Televison & Video Logo
Posted on May 07, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a panasonic hdtv 1080i. At the bottom of the screen there is a blue curve. Can I fix this?
Anonymous
Level 3:
  • Televison & ... Master 3,459 Answers
  • Posted on May 07, 2011
Anonymous
Level 3:
Answers
3459
Questions
5
Helped
849980
Points
5558
Sounds like a convergence issue. Check the site www.TvRepairKits.com to see if they have the parts for your TV.
Panasonic rear projection 52inch cinema vision 1080i hdtv looks 3D with double vision red, blue and green how do I fix
Replace the convergence chips--should be stk-392-110's in the Panasonic.
I have start to finish free instructions for this repair based on the model number----a email address will get them for free.
2answers
Projection HDTV Pansonic 47" Curving blue and green colors on top and bottom of screen.
You will need to replace your two convergence I.C.s.They are two large IC mounted on a large aluminum heat sink.Replace both,look for any burned resistors near them,replace those if needed,and readjust your convergence. Good Luck
Let me know if you need any further help
2helpful
Convergence panasonic HDTV 1080i bbe hi definition
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
2helpful
Blury screen on panasonic 1080i hdtv
seeing double and a lot of green on my panisonic hdtv 1080i what do i need to replace?
I have a Panasonic HDTV 1080i, We started to experience a yellow and blue arc at the bottom of the screen about a month ago. Last night the picture went black. Only the sound is left. What happened?
The convergence IC's are definitely bad. This is a big repair involving taking out the main board and soldering in two new IC's. They are not plug-in components and you would need a professional to do this job.
Blue lines appeared near lower half of screen
Hello... This sounds like a convergence issue, but I didn't think they made rear-projection TVs as recently as 2013? Also, your post says you have a 32"? If it's a 32", then ignore the following.
If it is a convergence issue, parts will need to be replaced. There are usually two STK ICs and maybe some resistors that can go bad.
I hope this helps!
2helpful
3answers
Panasonic PT-53WX54 curved bottom
its the problem of convergence in the unit that needs to be repaired
for how to repair please click the above link
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
My panasonic HDTV bbl 1080i was purchased about 6 or 7 years ago. The image shows two or three other images from the original image which are florence green and pink. So basically I see a triple image of...
I have a Panasonic PT-47WX53 rear projection TV and the picture was pretty dark for the last year but for game it was OK but know the blue is out of sequence, do I need to change the lamps?
And where to find them?
1helpful
Panasonic HDTV 1080i Lamp out
We have a blue line across the bottom of our screen how do we fix it?
PT-47WX53 blue convergence
you will need to change or have the convergence IC's replaced I'm afraid. Good Luck
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
