Question about Motorola Mobility RAZR V3m Cellular Phone
Simm Card How do I get at the simm card
  • jeffyg867530 Sep 07, 2008
    How do I remove the SIM card from a RAZR?
  • califj123 Sep 07, 2008
    how do I remove the sims card to put another one in?
Desbloquear
Posted on Aug 21, 2008
Camera won't take pictures. Everything shows it is working put when you put Simm card to check pictures no pictures on it. Re formated the card put a
Check the memory card to make sure that it is good and capable of storing picture data. Easiest way is to try another card and see if camera does the same thing. If so then the issue is with the camera's electronics.
Oct 23, 2015 | Cameras
Phone says there is no sim card but its installed.
SIMM card could have dirty contacts, pull out the card and clean the contacts with a pencil eraser used gently and a clean cloth, reinstall. SIMM card could also be from a different carrier than the phone was originally designed for (phone is locked).
May 02, 2015 | Motorola Mobility DROID RAZR MAXX HD
Getting 955 Service Message. Font CFC. What is
this is either caused by a simm card being corrupted or the engine board being bad. remove the simm card to isolate the problem
Apr 13, 2010 | Lexmark Optra T612 Laser Printer
My safelink phone have sribble number&letters when i make a call i need a new phone how do i get it.
There are two ways that you can solve this problem, so here they are.
First Option:
You can call Safelink's Customer Service Number at either 1-800-378-1684 or 800-723-3546 and explain to them what your situation is and have them send you a replacement phone by snail-mail. If you do not want to wait for a new phone to come in the mail, then scrow down to option two. If customer service tries to give you any **** about charging you for a new phone, politely tell them that you wish to cancel your service and that you will use Assurance Wireless instead as Assurance offers 200 free minutes over Safelink's 68 free minutes. More details on Assurance is at http://www.assurancewireless.com/Public/Welcome.aspx
Second Option:
If you do not want to wait for a new Safelink phone to come in the mail and you actually have some money to spare, simply go to any retailer like Big Lots, Wal-Mar or any other retailer that sells the Tracfone Pre-Paid Wireless Phones and purchase a new Tracfone Pre-Paid Phone. Next, remove the battery cover and the battery from the old phone. You will see a little white card underneith the metal sheilding. This is callled the SIMM card. Simply slide the SIMM card out from the underneith the shield to remove it from the old phone. Now, repeat the same procedure described with the new phone and remove that SIMM card as well. Once you have removed both SIMM cards, simply take the SIMM card that came out of your old phone and insert it in your new phone. Replace the battery and cover and power up your new phone. The network will recognize your SIMM card and give you the same minutes that you had with your old phone and your same phone number.
Feb 25, 2010 | Motorola Mobility TracFone w175 PayAsYouGo...
I need a puk code for samsung s-3650 can not use it without it.
If you enter your SIMM password wrong a few times (3 in general), your SIMM will be lock: contact your Mobile phone Service provider help desk who should be abel to give you the specific SIMM card 'PUK' code.
DO NOT ATTEMPT TO ENTER INVALID CODE as after usually 10 tries, your SIMM CARD WILL BE DESTROYED and need replacement simm at a (substantial) cost!
Dec 24, 2009 | Samsung S3650 Corby / S3650 Genio Touch...
My hp ipaq hw6515 does not read my Afghanistan's sim card
The IPAQ 6515 will only work with GSM Simm and network. It is also NOT 3G compatible.
You can verify that the 6515 is working with another network SIMM, then it is likely that your Simm card is not compatible and may in fact be design on Afghanistan's 'Analog' network.
Incidentally, the 6515 will also not work in Japan even with a working 'roaming' SIMM as the Japanese Mobile Network is also not compatible!
Hope it helps!
Dec 15, 2009 | HP iPAQ hw6515 Pocket PC
Just bought this sony ericsson 510ki off ebay. It does'nt have a simm and when I put my simm inside it just says insert correct simm
This means your phone is locked to some network
( Means u can't use other SIM Card unless ur phone is UNLOCKED)...
And if u want to unlock it then just ask me back...
i will help u with that...
- Nicky
Nov 13, 2009 | Sony Ericsson K550i Cellular Phone
Simm card puk code
When a SIM card get's blocked you can enter the PUK code to unblock it. The PUK code should be available from the service provider.
Be careful, if you enter 10 wrong PUK codes you completely block your SIM card. There is no (known) way to unlock it.
please rate the solution if you find it useful
Feb 03, 2009 | Teac (DV-W58GA-PUK) Burner
My Motorola Krazr is telling me to Insert SIM.Its says I can only make emergency numbers.What do i do?
BrutherG,
I was getting the same message after charging the phone and powering it back up.  I do not remember ever touching the Simm card but somehow I had entered it with the 45 degree corner cut-off viewable after insertion which is the wrong orientation.  The end of the card with the corner cut-off is inserted first and will become hidden from view.
Another suggestion is to take a thing swab of alcohol and clean off both the Simm card contacts as will as the round contacts in the phone.  Make sure you gently blow dry the contacts with non-heated air before replacing the Simm card and battery.  I think the real issue all along was contacts slightly covered with a film that was making the phone think it lacked a Simm card altogether.
Hope this helps!
Sep 24, 2008 | Lands Phones
How do I transfer phone numbers from phone memory to simm card Sony ericson K 700 i ( to use simm card in a new phone)
In my sony ericsson, when I go to the phone book, I select the menu key and go into the phonebook options/setup
Jun 27, 2008 | Lands Phones
Motorola Mobility RAZR V3m Cellular Phone Logo
75 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
