Question about Canon imageCLASS MF4150 All-In-One Laser Printer
Canon image class MF4150 distinctive ring
Hi there
My fax picks up on my phone line as well as for distinctive ring. How do I set this up for just distinctive ring? I can't find it in the menu.
Thanks
I have an ooma telo and canon mf4150 fax machine. I have a main line and a 2nd dedicated fax line on my telo. I have a 3-way splitter on my telo phone port with connections to 1) the fax machine, 2) my panasonic telepone and 3) the telephone plug (to distribute the ooma dial tone throughout my house.
Problem: when I get a phone call on my main line (which is not enabled in ooma my page preferences for fax), the fax machine picks it up.
I was going to set up ooma to deliver a distinctive ring on the fax line, but the choices for distinctive rings do not match the fax machine's choices for distinctive rings.
I can't leave the fax machine on manual answer (recommended by ooma) because it is a dedicated fax line to receive faxes whenever they come in.
Help?
Posted on Feb 20, 2010
How to Set the Receive Mode (MF4140/MF4150)
1. Press [Additional Functions]. 2. Use [Left cursor] or [Right cursor] to select [FAX SETTINGS], then press [OK]. 3. Use [Left cursor] or [Right cursor] to select [RX SETTINGS], then press [OK]. 4. Use [Left cursor] or [Right cursor] to select [RX MODE], then press [OK]. 5. Use [Left cursor] or [Right cursor] to select the receive mode, then press [OK]. [FaxOnly]: Answers all calls as faxes and disconnects voice calls. [AnsMode]: Receives faxes automatically and records voice messages. [NET SWITCH]: Distinguishes between fax and voice calls. [FaxTel]: Switches between fax and voice calls automatically. [MANUAL]: Does not answer any calls. You have to manually receive faxes. NOTE: a. For [FaxTel] or [MANUAL], make sure the optional handset or an external telephone is connected to the machine. b. For [AnsMode], make sure an answering machine is connected to the machine. c. The [NET SWITCH] mode is available for certain countries only and requires subscription to a network switch service. 6. Press [Stop/Reset] to return to the standby mode.
Posted on Aug 30, 2008
Hooking up fax to KX TG7871 Panasonic Phone
There is excellent support here on basic fax setups. You have what is known as "Distinctive Ringing Service". There are pros and cons to the various setups. I assume you recognize the rings and answer only when the ring for the landline talk comes on. The fax will pick up the faxes, and the answering machine will pick up the voice.
Need model number of your fax - google that!
Service manual for your phone.
http://service.us.panasonic.com/OPERMANPDF/KXTG7841-MUL.PDF
This link shows various configurations of setting up your phone/fax/answering machine or using an answering service.
http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&lc=en&docname=c00059780#Dist_ring
Distinctive Ringing Service setup While it is not available everywhere, a distinctive ringing service can be purchased from most telephone companies. With this service, more than one phone number is assigned to the same phone line. Each phone number will ring differently. The main number will ring with a normal single ring and the additional number will ring with a distinctive ring pattern assigned by the phone company.
When a distinctive ringing service is used, set the Rings to Answer to 2 and then follow the steps below to set the distinctive ringing pattern:
  1. Press Setup , press 4 , and then press 1 to enter the Answer Ring Pattern setup of the Advanced Fax settings.
  2. Use the Right Arrow to scroll through the available settings. When the ring pattern assigned by the phone company displays (double or triple rings), press OK .
Mar 06, 2014 | Lands Phones
Distinct ring function for fax?
Setting The Receive Mode
  1. Press <FAX>, then press <Menu>.
  2. Press <OK>.
  3. Use [<]or [>] to select the receive mode.
  4. Press <OK>.
Aug 13, 2008 | Canon PIXMA MP780 All-In-One InkJet...
