The red and green balance is off, how do I fix it myself?
  • 8,617 Answers
I am not sure what youre refering to when you say balance. can you be more specific and also include your model number? Is the pisture 3D looking?
Posted on Aug 12, 2008
Jet 3 Ultra kicking error code 3 red, 4 yellow, 1 green.
check connections to controller, may have damage.
Jan 15, 2016 | Jet 3 Ultra Power Chair
Picture on golden tee is dark red not normal green did revert to green but back to red
Sounds like a cold solder joint. Unless you have knowledge of electronics and high voltage, I wouldn't try to fix it myself. A honest TV repairman should be able to fix it. And when I mean high voltage, I mean 2000-3000 volts is average with a CRT TV tube.
Dec 17, 2012 | Arcade Golden Tee Unplugged Video Cabinet
I fix the red doubling by adjusting the red screen screw now the people are greenish. can someone help me. pt-56wx53g
turning the red Screen down even slightly will make the other two CRTs dominate over red. You may be able to turn the Green and the Blue down slightly to balance them back to what red is at. Turning the screens down too low will cause them to shut off if they get lower than the cut off point.
Sep 15, 2011 | Panasonic PT-56WX53 53" Rear Projection...
My screen keeps losing the red colour
not absolutly sure but it sounds like one of the crt's are starting to fail. Sony has a white balance circuit that constantly will attempt to correct for white balance errors, if it has a hard time fixing the white balalnce what you describe can happen. Durring these events your tv's power button can blink in repeating pattern of 5 blinks indicating an akb or auto white balance error. Eventually the picture may flicker on and off or the tv will shut down all togeter with a 5 blink error. But i cannot be sure without looking at it myself. There are other causes aswell; focus block, or a crt driver can cause simular issues. But given the age of this set i feel it is a better chance one of the crt;s are going bad. But again it could be the other things i mentioned.
May 07, 2010 | Sony KP-43HT20 43" Rear Projection...
Sony trinitron FV-32FS120 picture has an orange tint
THERE ARE ADJUSTMENTS TO THE VIDEO DRIVE THAT CAN CORRECT THIS PROBLEM/THEY ARE IN THE SERVICE MENU. WITH THE POWER OFF, PRESS MENU-5-VOL+ POWER THE SET WILL COME ON IN THE SERVICE MODE. STEP THREW THE MENU ITEMS UNTIL YOU GET TO RED/GREEN/BLUE DRIVE THEN ADJ. TO BALANCE THE COLORS WHEN DONE PRESS MUTE TO STORE THEN POWER OFF ON THE FRONT OF THE SET OR IT WONT SAVE.
Dec 27, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
The color of the picture shows only blue and yellow the red and green just disappeared. Is this a fix I can do myself??
your green is acutally there because you had yellow, so your problem is most likely the RED CRT od Video amp ic on the crt board you should have a tech check it out if it went off suddenly then i would lean mostly to the amp
Nov 30, 2009 | RCA R56WH76 Projection Television
Too much red.
I have a philips magnavox and had two problems that I recently fixed using kits from www.TvRepairKits.com. I can't say enough about their kits and help. Without them I would have never been able to fix my TV set myself.
The first problem I had was the TV was looking 3D. After doing some homework I found out that this is a convergence problem. I bought a kit, followed the instructions, and to my amazement fixed it myself.
After building my confidence with the 1st repair I decided to get their CRT fluid kit. This kit fixes the dull video,red video, or bright/halo looking video. If you have a magmavox set that is more than 5 years old your tv has this problem already. It happens on every set. As before I bought the kit, followed the instructions, and now my video looks factory new. Once again I wanted to say thanks to the team at Tv Repair Kits for putting together kits that the average joe can use.
ML
Jul 27, 2009 | Philips 9P5034C 50" Rear Projection...
Samsung CRT HDTV - Red, Blue, but No Green.
If their is no green chances are the chip for RGB on the tubebase has packed up its usually something like a TDA 6107Q
Jul 06, 2009 | Samsung TXJ3676 36" TV
Hitachi 51f510 Color problem
for testing, place the green crt board on the red crt and see if the red crt lights up and the green does not. If the green does not light up then check for 200+ volts on the collector or the output transistor. if you have that kind of voltage thee then check for an open resistor. If not then make sure the transistor is not shorted
Dec 28, 2008 | Hitachi 51F510 51" Rear Projection...
Toshiba TZ55V61 having prob. w/red,yellow lights
Convergence issue...replace STK392-110 IC's on small PCB
mounted by itself above power supply....................T.
Nov 08, 2007 | Toshiba TZ55V61 55" Rear Projection...
Televison & Video Logo
37 people viewed this question
Top Televison & Video Experts
