres a fuse inside that may have blown
Jun 13, 2008 | GE JVM1640 Microwave Oven
No Power
My microwave was totally dead. Things I discovered: 1) There is an easily replacable fuse accessed by taking off the top front vent cover (two screws on top, gently massage off) and then the inside plastic grill. UNPLUG before doing this! 2) Pop off two wires on either end of fuse holder for safety. Then pop out fuse and replace. For more extensive help, there is an evelope with a wiring diagram inside the case on the inside wall! Very helpful when diagnosing the surface lamp problem (I forgot to plug the ballast back in when I closed up the bottom).
May 13, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
163 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