I have a canon mx410 all in one inkjet printer.i need assistance with setting up the fax to a phone line. Thank you Zainy
  • Call your phone company to sign up for service. Ask for an additional line with a "distinctive ring." The additional line is for your fax machine---whenever you hear the distinctive ring you'll know that a fax is coming through. Get voice mail service on the regular phone line as well.
    Purchase a two-jack phone splitter (sometimes called a wall jack adapter) that allows two cords to plug into the same phone line. Plug it into the phone jack in your wall.
  • Run a phone cord from both machines into the wall adapter. Test the system by calling both your regular phone number (assure it rings and the voice mail picks up) and your fax number to see if the fax machine picks up (you'll hear a set of strange beeping tones).
  • Apr 13, 2011 | Canon Pixma MX410 All-In-One Printer
    Can't send or receive faxes
    it's most likely the compression on the phone line or you need to set up your fax machine for proper receive mode.
    Contact your phone service provider to see if they support faxes.
    (Faxes cannot handle nearly as much compression as standard voice)
    Jun 09, 2010 | Canon PIXMA MX300 All-in-One Printer
    Can't receive fax. MP530is set on DRPD. Phone
    DR is for distinctive ring, do you actually have distinctive ring from your phone company? Have you set the matching pattern into the Canon? It will only answer when it is sent the proper ring, unless you turn off distinctive ring.
    Apr 20, 2010 | Canon PIXMA MP530 All-In-One InkJet...
    Canon mf4150 -- fax has a mind of its own?
    Hi ...
    The problem is with receive mode settings ... Following the below instructions and you can change the receive mode settings which will resolve the problem.
    Setting the Receive Mode
    1. Press <Additional Functions>.
    2. Use <la.gif> or <ra.gif> to select [5 FAX SETTINGS], then press <OK>.
    3. Use <la.gif> or <ra.gif> to select [3 RX SETTINGS], then press <OK>.
    4. Use <la.gif> or <ra.gif> to select [3 RX MODE], then press <OK>.
    5. Use <la.gif> or <ra.gif> to select the desired receive mode, then press <OK>.
      round_note.gif - For [AnsMode], make sure an answering machine is connected to the machine. If [AnsMode], [FAX/TEL], or [DRPD] is selected, you can select some settings as below:
      [AnsMode]
      --- [AnsMode CHK TIME] (select time from 10 to 30 seconds for the answering machine to start playing outgoing message after receiving a call)
      --- [FAX DETECT TIME] (select the duration from 10 to 70 seconds for the fax to detect)
      [FAX/TEL]
      --- [RING START TIME] (select the time from 0 to 30 seconds for the phone to start ringing after receiving a call)
      --- [F/T RING TIME] (select the duration of ringing from 10 to 45 seconds)
      --- [F/T SWITCH ACTION] (select the action the machine will take after the ringing ends, Receive or Disconnect)
      [DRPD]
      --- [NORMAL RING]
      --- [DOUBLE RING]
      --- [SHORT-SHORT-LONG]
      --- [SHORT-LONG-SHORT]
      --- [OTHER RING TYPE]
    6. Press <Stop/Reset> to return to the standby display.
    Jul 17, 2009 | Canon imageCLASS® MF4150 All-In-One Laser...
    How to change fax settings to accommodate distinctive ring
    Go to this link. In the search window in the center of the screen, type "drpd setup" and click on the Search button. Select the option "How do I set up DRPD". You should see step by step instructions to set it up.
    Feb 05, 2009 | Canon PIXMA MP530 All-In-One InkJet...
    Phone line and fax line
    If you actually have a 2 line setup with 2 #'s each with it's own separate line, it's wired backwards. Otherwise (distinctive ring, etc) the machine has to be capable of and set-up to recognize which ring pattern is a fax call.
    Also, you have to enable auto-answer on the fax machine.
    Feb 21, 2008 | Canon PIXMA MP830 All-In-One InkJet...
    Canon imageCLASS  MF4150 All-In-One Laser Printer Logo
    1,107 people viewed this question
    old marine
    old marine
