Question about Toshiba e-Studio 350 Copier
Toshiba e 350 "close finisher door"
Copier will not copy due to "close finisher door" error. I have checked and all doors etc are closed. Can anyone help me?
  • 1 more comment
  • store_5112 Aug 13, 2008
    Any chance you could describe the sorter and where to look to see what might be triggered?
  • Anonymous Mar 24, 2009
    Toshiba e 350 "close finisher door i have also same problem where i can find finisher door in thoshiba350?
  • Anonymous Mar 18, 2014
    One copy at a time comes out due to finisher door message. No jams detected but once the door is open and closed one copy will come out and then indicate finisher problem again.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Toshiba Master
  • 1,362 Answers
Finisher door is the sorter. there is a switch or door in the sorter not closed (or triggered)
Posted on Aug 12, 2008
Close Front Cover For Toshiba E-studio 350
There are many possibles that can cause "Close Front Cover"
Check the front cover actuator, switch. If all covers, switches is working fine, probably power supply is faulty.
Dec 02, 2015 | Toshiba e-Studio 350 Copier
Toshiba e-studio 28 copier
Check that all the door are well closed and in place.
Jul 15, 2008 | Toshiba e-Studio65 Copier
I have an error code C-2557 on this Biz 350 with the finisher, without the the finisher m/c works fine
C-2557 ATDC sensor malfunction.Enter in the service mode press following keys:
Utility-Metercount-Details-STOP-0-0-Stop-0-1-press 00000000 press Enter in Tech. mode select Printer than select ATDC gain and read the ATDC current value.If the value is situate 150-160 increase the value to 164-174 (to change the value press C and entering the new value)return in the copy mode turn OFF the copier open the rigy door than close and turn ON the copier and make a few copies.If the error persist discrease the ATDC value and make some copies.If the code persist change the developer .Before change the developer reset the special parts counter I/U counter,developer.After change the developer perform F8 and verify the new value to ATDC gain and notice.
Feb 19, 2013 | Konica Minolta bizhub 350 All-In-One Laser...
Close side door
Good solutions for u :
1. Cheak all the connectors in cool mind
2. On the other hand this fault may me come from main board.
3. and the last say is this error can come out from power supply.
4. Cheak your closing again.
Jul 21, 2010 | Toshiba 2060 Copier
ImageCLASS 2300 not printing, check printer cover message
Had the same problem spent 2 hours opening and closing everything trying to reset turn off and on etc. Here is how I fixed it, slammed all the doors on left side starting with above cartridge to cartridge door and 2 little doors by paper hard - and I mean hard - and whammo error cleared immediately. Sensors that check for open door obviously stick and report they are open when they are really closed. I am sure this saved me an expensive service call.
Apr 05, 2010 | Canon imageCLASS 2300 All-In-One Laser...
I have a trouble code (cobao) with a minolta di alta di 350 copier
Elevation drive motor failure. was there or Is there anything under the trays of the finisher (where the copies come out?) look over the exit trays make sure ther is no damage or binding. Open close finiher door turn power off then on.
Jun 07, 2009 | Minolta Office Equipment & Supplies
Toshiba e studio 232 screen shows
is the finisher tray atach and connector plug in? it's possible that the connector was unplugged while the machine was on and an memory error apeared! if so, unplug the copier from power source, plug in the finisher, and plug in the power corde . if it won't work you shall check also if all doors of finisher are closed and if wasn't broken one of the sensors!
Nov 03, 2008 | Toshiba e-Studio 232 Black and White...
Error Code 000061-0001
Error code for 0061-0001
Main cause : The laser shutter is faulty. The laser unit is faulty. The potential measurement PCB is faulty. The DC controller PCB is faulty.
Mode of detection : 0001- As the result of potential control, the drum surface potential (VL2) of the white background is about 200 V (generating solid black images.)
Dec 14, 2007 | Canon imageRUNNER 5000 Copier
E350 misfeed on print/copy 2nd page
Does this happen from all cassettes or only one? What are you getting for a jam location??
May 11, 2007 | Toshiba e-Studio 350 Copier
Toshiba e-Studio 350 Copier Logo
1,508 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
