Question about Apple Mac OS X 10.4
Mac Disk Utility Problem
Trying to use my Disk Utility program to, but it doesn't start running, what am I missing?
    Problem Solver:
  • 11 Answers
1.Insert the Mac OS X Install CD or DVD.
2.Restart Mac, immediately after the bong, hold down the C key until the Apple logo appears.
3.When the Installer reaches the INTRODUCTION phase, click on Utilities at the top of the screen, and drop down to Disk Utility.
4.Click the First Aid tab.
5.Highlight the boot hard drive volume or partition.
6.Click Repair Disk.
7.Repeat steps 5 and 6 until the scan comes up all clean and good (and run it one more time).
8.Quit Disk Utility and the OS Installer and reboot.
9.Firewire Target Disk Mode is another option we should know about.
Cheers.
Posted on Aug 24, 2008
  • joey stec May 28, 2013
    i tried but the start up disk won't start now no monitor just a blinking pilot
  • 30 Answers
I recommend you to visit my thread about the mac Disk repair
http://www.fixya.com/support/r935084-mac_repair_disk
I think it's clear and easy to follow, you can find it at fixya in the tips & tricks section, or follow the link above.
Ciao.
Posted on Aug 17, 2008
    Problem Solver:
  • 11 Answers
I would suggest updating your Apple to the latest MAC OS X 10.5
Posted on Aug 15, 2008
How do I fix error code -8072 in OSX when trying to deleteitems fro Trash bin
If you can't empty the Trash on your Mac Try these solutions if you can't empty the Trash or move a file to the Trash.
If your Mac says that the file is in use
  1. Quit any app that you were using with the file, then empty the Trash.
  2. If that doesn't work, the app might have one or more background processes that are using the file. Restart your Mac, then empty the Trash.
  3. If that doesn't work, you might have a startup item or login item that is using the file. To temporarily prevent such items from opening automatically, start up in safe mode by holding down the Shift key while your Mac starts up. Then empty the Trash and restart your Mac normally.
If you can't delete the file for other reasons
  1. Start up from macOS Recovery by holding down Command-R while your Mac starts up.
  2. When the macOS Utilities window appears, select Disk Utility and click Continue.
  3. In Disk Utility, select the disk that contains the file that you want to delete. Then use the First Aid feature of Disk Utility to repair that disk.
  4. Quit Disk Utility, then restart your Mac and empty the Trash.
Jan 02, 2018 | Computers & Internet
What does flashing globe on white screen on mac meanmacbook pro
If by flashing globe you mean spinning globe (often a colored beach ball), there are several possible reasons. The spinning beach ball happens when a operating system command cannot be completed. The computer is frozen/stuck in a process that it can't complete.
Most often the cause is faulty or missing information on the hard drive. Running Disk Utility will often fix it. You may need to start the computer from your OS install disk and rather than install find Disk Utility in the pull down menu and run it on your hard drive.
The spinning ball could also be caused by insufficient RAM memory to even run the operating system. It could also be caused by hardware problems which can be diagnosed with the Apple Hardware Test found on the disks sold with the machine.
If you truly mean a flashing round globe, I have never seen such a figure. Flashing question marks or flashing circle with a slash through it means the mac cannot find a bootable hard drive. Your hard drive may have died or become corrupted. To see if you hard drive is defective, again run Disk Utility by booting off an install CD or another hard drive with a compatible MacOSX operating system to diagnose.
Try running the repair disk program under the general tab of the Disk Utility program.
Aug 11, 2014 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Time machine on MAC 10.5.8 will not open; error message -43
error -43 fnfErr: File not found
Could be many things, we should start with this...
"Try Disk Utility
1. Insert the Mac OS X Install disc, then restart the computer while holding the C key.
2. When your computer finishes starting up from the disc, choose Disk Utility from the Installer menu at top of the screen. (In Mac OS X 10.4 or later, you must select your language first.)
*Important: Do not click Continue in the first screen of the Installer. If you do, you must restart from the disc again to access Disk Utility.*
3. Click the First Aid tab.
4. Select your Mac OS X volume.
5. Click Repair Disk, (not Repair Permissions). Disk Utility checks and repairs the disk."
http://docs.info.apple.com/article.html?artnum=106214
Then Repair Disk on the external drive.
Then try a Safe Boot, (holding Shift key down at bootup), run Disk Utility in Applications>Utilities, then highlight your drive, click on Repair Permissions, reboot when it completes.
(Safe boot may stay on the gray radian for a long time, let it go, it's trying to repair the Hard Drive.)
If perchance you can't find your install Disc, at least try it from the Safe Boot part onward.
If TM display doesn't even show up, see this...
http://pondini.org/TM/E4.html
And also i share a link to another error issues.
http://www.macworld.co.uk/feature/mac-software/common-mac-error-messages-3502033/
Thanks,
Mac Support
May 25, 2014 | Computers & Internet
Mac 0sx 10.5.8
The disk might not have a working OS on it.
