My HP 8510w is running 1680x1050 resolution, but the Samsung 225BW does not pickup this resolution, instead running 1400x1040. Therefore the screen looks odd and out of sync!
    Scholar:
  • 94 Answers
Not all monitors can display the resoluton that graphics cards output. You will just have to choose a resolution that you can use comfortably, or buy a monitor that will accept a 1680x1050 input.
Hope this helps.
Posted on Aug 13, 2008
SOURCE:
I'm trying to connect my ps3 to an HP w2007 LCD monitor, yet the monitor states it cannot connect because of changing settings to 1680x1050-60hz. I've already connected HDMI-DVI and have no idea next.
You need to change the resolution on your PS3 to match the 1680x1050 of the monitor:
Start with your PS3 turned off. With the PS3 off (showing a solid Red light) if you hold the power button down until you hear two beeps it will force the PS3 to forget any saved video output settings and boot up at a lower resolution. It will then take you through the Optimal Resolution set up.
Aug 15, 2016 | HP W2007 LCD Monitor
My desk top computer input signal out of range says change to 1680x1050-60HZ what do I DO
Just change resolution to 1680x1050. On Windows 7 right click on desktop and click screen resolution and change there...
Aug 11, 2013 | HP Compaq 6710b Notebook
Ps3 and HD TV stuck on 576p
Turn off the PS3.
PRESS THE POWER BUTTON AND HOLD IT DOWN UNTIL YOU HEAR 2 BEEPS.
THIS WILL RESET YOU PS3 VIDEO
Jun 27, 2013 | Video Game Consoles & Games
Hello, I have a Toshiba Dynadock U Universal USB Connect Docking Station. I have a Dell laptop with Windows 7 Professional. I set my screen resolution at 1680x1050. Whenever I turn on my laptop, the...
why dont you disable hibernation as it seems the dynadock is outputting a signal that is the maximum that your external monitor / tv is capable of showing
Feb 28, 2011 | Toshiba Dynadock USB Docking Station
If i try to connect to 1680x1050, my screen goes dark. but when im using 1600x1000 it still desplays
The resolution 1680X1050 is the native resolution for your monitor. This means that the best view for your monitor is for this resolution. Your problem in not at the resolution, it's at the refresh rate. How to fix this? Go to the settings for your screen. At the lower right corner you will locate "for advanced users" button. Click on it and choose the "screen" tab. At the lower part of the window you will locate the "refresh rate". Click on it and change it at the lower setting (about 60 - 70 Hertz). Click on aplly - OK. You will be back to the resolution settings page. Set the resolution at 1680X1050, apply - ok. Go back to "refresh rate" window and change the setting to a higher setting STEP BY STEP. In case of an "out of range" and blaack screen DON'T DO ANYTHING, at 15 seconds you will come back to the previous settings. With this procedure you will get the native resolution for your screen with the higher refresh rate.
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Sep 07, 2010 | Samsung 226BW Monitor
Trying to get the screen size fixed properly. screen needs to be set at 1680x1050. It is making pictures look fat
u need to check if ur monitor is capable of handling 1680x1050...resolution
go to Desktop/right click on desktop/go to properties/settings.../in the screen resolution optopn/do u c a slider than has option to select ur 1680x1050
if it has then chose that and click OK....
if ur monitor can show that resolution it will give ua msg else u wont..
mind it...a higher resolution and change regresh freq rate can spoil ur monitor....
so be careful while doing this
Dec 17, 2009 | Computers & Internet
1440x900 Monitor seems to think it is a 1680x1050 screen @ >19"?
Try reinstalling the video driver (Control Panel - System - Device Drivers - Video ... ) Good luck
Jun 13, 2009 | ViewSonic VA1930WM LCD Monitor
Acer x213W - setting the resolution
Sorry about the delay. I also just purchased an Acer x213w and had some trouble setting up my computer in order to achieve the optimum resolution of 1680x1050.
I'm using an HP Pavilion m7170n, so it's a bit old and thus could not support this widescreen resolution. However, my computer comes with an ATI Radeon graphics card and, upon contacting HP Support, was allowed to download ATI's "Catalyst Control Centre". After installation, these drivers added the option of selecting a screen resolution of 1680x1050 from Desktop properties.
So this is my solution to you: simply google your graphics card along with 1680x1050 driver and hopefully you'll be able to download a driver update which does the same for you as it did for me.
May 11, 2008 | Computers & Internet
Problem with the P5VDC-MX to display 1680x1050 resolution
If you go to the FAQ section for your board you will see that the screen resolution can only go to 1600x1200 UXGA, UXGA+ res name pixal depth 8/16/32
http://support.asus.com/faq/faq.aspx?SLanguage=en-us&model=P5VDC-MX
FAQ page 4
Dec 30, 2007 | ASUS P5VDC-MX Motherboard
Open Questions:
Computers & Internet Logo
105 people viewed this question
Ekse
Alun Cox
