Question about Lexmark X7170 All-In-One InkJet Printer
X7170 I have the error 1203 that appear all the time and not allowing me to use the printer, what sjould i do. Thank you
  • 4,041 Answers
ERROR 1203 LEXMARK ERROR 1200Error 1203 is an issue that occurs either when a cartridge is bad or the printer cartridge Slot is bad...
1 - try cleaning the copper contacts of the both carts and cart slot in the printer and try again..
or
2 - when error shows up, shut the printers power off; wait one minute and turn it back on press copy.
Posted on Apr 25, 2010
Lexmark printer x7170 cartridge error 1203
The 1203 error indicates either a communication problem between your cartridges and the printer or a short in one of your cartridges. Please follow the steps below to identify and fix this issue:
1. Make sure the printer is on.
2. Open the printer cover. The print cartridge carrier moves and stops at the loading position, unless the All-in-One is busy.
Note: If the carrier does not automatically move to the center, turn off the printer/unplug the printer from the power source and then slide the carrier to the center.
3. Remove both cartridges from the carrier.
4. Close the printer cover.
5. Re-brick your printer. Pull out the power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds.
6. When the printer turns on, reinsert one cartridge first.
7. Close the printer cover and check for any errors.
8. If no error appears, reinsert the other cartridge. Close the printer cover.
9. Replace whichever cartridge is causing the error to appear with a new cartridge.
If problem continues, please contact Lexmark Technical Support Center for additional assistance.
Sep 19, 2011 | Lexmark X7170 All-In-One InkJet Printer
Printer says cartridge error: error 1203
Remove both ink cartridges and check the bottoms to be sure all of the tap is removed. Small pieces of tape frequently are stuck to the cartridge bottom causing errors. Confirm you have the correct cartridges (# 34 for Black(HIGHYIELD) and #33 for color). Reseat the cartridges and try again.
Sep 06, 2010 | Lexmark X7170 All-In-One InkJet Printer
X7170 Cartridge error....Code is 1203....need to clear it....WHen I started to scan a document to fax it started getting jammed at the feed and when I stopped it and opened the top cover......It now won't...
Hi there
ERROR 1203 LEXMARK ERROR 1200 Error 1203 is an issue that occurs either when a cartridge is bad or the printer cartridge Slot is bad...
or
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Jan 20, 2010 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
I'm getting a message on my inkjet that says "Cartridge Error:1203". Can you help me fix this problem, I have already checked the cartridges. Thank You!
or
Jan 07, 2010 | Lexmark X7170 All-In-One InkJet Printer
Error 1203 I'm getting error 1203 on the printer. I have new cartridges in. Fresh paper. Still getting error 1203
1. Press Power to turn your All-In-One off.
2. Unplug your All-In-One from the wall outlet.
3. Plug in your All-In-One.
4. Reinstall the cartridges.
If this does not resolve the problem, replace your cartridges to fix the problem.
Nov 26, 2009 | Lexmark X7170 All-In-One InkJet Printer
On my printer it is saying cartridge error 1203 and it won't print. Help!
Error 1203 is a cartridge error, please contact the store where you bought it or Lexmark costumer support so they can replace the cartridge.
Good Luck,
GetAFix99
Nov 16, 2009 | Lexmark X7170 All-In-One InkJet Printer
Cartridge error 1203 consult see user guide on display panel
Error 1203 is an issue that occurs either when a cartridge is bad or the printer cartridge Slot is bad... I would request you to try cleaning the copper contacts of the both carts and cart slot in the printer and try again..
Jan 19, 2009 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Error 1203
Ok this some times works.
or
Nov 20, 2008 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Lexmark X7170 All-In-One InkJet Printer Logo
175 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