It you have successfully run the disk utility the disk probably in full working order. I think that the OS on the disk is either missing, corrupt or not compatible with the computer you are running it on.
May 28, 2013 | Apple Leopard 10.5 Osx Mac Operating...
My power mac G4 is not opening safemode as well as it is not boot from CD
Two possible things are wrong either your hard drive has gone or your system has corrupted. Put your instal or system disk in start it up holding down the c key. Once it has started check that the hard drive exists by go to the menu bar and selecting the disk utility. If the hard drive shows it means that it is okay run the disk utility check drive and then run the repair permissions. Then try restarting, if it works then you are back up and running again. If the drive shows up and you restart and the same thing shows up with the grey screen, you will need to reinstal your system. You do this by starting up with the instal disk holding down the c key and run the instal script. To keep your hard drive contents your will MUST use the preserve users instal.
If your hard drive does not show up the hard drive is probably a gonner and you will have to purchase a new hard drive and instal a fresh system.
Hope this helps
Nov 17, 2011 | Apple PowerBook G4 Mac Notebook
When I try to connect my Seagate Free Agent Pro backup drive using USB to my new Sony BDP S570 DVD player I receive a message USB device connected is not support. It worked with a Western Digital drive
So I would suggest a few things for this issue. First check the format of the drive you are trying to plug in. You can do this on your Mac by using Disk Utility (Applications - Utilities - Disk Utility). Plug in the drive and open Disk Utility and click on the partition. At the bottom of the Disk Utility window it lists the information about the drive. You are specifically interested in the "Format" item. If your drive is formatted Mac OS Extended or some other Mac format you probably cannot use it on the Sony Blue Ray player. Most device look for and are only compatible with Windows type formats. For example, NTFS or FAT32. The best way to test if this is really the problem, or a systemic problem with the BR player would be to pick up a USB jump drive somewhere (they are cheap if you don't have one just laying around.) Format the jump drive to a FAT32 or NTFS file system using Disk Utility. Copy the files you want to view to the jump drive (Be sure to check the file type compatibility chart on the Sony website or in the manual and make sure what you are trying to view matches those types.) Plug that in and see if you are successful. Also there was a few notes on forums that Sony doesn't support actual hard drives on the BR players which would suggest that they only support Jump drives and FAT32 because of the file size limitations it brings. Try this and let me know how it goes. Attached is a picture of my Free Agent drive formatted for Mac in Disk Utility .jp_2010.jpg
Apr 30, 2011 | Computers & Internet
When powering it up it starts to boot I get a blue screen then it goes black where do I start ?
Try starting your mac from it's install disc.
1) First turn off your computer.
2) Then restart it, right when you push the power button to turn it on, press the option key down and hold it
3) pressing the option key will bring to a screen where you can choose your startup disk. Usually, you'll see your Macintosh HD available to startup from. Don't choose anything yet.
4) Insert your install disc into the CD slot.
5) wait a couple of seconds and then clock on your install disc as your startup option.
6) after clicking on the disc, go to the menubar and click on Utilities then disk utility.
7)once the disk utility app is open hit "verify disk permissions"
8) after you've "verified disk permission" hit "repair disk permissions"
- this might take a long time depending how much you've actually done this (which it's good to do every other month or so to keep your mac running smoothly). things might seem to freeze up as well, but it's the mac trying to verify and repair broken permissions on your computer. Don't that's normal.
9) after you have repaired the disk permission, reboot your mac by quitting disk utility and then choosing the startup disk as your normal macintosh HD. That should do the trick. If not, tell us what has changed.
Dec 15, 2010 | Apple PowerBook G4 Mac Notebook
Can`t install a O S on a new hard disk
you will need to run fdisk. to create a partition on the HD .
then format the drive c:
you can use any partition creator software
May 14, 2010 | Acer X193W LCD Monitor
MacBook Desktop Lost My Desktop Folders
Hello, it semms that you have a "permission" issue, or that you are accesing another account on the computer without noticing it. Please repair disk and permissions from the disk utility on your install DVD:
- Insert install DVD
- reboot the mac holding the C key
- choose english
- Go to the utilities menu and choose Disk Utility
- In the disk utility window, SOS tab, select your drive, and hit repair disk and repair permissions
- reboot
Also check that you are accessing the account that you want and not another one: log out, and log in...
May 31, 2009 | Apple Power Mac G4 Dual Mac Desktop
New User
You need to run the disk utility program to repair disk permissions. It is in the applications folder, in utilities, first aid. If the iBook won't let you run that program, you will need to boot from the Tiger CD and run the disk utility from there.
The final revision of Tiger is 10.4.11. Once you have your system in order you will want to check for Apple updates. This can be found under the apple menu at the top of your screen or in system preferences.
Dec 12, 2007 | Apple iBook G4 (Z0AZW13397068) PC Notebook
Apple Mac OS X 10.4 Logo
421 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
