Question about Transcend (589307) Media
1 gb sd card
I removed my 1gb transend sd card from my digital camera whilst it was still turned, now i cannot access my images and neither my camera or my pc recognises the sd card
Does your cvamera has interior memory?
Posted on Aug 12, 2008
What GB memory card does work in a C310 digital camera. My printer dock does not work anymore except to charge my camera and I thought I could get a memory card and print the few pictures I take at a...
The C310 will accept SD cards up to 2GB in size and SDHC cards up to 32 GB. 1GB SD cards are getting hard to find, but 2GB cards should work just as well.
BTW, FixYa doesn't have an online store.
Jun 21, 2011 | Kodak EasyShare C310 Digital Camera
My model is SD 10. Sofar I had 256 MB memory card in that camera. Recently I put 2 GB card. After somedays the camera take long time for processing. Finally in the photo taken day light, I can see only...
switch to a sd card of less than 2gb as your camera's internal image processor power is being used in running or reading the huge 2gb sd card ...and that is the reason the image izz getting white ...try for 1gb or less ..
Jan 31, 2011 | Canon PowerShot SD10 / IXUS I Digital...
Im using an optio s4 camera and just bought a 4GB SD card. But when I insert the SD card into the camera, there's only a black screen when I turn it on.:( But when I remove the SD card, the camera works...
The Optio S4 works with MMC and SD cards. Your 4GB card is actually an SDHC card. While it fits into the slot, it is electronically incompatible. You need to go with cards 2GB and smaller.
Jan 15, 2011 | Pentax Optio S4 Digital Camera
Memory card error
This seems to be a known issue with the Canon camera's to display Memory card error.
Give this a try
1. Remove the card from camera and wait for sometime ( 1-2 minute ) and re-inserting the card.
2. If this does not work, you need a card reader to read/view images on your PC ( since you are not able to access the card in your camera )
3. If you are not able to access/view the images from Card, click on the link below to recover the images from card - Recover images
When you open the webpage, click on the Download Now option to download the software ( it is free )
4. Try this fix to resolve the issue, Sometimes it takes long time for the camera to load the images and it results in memory card error - Click on the link to download the fix - Firmware Update
5. Try using a SD card with less memory like 1 GB card or max 2 GB for better access of card in camera.
Hope this is helpful.
Nov 05, 2010 | Canon PowerShot S3 IS Digital Camera
I lost the usb cable for my camera and am trying to remove images from the internal sd card. how can i do this?
For your USB
> Contact kodak store at 1 888 369 6600 ask for KODAK USB Cable, Model U-8 or simply log on to www.kodak.com/go/shop.
To remove images from the internal memory of the camera
1. Turn the Mode dial to Favorites
2. Press the Menu button
3. Highlight delete or the minus icon, then press the OK button.
All pictures stored in the Favorites section of internal memory are removed.
4. Press the Menu button to exit the menu
** Kodak CD33 has 16 MB internal memory and it has a slot for MEMORY CARD 3428db8.jpginternal memory is different to memory card. You can use the camera without memory card but it's only up to 16MB while if your using s memory card you can load up to SD Memory Card 2 GB.
16MB if camera is set to 2MP it will only take about 2-5 photos while if your using a Memory card with a size of 1GB and camera is set to 2MP about 1137 photos.
* Contact Kodak support line @ 1 800 235 6325 (23KODAK)
Nov 16, 2009 | Kodak EasyShare CD33 Digital Camera
What does error code 00400 mean
Moultrie told me they could not fix the camera. I removed the Lexar 512 SD card and re-ran the test. The test passed and the camera worked. I replaced the Lexar SD card with a Cannon SD card and reran the test. The test passed and the camera works. I put the Lexar SD card and got a 00400 error message. Change SD cards. It fixed the problem for me.
Aug 31, 2009 | Moultrie MFH-DGS-200 Digital Camera
I bought a 2GB SD card for my Kodak EasyShare C330 Camera
Buy a 1GB card (or 2). The spec for the SD card format is going to 2GB but the Kodak C330 not compatible with 2 GB SD memory cards.
Click
Jun 01, 2009 | Kodak EasyShare C330 Digital Camera
My Mustek dv-3500 doesn't take a 1 gb or 2 gb sd card?
If the camera will accept a 1GB card you'll be happy to know it will hold a ton of images (verses your 128MB). Yes - you would format the SD card in your camera. You should find the instructions in your manual or poking around in the menu.
May 01, 2009 | Mustek DV-3500 Digital Camera
SD Card Wont Work
Check if the SD card is iserted properly into the camera, eventually pull it out and push it back inside the camera. Also remove camera batteries , repeat the operation, and put back batteries.
If the card still does not work test the card into a different device, it is not unfrequent that an SD card comes defective from factory. In this case take the card back to the retailer and a have it changed.
If the card works on a different device, then it may be that the NV3 does not support 4 GB , there is no mention about max SD format supported in camera specs, or in the manual. In this case I suggest testing a 1 or 2 Gb card at the shop, and then buying right one.
Regards
Apr 02, 2008 | Samsung NV3 Digital Camera
Transcend (589307) Media Logo
48 people viewed this question
Top Transcend Electronics - Others Experts
Alun Cox
Are you a Transcend Electronics - Other Expert? Answer questions, earn points and help others
