I believe you're referring to the lid safety switch. Do not operate your machine without this safety switch! The switch / wiring harness are not very hard to install... here's how-
---UNPLUG THE WASHER FROM THE ELECTRICAL OUTLET---
1. Remove console, depending on vintage, there should be a couple of screws that will allow you to rotate the console up and back.
2. Remove 2 gold clips at rear of top. These clips are the only thing that retain the top / lid / cabinet
3. Unplug lid switch harness (small white connector at rear of top)
4. Rotate the cabinet up a few inches at the rear and pull it straight off. The top / lid / cabinet will come off as a single unit. The entire lid switch and harness are connected under the top w/ a couple of screws and a few spring retainers.
5. Buy replacement parts at a local appliance repair shop, including a new striker (the part that pushes the switch down when you close the lid).
6. Reinstall everything reverse from above. When you rotate the cabinet back on, make sure you have the front edge under the base channel and push inward on the rear corners to engage the cabinet on the rear base tabs.
Good luck.
