Question about Intel Desktop Board D845WN Motherboard
Intel D845Wn Motherboard
The motherboard has capacitors around the CPU that have blown. Do you repair these boards? Are these boards still available for purchase if unrepairable?
  • jwendel Aug 13, 2008
    It would be great to upgrade the motherboard to something with a new processor, but this machine is actually a digital video recorder and it will only run the recovery and accept licensing with this specific motherboard.
  • 781 Answers
Possible on first question but debatable to do it as something else could have caused them to blow
check the web for similar boards but I would not get similar I would get the latest one I could afford with CPU and change all drives and card over to it then you have a more up to date computer for minimum cost
Posted on Aug 12, 2008
No beeps at post on intel d845wn. have removed all but cpu and hd. any suggestions ?
If you have removed everything and still no beep, that means that your MB doesn't start at all. The problem is either the CPU or the MB
Nov 15, 2009 | Intel D845WN (KD845WNPAK10) Motherboard
How to connect power supply to intel desktop board of d845wn
hmm strange question but you cant really get it wrong you plug the 20 pin conector from the power supply into the board then plug the little 4pin block which is on a diffrent cable into the little 4 pin block on the motherboard there all shaped to fit the conections so you cant get them wrong
Sep 24, 2009 | Intel Desktop Board D845WN Motherboard
Intel desktop board D845wN - no screen display
HI,
Switch on your computer and listen for a beeb sound.... if no beeb sound available then your Motherboard has a problem.
if beeb sound comes then switch off your computer and see for the loose contacts on motherboard.
eg. remove ram, clean ram socket and put back the ram
your problem may solved.
thanks
ehsan (md_ehsan_1@yahoo.co.in)
Jun 15, 2009 | Intel Desktop Board D845WN Motherboard
Windows Xp sp 2 installation problem
check the cpu fan or remove it then put it again
Nov 08, 2008 | Intel D845WN (KD845WNPAK10) Motherboard
133hz sdram problem
Please check this Intel link that shows specifications for memory that can be used in the Intel D845WN motherboard.
http://www.intel.com/support/motherboards/desktop/d845wn/sb/cs-008941.htm#1
When upgrading or increasing memory. The DIMM's should be the same. The Intel D845WN board requires the memory to run at 3.3volt. If the memory you are adding is within the Intel spec's, than switch the two Dimm's. Insert only the new DIMM & check if the system hangs. If it does than it is possible the new memory it either not compatable or is defective. For more information about the D845WN board download the manual for you're Intel board. http://support.intel.com/support/motherboards/desktop/d845wn/sb/cs-008937.htm
Luck!
Mike
May 19, 2008 | Intel D845WN (KD845WNPAK10) Motherboard
Intel Mother Board D845WN
Seems there is a loose wire, loose card, motherboard failure or mis-plugged wire. IS everything in right?
Nov 09, 2007 | Intel Desktop Board D845WN Motherboard
Intel Desktop Board D845WN Motherboard Logo
52 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
