Question about Uniden Cordless phone EXS9950
Phone not working. I left it unpluged all night to reboot. Same proplen. No service in or out. Badse keeps flashing "Welcome Please wait"
  • bcr578 Aug 12, 2008
    no dialtone on any of the phones. What is pairing? How to redo the initial install setup. Can't find the manual
    Guru:
  • 1,894 Answers
Pls check if the intercom function works. If yes, then the base is simply waiting for the presence of a dialtone on the telephone line. It would be required to check your telephone wire connections. Further, if you have an extension telephone, pls verify that indeed you have dialtone along the same line. In most instances, you may need to contact your phone provider to verify service.
If no intercom function, it may simply need pairing again or redo the initial install setup.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
credits: Benimur
Posted on Aug 12, 2008
Uniden powermax 5.8 GHz not working
have you tried a hard reset. please leave the phone plugged off from wall power for one night and then try starting.
this may start the phone normally and problem will get solved many times.
thank you
Aug 12, 2008 | Uniden Cordless phone EXS9950
Blackberry 8520 won't reboot goes half way then stops took battery out left all night still won't go any further what can I do ? Please
my phone does this ever so often... you will lose all the data on the phone. with the phone off take the sdd card out and then while holding the volume button (+ or - changes from phone to phone... hold the volume camera and power button and wait for the screen you dont ever see, if you stop holding or hold the wrong volume button it will not work... then when that screen pops up hit your menu button on the touch screen, use the volume button to scroll down to system restore or what ever its called and select it with the camera button... then reboot your phone.
Feb 08, 2013 | Cell Phones
I use nokia c - 3.. last night i download facebook n mini opera than after my cell automatically restart n restore all... n after internet browse not opened also alerts DOWNLOAD SETTING FOR SOME...
This problem cause due to over usage of phone memory.So, first of all try to remove sim card and charger and try to reboot the phone for 5-10 times.If the problem still persist contact mobile repairing shop or follow the steps below First download and install Pheonix from this link. Nokia Phoenix Service Software 2011 - Download secondly Download flash file from this link C 3 flash file and install it to C / program files/pheonix.. after finished this installation open pheonix . Inside the interface at the> top left <there you see "File" click there and choose "open file" and then select the approprait Product type i.e "which is written on the back panel inside the battery of every Nokia(Type RM-000).After doing this again at the left top count from "File"1..2..3..the 4th one is "Flashing" press there, when you click there you'll see three sub-menus, just select the "Firmware Update" again you'll see another interface. Look at the product code there should be blank and put your "mouse tool" at the straight end from the "Product Code" there is a Button and choose the code which is written in the back side of your phone. e.g CODE:0000000.if the same code does not found just take one which is higher. After this you can see "Dead phone USB flashing" click that box. Now this is the last stage... Connect your phone with the USB to your PC and let the driver install ...wait for a moment.(If your phone working).Lastly after just finished (In case your phone is Dead, unable to switch on in normal mode start from here) Connect the phone to pc without powering...insert good battery and Click the "Referbish" button after this, a message will prompt you "press power botton" etc. insert charger or press it and wait until the phone will Restart automatically in normal mode 10-15 minutes. If you cannot understand just leave a Comment / Click here1. thanks for visiting fixya. Good luck.
Sep 18, 2011 | Nokia C3 Cell Phone
I flashed WM 6.5 SCHIST ROM 21864 TouchFlo2D on my Asus P527 smartphone. Flashing happened successfully when rebooted, It hangs at welcome screen "Wendows Mobile". To reflash it with older...
Win 21864 ROM did not work for me. got stuck at the same place as u were.
Was able to recover the phone with the below way
1. download SCHIST_23034pim from xda-developer. (Sorry dont have the direct link). and unrar it.
2. keep the phone locked.
3. press the ok button on the left side of the phone
4. press reset using the stylus
5. release the reset button
6. release ok button
7. You should get the "Insert IPL cable" message on the phone.
8. Run the P527FUU.exe from the place where u had unrared the SCHIST_2303 ROM
9. Right click on the window title and select expert mode.
10. Click the update button. Phone would be flashed with 6,5
Note:
Found some issues
1. Date gets reset whenever phone is switched on
2. Missed calls lost. You get the notification of missed call,but when you click the notification do not see the missed call.
3. Wireless configuration lost when rebooting.
4. Issue with accessing windows market place.
Nov 18, 2010 | ASUS P527 Smartphone
Uniden DSS7855+1, flashing ''welcome! please wait...'', wont work
This is not a direct solution to your problem, but a workaround for a similar situation. I have two headsets and two charging stations. One of the headsets was stuck with the message ''Welcome! please wait''. When I put the phone on the charging station it usually sits on nothing would happen, but when I put it on the other station the phone came back to life. The non-working charging station will still charge the phone so it is worth keeping.
Mar 04, 2009 | Uniden Lands Phones
W580i Screen!
the firmware on the phone need to be flash to correct this issue...try topsony.com or take the phone to a mobile service center and have them flash it for you.
Oct 23, 2008 | Sony Ericsson W850i Cellular Phone
Uniden Cordless phone EXS9950 Logo
207 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
