Question about Intel D845GLLY Motherboard
Problem in installing drivers
Hello sir, i have D845GLLY motherboard.my graphics installation CD is not installing some filles like wa310.sys etc.
from where i can download these drivers n how.
please help if
suggest if some such free downloads r available
  • 326 Answers
Http://downloadcenter.intel.com/Product_Filter.aspx?ProductID=829
put your operating system in then select what drivers you need
hope it helps
Posted on Aug 12, 2008
Installing audio driver problem
Hello download the driver from here:
http://support.asus.com/Download.aspx?SLanguage=en&m=P4SP-MX&p=1&os=
Please select your windows system.
Open the Driver folder and click on global for download.
Please unzip the file before you install.
Maybe the file is damaged try uninstall it before you install the new.
Please install the other driver if any missing.
Good luck
Nov 25, 2011 | ASUS P4SP-MX Motherboard
My motherboard is that of intel D845GLLY. I reinstalled windowsxp, so as normal my computer is formatted. this is my first installation after buying. Even if I entered my motherboard cd I could not get an...
Do the following:
  • Control Panel
  • System
  • Hardware
  • Device Manager
  • Look for hardware listed under unknown, your system most likely tried to load the audio driver and couldn't find it at the initial software install of XP
  • Uninstall , Reboot your system, your system will try and reload the driver...point it to the correct file location or install manually
Feb 11, 2011 | Intel D845GLLY Motherboard
Need video driver embeeded on d845 glly / intell
Intel's website is the best place for this. www.intel.com
Here is a link to all of the drivers for this board.
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Desktop+Boards&ProductLine=Intel®+845+Chipset+Family+Boards&ProductProduct=Intel®+Desktop+Board+D845GLLY
Make sure you have the chipset drivers installed before you install the 845 integrated graphics driver.
Good luck
Oct 26, 2009 | Intel D845GLLY Motherboard
Dont have motherboard cd,m not able to find LAN Drivers on net
You have 2 choices. 1. Call Intel tech support & see if they can find a solution for you or 2. Install a standalone ethernet/wireless card, depending on your setup and disable onboard LAN. I had to go the 2nd route as my onboard LAN wass not compatible with Windows Vista. Hope this helps.
Dec 24, 2008 | Intel D845GLLY Motherboard
Audio installing
THE PROBLEM IS THE AUDIO DRIVER OF INTEL D845GLLY MOTHERBOARD FOR XP SERVICE PACK 2 NOT SUPPORTED PLEASE HELP ME FOR DOWNLOAD THIS DRIVER NOW
Oct 21, 2008 | Intel D845GLLY Motherboard
Graphics card
Hi Harikris, no you can not install just any graphics card. You're Intel D845GLLY board uses an onboard graphics card. (It's an AGP graphics card).
If it's you're intention to install a new graphics card you must use a PCI graphics card. (Understand that the AGP onboard graphics is faster than a PCI graphics card). However, the PCI cards do use their own memory. (Which fee’s you're system memory to run windows.
The Intel D845GLLY has 4 PCI (White) slots, onboard. You can add a video card into the system. You're onboard video card does use you're system memory to function. If you're PC has 512MB of system memory & you're video card is set to use 128MB of memory. Than you're system is left to run with 128MB. One would think you're system is running a little slow.
The Intel D845GLLY motherboard can use up to 256MB of system memory. You can set the amount of system memory in the bios as shown on page 49, table 18. In you're manual. If you do not have you're manual you can download it from here: http://www.intel.com/support/motherboards/desktop/d845glly/sb/cs-008853.htm
May I suggest you increase you're system memory to 1GB. Than increase you're graphics memory to 256MB. You're system will run faster & so will you're graphics card. These older Intel motherboards require memory current for you're board. Click this link: http://www.memory-up.com/Memory/IntelD12696.html
If you still feel that you want to use the slower PCI graphics card you can choose from any listed on this link: http://www.newegg.com/product/ProductList.aspx?N=2000380048+1069609642&Submit=ENE&SubCategory=48&nm_mc=KNC-GoogleAdwords&cm_mmc=KNC-GoogleAdwords-_-NA-_-NA-_-NA
You will also need to change a setting in you're bios to boot to the PCI card instead of the AGP onboard card. Page 49.
Good Luck!
M
Jun 04, 2008 | Intel D845GLLY Motherboard
Intel 845 glly board please solve the problem
Hi Nadeem Nawaz,
No board will show display without memory. Your motherboard must run memory type;
Two DIMM sockets supporting 3.3 V (only) 168-pin 133 MHz Single Data Rate (SDR) SDRAM DIMMs with gold-plated contacts.
Unbuffered non-ECC DIMMs only.
Maximum total system memory: 2 GB; minimum total system memory: 64 MB.
Serial Presence Detect (SPD) DIMMs only.
Intel link showing memory specifications.
Intel Desktop Board D845GLLY
http://www.intel.com/support/motherboards/desktop/d845glly/sb/cs-012825.htm
If your memory is within Intel's memory specifications & you are not getting display on your monitor. It is possible that the integerated on board graphics (Shown on page 13 in your user manual), may be defective.
You can add a PCI video card to the PC. The Intel D845GLLY will auto detect the PCI video card. No need to enter the bios & make changes.
Please keep this in mind. The integrated video card is PCI, if it has failed, there is a good chance it will not see the PCI add in video card. If you can find a used (Working) PCI video card to test in the PC.
Intel Desktop Board D845GLLY main website link.
Luck!
Apr 19, 2008 | Intel D845GLLY Motherboard
Dowloading graphic driver
You can download all drivers for Windows XP from here.
Lolita
Apr 10, 2008 | Intel D845GLLY Motherboard
USB
checked my XP via control panel: usbhub.sys usbohci.sys usbport.sys usbui.sys good luck...may be difficult to force drivers...when system asks to install software, insert the original XP cd. The driver did not change with SP2, as far as I know.
Aug 18, 2007 | Microsoft Windows XP Professional With...
Intel D845GLLY Motherboard Logo
62 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
