Laser skipping in Sony CDP-C67ES? Where to repair?
tvservice306
  • 458 Answers
SOURCE: sony cdp-cx235 cd skip
need replaced laser pick up part no:
Manufacturer Sony Part Number 8-848-415-13 Description DEVICE, OPTICAL
Posted on Apr 04, 2010
dunnbiker
  • 8546 Answers
SOURCE: Sony cdp-cx53 CD player skipping for all cd's
read this...
http://www.repairfaq.org/sam/cdfaq.htm
Posted on Feb 05, 2011
dunnbiker
  • 8546 Answers
SOURCE: I have a Compact Disc Player Sony CDP-CX200 Some
You don't KNOW it's dirty.
Before you dive in and possibly wreck it, read this...
Posted on Apr 02, 2011
SOURCE: cd player skips, shoudl I
I would try a cd cleaner cd - they normally have tiny brushes on the CD itself, which when used brushes against the laser lens.
I have opened one up before, they do get dusty - so if you really want to give it a good clean I would open it (remove the 6 screws putting them somewhere safe) and use a can of compressed air to blow out any dust.
There is a fair amount of grease inside which may collect dust if blown about.
Good luck.
Posted on Sep 28, 2011
  • 10 Answers
SOURCE: the sony model #CDP-c910
Try changing the (only) belt the player has with a brand new one. Go to www.partstore.com. I believe it costs more than $10. Clean the pulleys with isoprophyll alcohol using a cotton swab after removing the old belt.
After you remove the top cover, take a careful look how the belt is placed. Don't unscrew anything. The belt can be removed and replaced without removing any screw. A paper clip will help if you don't have the right belt removal & replacement tool. A commercial CD lens cleaner (I use Scotch brand) will greatly help. Just insert it in your magazine and run for a few seconds to a minute. This is not a sure fire solution but most of the problems in this model is attributed to an loose/overstretched old belt and a dirty laser lens. I hope this helps & good luck!
Posted on Oct 15, 2011
Skipping disc
Hello
Skipping of all types of discs, whethere it is old or new, is due the Laser Pickup Unit problem and is common to all CD playeres whatever brand it may be. Your Sony has also this proble. There is no other way than replace the Laser Pickup Unit with same type and number. Insist on same type and number, since Sony uses special number and type. OK.
Feb 10, 2011 | Sony CDP-CE375 5-Disc CD Changer
When a cd is playing it skips back to beginning of cd & will not advance to next song or it skips the cd entirely & will not continue to play
unfortunately if your disc is clean and scratch free your laser will be weak and need replacing,, on that model cleaning the laser is a waste of time and money as its a sealed cabinet --check for flaws on your disc itself
Sep 01, 2010 | Sony CDP-CE335 5-Disc CD Changer
CDP CX355 Seems to Skip- sound similar to what happens with LP record when dirty.
If the player "skips" after 15+ seconds the likely problem is the split rack&pinion used to position the laser. The split rack is sprung to remove play or backlash when meshing with the driver cog. This split rack can jump cogs over time, eventually becoming ineffective. The solution is to remove the laser assembly and gently disengage the driver cog, compress the split rack and re-engage the driver cog. This should solve the skipping problem.
Nov 28, 2009 | Sony MegaStorage CDP-CX355 300-Disc CD...
Cds dont load and tracks will skip during song play
It is clear symptoms of bad optical laser or dirty optical lens.
Please put lens cleaning CD in player, play that CD to clean dust on optical lens surface. If that helps, fine or replace optical laser block in player.
I can provide you optical lens part number, please confirm is it Sony CDP-CX153 cd player or any other model.
Thanks.
Oct 27, 2009 | Sony CDP-CX153 100-Disc CD Changer
Sony cdp-cx235 cd skip
Apr 07, 2009 | Sony CDP-CX235 200-Disc CD Changer
Cd's always skip
You have done well for 10 years laser changes are in order
When a cd skips it is due to laser diode becoming weak over time not producing an original beam causing focus prolbems ,hence skipping discs
Dec 29, 2008 | Sony CDP-CX220 200-Disc CD Changer
Sony megastorage 300 cd changer
Hi There are many things that can cause your problem, I can tell you the most likely ones, but I recommend you don't take the unit apart, as the mech. in a 300 disk changer is complicated & delicate, and you may just cost yourself alot more money than getting it repaired. The symptoms you sescribe can be caused by failing laser pickup, dirty laser lense (especially if you've done home renvations with drywall), split drive gear that moves the laser on the sled rails, or even a hair or piece of dirt in the gear teeth of that same gear. The unit will play fine, until it hits the tooth where the debris are, then it skips, or jumps back a bit and starts again until it hits the same spot. Also..badly scratched or finger printed disks will cause that, but that is the first thing most people check. I wish it was something you could repair yourself, but my best advise is to take it to a reputable repair shop, and hope it is not a bad laser, as that is a fairly expensive repair. Hope this helps, Good Luck!
May 01, 2007 | Sony MegaStorage CDP-CX355 300-Disc CD...
56 people viewed this question
 Grubhead
Grubhead
