Question about Compaq Presario Notebook
Computer flickers - Compaq Presario Notebook
Sounds like the connection to the screen is loose. Check online for document to repair laptop. Open and check connection between motherboard and screen
Posted on Aug 12, 2008
SOURCE:
Flickering monitor, but laptop functions fine
Flickering monitor but laptop functions fine
Might be a bad monitor or the wron driver. Check your monitor on another computer, if still flickering, you should take it to repair.
Jun 24, 2015 | Computers & Internet
My lenovo LCD screen is flickering black and striped lines, how to get it fixed in Richmond Hill Ontario
Laptop computers have LCD displays that are sensitive to many things. LCD displays have faults that sometimes produce a flickering screen, lines, dots or a faint display. These screens are sensitive to magnetic fields or electronic items near the computer. Speakers, cell phones, lights and other electrical items are examples. Your display also could be flickering due to software issues such as the video drivers or hardware issues relating to the inverter going bad or the LCD screen itself needing to be replaced. Trace the cause of your problem to come to a resolution.
1.Turn off the computer. Disconnect all external devices. Turn the computer over (bottom facing up). Take out the battery and reseat it. Turn the computer on.
2.Reset your resolution and refresh rate.
Windows XP:
Right click an open area on your desktop. Click "Properties" in the drop-down menu.
Click the "Advanced" button at the bottom of settings tab. Another dialog box appears. Click the "Monitor" tab. Change the Refresh rate to your default, or 60 hertz. Click "OK."
Windows Vista:
Click "Start, Control Panel." Find and click "Appearance and Personalization." Click "Adjust Screen Resolution." Change resolution to the default, or 800 x 600. Click "Advanced Settings." Click the "Monitor" tab. Change the refresh rate to the default, or 60 hertz. Click "OK."
Windows 7:
Click "Start, Control Panel." Find and click "Display" Click "Change display settings" on the left side. Change screen resolution to 800 x 600. Click "Advanced Settings" in the lower right. Click the "Monitor" tab. Change the refresh rate to 60 hertz. Click "OK."
3.Check the computer's surroundings. Move away any speakers, fluorescent lights, fans, cell phones, radios and any other electrical device that can cause flickering. Temporarily move electrical items away from the computer to see if they are producing this issue.
If the flicker stops, put back one item at a time to determine what is causing the problem.
4.Connect an external monitor to your laptop computer to see if that screen is also flickering. If there is no flicker, then the problem is strictly with the laptop, indicating a possible hardware failure. Contact the manufacturer for a replacement LCD.
If the flicker continues, go to next step.
5.Reset/Update your video driver. Click "Start" and right-click "My Computer." Click "Properties." The "System Properties" dialog box will appear.
6.Click "Device Manager." A list of items will appear. Click the (+) sign next to "Display Adapters."
7.Right-click the video adapter and click "Uninstall." Confirm removal. Restart the computer. The video driver will automatically reinstall itself.
8.Check to see if the flicker still exists. If so, go to the manufacturer's website. Download and install the newest video driver and BIOS for the computer.
9.Restart computer once drivers are installed. Continue to the next step if there is still flickering.
10.Open up your display screen all the way. If the flicker stops by opening it a certain distance, it is the display inverter. If the flicker still exists, the LCD screen should be replaced.
11.Contact the manufacturer of the computer for more information and a possible replacement inverter and LCD display. This will depend on the manufacturer and the computer itself.
I hope you find it very helpful. Thanks
Sep 05, 2011 | Lenovo 3000 N200 Notebook
My monitor is flickering
Flickering on the screen can be caused by defective hardware in the computer or by improperly installed software monitor may flicker and goes into rolling state due to dust, overheating after a long continuous usage,loose circuitry or due to some electromagnetic interference with other like tv , UPS, large speaker systems etc.
FIX :
1.Try Re-installing your Video driver
2 If it is possible, connect a different monitor to the computer. If the flickering disappears, it is a fair indication that the monitor is defective, otherwise go to the next step.
3. Set up the computer and the monitor on a different place in your house. If the flickering disappears now, it is most likely an interference caused by something in the original location. Check for devices which can cause interference.
4. If the flickering persists, check the setup of your system. If available in the setup, make sure that the option Monitor Type is configured as Colour Non-Interlaced.
If you don't think any above possible reasons for the rolling or flickering state of your monitor then we recommend you to get your monitor checked by the monitor company at their respective service cente
Sep 01, 2011 | LG Studioworks 700S 17" CRT Monitor
My laptop emachine g720 screen flickering
Windows XP:
Windows Vista:
Windows 7:
I hope you find it very helpful. Thank you for using fixya.com
Aug 19, 2011 | Computers & Internet
Lcd screen is flickering on and off very fast
Disconnect the lcd from the computer. Turn on the LCD and see if it still flickers fast. If it doesn't then go ahead reconnect the lcd back to the computer. If its still flickering, then go ahead and hook it up to another laptop or desktop. If it doesn't flicker on another computer then that means there is a problems with the video card on the original computer.
If it still flickers then that means the lcd is bad and would need to be replaced.
May 31, 2011 | LG L1960TR 19" LCD Monitor
My BenQ G2220HD Monitor flickers. I've tried my level best to solve this problem but could not get rid of the flickering.
Try connecting it to a different laptop/desktop, to see if the flickering "follows" the monitor. If not, then the video-card in your computer is the problem -- try connecting another monitor to your computer, to see if the flickering still happens.
Sep 02, 2010 | BenQ G2220HD Monitor
My computer screen flickers when you start it up what could it be
It is normal to flicker if the computer is turned on (on a cold boot), but there could be a problem on it if it keeps on flickering inside the operating system.
Dec 14, 2009 | Dell E207WFP LCD Monitor
Dell 2005FPW Monitor Flicker problem
The flickering is most likely the florescent backlight having a hard time starting, Just like in a light fixture, as it gets old, it takes longer to warm up to get full functionality.
If under warranty, contact Dell for a replacement, if not, then when it becomes untenable, replace the monitor. Prices are dropping drastically, an new 20 or 22 In can be bought for about $150 or less
Aug 08, 2009 | Computers & Internet
Compaq Presario Notebook Logo
43 people viewed this question
Top Compaq Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
