Question about Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
Drive belt how do you put the drive belt on a harley davidson 97 sportster
    Genius:
  • 2,028 Answers
You have to drop the swingarm, the belt wraps the arm, so you have to take it loose from the frame in order to get the belt in place. I would recommend a service manual for your bike, for all the torque specs of the components you will need to remove, ie... brake caliper, shocks, swing arm pivot bolt, etc.., and for the rear wheel and belt alignment, and the belt tension. The belt tension is crucial, if it not tight enough you will wear the belt out faster or it will slip, and if it's too tight you can break the belt or spin the splines out of the front drive pulley. I know this from experience, overtightened the belt on mine earlier this summer, was fine with my wieght, but spun the pulley at a ralley with a passenger. If you need any further assistance or have any questions, feel free to ask.
Posted on Aug 12, 2008
Pyrhyc is making you do a whole lot of work for nothing. 1. loosen rear axle and slide wheel forward 2. if you are trashing the belt just cut it off, if reusing the belt, mark the belt and pulleys(front & rear) so as to put back in original wear pattern 3. remove brake pedal pin on pushrod to master cylinder 4. remove master cylinder allens and brake hose keeper on pulley cover 5. remove cover allens and remove cover (depending on exhaust system, you might have to loosen the rear header) 6. remove belt guards 7. remove shock lower bolt and loosen top, swing shock out of the way and tighten down upper bolt 8. the belt can be turned sideways and fanagled around exhaust brackets and such (do not bend belt too sharply or you will damage the cords) 9. after you have threaded it the front pulley, install on rear pulley first then front pulley. 10. re-install what you took off .
now to tighten the belt, have someone sit on the bike to preload the belt and adjust the tensioners equally on both sides until belt will move 1/8 to 1/4 inch pushing at middle between pulleys. after a few hundred miles, recheck tension. a little too tight is better than too loose. if you slip a tooth, the belt is usually history. pyrhyc stripping his hub is only consequental, his hub was loose to begin with. if the slpines are tight, all the loading is equalized and the only harm is adding excessive load to the output shaft bearings which can cause premature failure. i probably have been more abusive to my pulleys and belts than pyrhyc will ever do and no failures to date but proper maintenance is the key. i wonder if he runs up to 60 in first and launches second into the air???
Posted on Aug 30, 2008
Secondary belt
I assume you are referring to the drive belt? If so those are usually good for around 100,000 miles, I'm still running the original belt on my 97. To replace this belt is a big job and would take to long to type out here. If you don't want to buy a manual check and see if your local library has one.
Jun 21, 2013 | Harley Davidson Motorcycles
Change drive belt sportster 1200
Hi Anonymous, I'm sorry you can't find the very first and best tool you ever bought for your Harley Davidson. Despair not, for a mere $6.50 you may be able to download another one from the website below and good luck.
Harley Davidson Manuals Mark Workshop
Jul 31, 2012 | 2006 Harley Davidson XL 1200 C Sportster...
Put on drive belt 2004 1200 sportster
Hi Bob, I'm sorry you can't find the very first and best tool you ever bought for your Harley Davidson. Despair not, for a mere $6.50 you may be able to download another one from the website below and good luck. Harley Davidson Manuals Mark Workshop
Jul 08, 2012 | 2004 Harley Davidson XL 1200 C Sportster...
How to adjust primary chain on 97 sportster
Hi Anonymous, for more information about your question please visit the websites below. Good luck and have nice day.
How To Adjust An Evolution Harley Davidson Sportster or Buell Motorcycle...
Jun 14, 2012 | Harley Davidson XLH Sportster 883 Deluxe...
How to change drive belt 1200 sportster
Hi Zacharyshick, for more information on your question please visit the websites below and good luck:
Mar 02, 2012 | 2000 Harley Davidson XL 1200 C Sportster...
How do I replace the drive belt for my 2003 XLH 1200 Sportster?
Replacing the final drive belt on the Sportster is simple compared to the the Big Twins. All you have to do is disconnect the rear brake master cylinder and take the front pulley cover off. Then take the rear wheel off and the right side shock. Put the new belt on and reassemble the bike. No problem.
Good Luck
Steve
Jun 10, 2011 | Harley Davidson XL 1200 C Sportster Custom...
How to change drive belt on harley sportster 883
Changing the drive belt on a Sporty is a snap compared to a big twin. First you'll have to remove the rear brake master cylinder and pedal or at least take the bolts out and move it out of the way. Remove the front pulley cover. Remove the rear wheel and the shock on the right hand side. You should be able to work the belt off the front pulley and get the new back on.
When you put the new belt on and tension it, make sure you keep the adjuster bolts of either side of the swingarm about the same length. This ensures that the rear wheel is aligned with the swingarm.wd4ity_1.gif
Nov 15, 2010 | 2004 Harley Davidson XL 883 Sportster
After reinstalling rear wheel assy on a 1988 harley sportster 883, it seems to close on one side
Look at the final drive belt. Sight along the belt as you sight a rifle. Does it look straight? If not, have you got any and all spacers in the correct location?
Go to this site, BikeBandit.com, for a drawing of the rear wheel and spacers for your bike. Search under OEM parts if this is not the correct picture.
http://www.bikebandit.com/1988-harley-davidson-motorcycle-xlh883-deluxe/o/m1788
Good luck
Steve
Sep 29, 2010 | 1993 Harley Davidson XLH Sportster 883...
Replace drive belt on 1200 harley
To change the final drive belt on a Sportster is much simpler than doing the same job on a Big Twin Harley.
Support the bike so that you can remove the rear wheel, right rear shock absorber, the belt guard, and the front pulley cover. Take the old belt off and install the new one. Put the bike back together and adjust the belt to have about a 1/2" up and down movement in the middle of the belt with 10 pounds of force applied. Make sure your rear brakes work properly before you ride the bike.
While installing the belt, do not bend the belt in a radius any smaller than 4". Bending the belt too tightly will damage the cords inside the belt and may cause premature failure of the belt.
Nov 08, 2009 | 2001 Harley Davidson XL 1200 C Sportster...
Lands Phones Logo
386 people viewed this question
Top Harley Davidson Lands Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ted dux
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
