I would like to submit a meter reading - Office Equipment & Supplies
  • Anonymous Dec 09, 2008
    Sharp FO-DC535 fax machine
  • Anonymous Dec 22, 2008
    I need to submit the "meter reading" and do not know how to do that? Please help!
    President:
  • 2,072 Answers
I would need the model number of your machine to be able to tell you how to read the meter. Some are on the display and some print out the meter on paper. Can you please let me know what model number your machine is.
Posted on Aug 12, 2008
How do I wire in a amp meter please
amp meters are wired in series in a power circuit
that is to say cut the wire and attach each end of the wire to the terminals of the amp meter
you have to know the amps in the circuit to get an amp meter large enough to read the current or it will burn out
( a 60 amp meter for a 120 amp power wire is not right)
in that case you can get an amp meter that runs a resistance in the back of the unit and as volts and amps are directly related by reading the voltage drop across the resistance the current (amps) can be read
That allows a small amp meter with a high face reading to be attached to a large current wire 10000 amps etc
you can also get amp meters that have a crab claw clip that goes around the power wire and by reading the flux field voltage converts that to an amp reading without touching the wire ( used by electricians to check current draw in electrical motors etc )
Apr 12, 2017 | Cars & Trucks
Hi how to convert to kilowatt hour using this meter? Do we really need to multiply by 20
Yes, you do have do multiply, but not the number on the dial itself. This is a commercial or heavy residential use meter. They are geared so that each kilowatt hour measured by the dial is actually 20 kilowatt hours. This is done since some users use so much power that the meter could actually roll over during a normal billing cycle using a regular meter. So, if you are reading this meter to determine how many kilowatt hours you have used since the last reading, you simply read the meter as you would any normal meter to get the number displayed. Your photo reads 13525. That is your current meter value. If you last bill stated the meter value was 13501, that would indicate that you used 24 (13525-13501) times 20 or 480 kilowatt hours since the last bill.
Hope this helps!
Aug 15, 2016 | Office Equipment & Supplies
Lost password for betterrecipes.com. Tried to submit to them new password. Form not working.
June Media Inc
Customer Service
209 W. Jackson Blvd. Suite 702
Chicago, IL. 60606-6907
(312) 724-9444
Read more: http://www.betterrecipes.com/privacy-policy#ixzz3bwEZVxlA
Jun 02, 2015 | betterrecipes.com
Chevy silverado ecm
There are OBD 1 meters and OBD 2 meters that read codes, if your car is OBD2 you need an OBD2 meter to read the codes.
Dec 21, 2013 | Cars & Trucks
Which category do I type in to find a poem
Not sure if you want to submit a poem or read poems ..
To read try a google search for Find a Poem and you should get the URL
http://www.poemhunter.com/
To submit a poem then try a search "submit a poem" and there are scores of sites like
http://www.we-love-poems.net/submit.asp
Hope that helps and happy reading -- Ray
Jan 11, 2011 | Computers & Internet
I need to fill out a application online and submit it but i dont know how
Go to the web-page that contains the application.
Read the prompts for each field.
Fill-in the field.
Skip to the next field.
Fill-in the field.
Repeat for each field.
Click "SUBMIT".
Oct 27, 2009 | Computers & Internet
Where is the meter on Canon IRC33801 so I can submit the New Meter #s ?
press small button with 123 icon you will see the meter as well as serial number
Jul 14, 2009 | Canon PC1061 Copier
I need to obtain a meter reading for sharp ar-m236. How do I do that?
Simply press and hold the copy mode then you get the meter reading and toner percentage status
Apr 15, 2009 | Sharp AR-235 Copier
76 people viewed this question
jasbo
jasbo
