Hi... Is my Behringer Ultragraph FBQ1502 compatible with HARMAN/KARDON AVR 146? I already tried a bunch of cords but still I can't use it. When the FBQ1502 connected to HARMAN/KARDON the sound was gone, then if I take out the cords from my harman kardon the music plays. What am I suppose to do with it? Can you answer it directly. Tnx!
  • jppalma62 Aug 12, 2008
    yOUR INFORMATION ABOUT BEHRINGER FBQ1502 WAS NOT HELPFUL! IT DOESNT HAVE ANY SENSE BECAUSE YOU ANSWERED IT WRONG. I AM ASKING ABOUT BEHRINGER FBQ1502 NOT THE OTHER ONE!
    Brigadier General:
  • 6,966 Answers
Hi again,
Thank you for correcting the model. To my understanding the FBQ1502 also uses ¼” TRS connectors same as the FBQ6200.
Posted on Aug 13, 2008
2 Suggested Answers
Benimur
  • 6966 Answers
SOURCE: Behringer FBQ1502
An old trick we use to do is use the TAPE IN/OUT of the receiver and hook it to the stereo RCA IN/OUT of the equalizer.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Aug 09, 2008
Harman Kardon 146 receiver not turning on.
Possible blown fuse inside unit, unplug and remove the top cover
fuse should be near the power board and transformer. replace with exact fuse, "Never remove covers with the unit plugged in" Always wait 4 or 5 minutes after unplugging to remove the cover.Replace cover before plugging unit back in.
Oct 06, 2014 | Harmon Kardon Harman Kardon Avr 146 5.1...
Behringer FBQ1502
Aug 09, 2008 | Behringer FBQ6200 Home Equalizer
I want to set up my behringer fbq1502
It sounds as if you are not running in series. I assume you are in an insert on the mic channel. The insert send should go to the first item in the chain, then from the output of that to the input on the next item and so on until the output of the final item in the chain goes back to the return on the insert. This is applicable to the type of equipment you have detailed, in some cases however you may be running effects in parallel. Your case is definitely a series situation.
Mar 08, 2014 | Behringer FBQ1502 Ultragraph Pro Dual...
How to hook up a mixer, pre amp, power amp, crossover and equalizer
let see you want me to teach you what it took me 20 years to learn in a few moments...really
Mar 06, 2014 | Behringer Ultragraph Pro Fbq1502 Feedback...
I want to purchase a behringer 15 band graphic equaliser and connect it to a numark 5000fx mixer via skytec pro600 power amp can you help.
The signal path to follow is explained below:
*Audio Source(Cd/LapTop/Ipod)output to,
*Numark 5000FX Input, Then master/main outputs go to,
*Behringer FBQ1502 Inputs, then outputs go to,
*Pro600 Power Amplifier Inputs, then power amp outputs hooked up with a speaker each side.
Hope this helps.
Nov 06, 2013 | Behringer FBQ1502 Ultragraph Pro Dual...
Circuit diagram for ultragraph pro fbq 1502
and you are skilled at large scale smt replacements..
Feb 18, 2013 | Behringer Fbq1502 Ultragraph Fbq Pro 15...
Harmon/Kardon AVR 146 wont stay on when hit power
Probably was damage buy a power surge, Internal damage to (Reciever)
Nov 03, 2012 | Harmon Kardon Harman Kardon Avr 146 5.1...
Audio problems using a Playstation 3
First try ensuring that "OPT 1, 2, or 3" function is selected depending which one you are using on the H/K 146 (see manual for selection instructions). Next please ensure that the PS3 audio out set to "optical" (Settings/sound settings/audio output settings/digital out+DD 5.1). That should help.
Dec 05, 2008 | Harman Kardon AVR 130 Receiver
218 people viewed this question
 Grubhead
Grubhead
