Question about Lenovo 3000 N100 0768 - Pentium Dual Core T2060 1.6 GHz - 15.4in. TFT PC Desktop
Problem in finger print reader
Unable to enroll in omnipass
I canot work fingerprint
Posted on Sep 27, 2008
How do i use bio metric censer in hp Compaq nc6320
To use the Biometric fingerprint sensor, just swipe your finger across the reader and it should start the enrol program.
See the video on this page Using Fingerprint Reader with DigitalPersona or Verisoft
Oct 10, 2014 | Computers & Internet
In my fingerprint device there but in the application when i go to enroll the my fingerprint data it shows as unable to detect the fingerprint device. pls help me..........
Take it back to where you bought it or contact the manufacturer. I bought a laptop for my boys that was supposed to be new but it was used. The fingerprint function was devoted to the PREVIOUS owner's finger print.
Sep 27, 2014 | Acer Aspire Notebook
Fingerprint reader working but not showing image
From the description it is a software problem, If you were sticking things in the scanner bar that would not help and it will prevent the laptop from working.
Mar 30, 2012 | HP Compaq 6910p Notebook PC PC Notebook
How to program itouchless doorlocks
change master code
0 + * + default/old mastercode + new 8 didgit master code + #
when successful it will make a solid single beep if unsuccessful it will beep 3 times
enroll finger print at random no user ID
1 + # + master code + #
first scan place finger on the scanner and remove when the scanner light turns off
second scan replace same finger when the scanner lights back up you will hear a single beep if enrollment is successful
if scan fails you will hear 3 beeps
Jan 15, 2012 | Itouchless Bm003l Bio-matic Fingerprint...
Please,i need the drivers for my apc fingerprint reader
You can find the drivers here:
ftp://ftp.apc.com/apc/public/software/windows/xp/biopod/
or
go to omnipass's website (www.softexinc.com), go to downloads, trial version. chose omnipass client edition (x32 or x64 whatever u need) Then u check on the Authentec Fingerprint Touch Sensor Module (APC, Fellowes, etc.). Download both, install omnipass first... its a trial i know. Install authentec second, that gives u the drivers. Uninstall omnipass... who needs it if u already got the drivers!
Mar 07, 2011 | Computers & Internet
How do i get my MPC laptop TransPort T2300 Finger Print scanner to work? I tryed runnin my finger across it nothin happend .
Did you enroll your finger print first?
If not, log onto your account, and start the protector suite
go to the passport section, and set up a passport for your account.
Sorry if this isn't very clear, but I don't have the suite anymore, I'm running windows 7 on my t2300
Oct 12, 2010 | MPC Computers TransPort T2300 Notebook
How to setup finger print sensor
When you start a machine with a Fingerprint reader for the first time, you will see the following screen when you reach the Desktop. This is the main console for configuring and managing the Fingerprint reader.
Here you can enroll your fingerprint, and adjust your Power-on security settings.
When you click on “Create new passport and enroll fingerprints” you will be prompted for your logon password.
Once you enter your password you will see the main enrollment screen.
You can select a fingerprint to enroll either by selecting the fingertip with your mouse, or by choosing from the drop down list. To enroll, either double-click the fingertip you wish to use, or press the Enroll button
On the left is an animated finger that demonstrates how to swipe. You must swipe your finger three times to enroll.
If your finger is not centered, you will be prompted to move it to the right or to the left. If it’s not able to read at all you will be prompted to try again.
When you swipe successfully, you will see the highlighted portion go to No. 2 for the finger printer to be swiped again.
Once you have swiped three times successfully, the three images merge into one and you are brought back to the main enrollment screen, where the enrolled finger is shown with a red dot.
  • You can enroll multiple fingers.
  • The Enroll button has changed to say Delete. This allows you to delete a fingerprint you have already enrolled. If you used the mouse to click on a fingertip that was not already enrolled, the button would change back to Enroll.
When you click Next you are brought to the Power-on Security screen.
This is also the second choice from the main Fingerprints enrollment screen. Here you can use a fingerprint to replace your Power-on passwords if you are using them.
If you are using Power-on passwords, then select the box at the top. When you click on the Add button, you will be shown a list of the fingers that you have enrolled, and can select which one(s) you want to enable to replace your Power-on passwords.
Once you select a choice from the box, the finger will show up in the list. The first time you restart your machine after this, you may be asked to swipe your fingerprint as well as enter any Power-on passwords you have set. After that you should only be asked for your fingerprint.
  • Predesktop Authentication
    • In addition to the process above, there is a setting in BIOS that must be enabled for a user to be prompted for their fingerprint instead of a Power-on password. The Default for this Setting is “Enabled”, so no change should be necessary. It is in the Security Section under Fingerprint. The setting is called “Predesktop Authentication” Again, the default is “Enabled”. If disabled, a user will not be able to use their fingerprint on Power-on.
  • Security Mode
    • This controls what password will allow a user access to the system if they are not able to gain access using their fingerprint. The default setting is “Normal”. This will allow the use of either a user Power on password, or a Supervisor password instead of a fingerprint.
      The alternative setting is High. This will allow only a Supervisor password to be entered instead of a fingerprint to gain access to the system.
Once you click Finish, you will be brought back to the main Fingerprints screen.
The Create new Passport and enroll fingerprints choice has gone. Replacing it are two new choices:
  • Edit passport and fingerprints
  • Delete passport and fingerprints.
If you choose Edit passport and fingerprints you will be prompted to swipe your finger to confirm your identity
You will then see the password screen. Click next to go to the main enrollment screen.
This is the same screen that appears when you have successfully enrolled a fingerprint.
Here again you can delete or enroll fingerprints
I trust this was helpful and thank you for contacting the experts.
Jan 18, 2010 | Lenovo ThinkPad X300 Notebook
Fingerprint reader
Hi slipknot123,
it simply means that the software for your finger scanner requires the omnipass password modules before windows allows it to work with its identification and authentication modules.
if your computer came with a built-in finger print scanner, all the drivers and the necessary software for it should have been installed already, you may also check the recovery disk that was given you when got when you bought your computer, tcheck out their site at www.softexinc.com
Hope you have a nice day
Aug 07, 2008 | Lenovo 3000 N100 0768 - Pentium Dual Core...
Fingerprint reader software on lenovo 3000 n100
Hi jerseydeals,
I did a search and found an XP driver from the Lenovo site for your laptop's finger print reader, just follow the link below:
http://www-307.ibm.com/pc/support/site.wss/MIGR-63663.html
Also, the reader is controlled by the OmniPass software, you can check it out from http://www.softexinc.com who developed it and find the version for XP though theere are other software to which you could use that reader as well. Hope this helps
Cheers and best regards,
May 08, 2008 | Lenovo 3000 N100 0768 - Pentium Dual Core...
Lenovo 3000 N100 0768 - Pentium Dual Core T2060 1.6 GHz - 15.4in. TFT PC Desktop Logo
77 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
