Question about Sony Ericsson Z525a Cellular Phone
BLuetooth Failure Hello - I just bought two different bluetooth devices, and my particular phone seems to be dropping the connection with the head set. I took the first back thinking it was the headset, but found after purchasing the second with the same issues that it is probably the phone. My wife has the same phone, so I tried it with hers and it works perfectly. Is there anything that I can do to fit the phone?
  • Anonymous Aug 15, 2008
    Could you repost the link - it got cut off on the right side of the page.
    Thanks
I'm having the same problem as you.  I just tried turning off the phone and head set, restarting them, and then following these instructions exactly:   http://motorola-global-eng.custhelp.com/cgi-bin/motorola_global_eng.cfg/php/enduser/cci/bluetooth_pairing_instrctns.php?p_headset=4224&p_handset=4662&p_cat=744
Seemed to work.  For now...
Posted on Aug 15, 2008
SOURCE:
The bluetooth wont work on anythink
hello there, what is the make and model of your cellular device. Bluetooth permissions change from device to device, often enough only phone calls are allowed to be transmitted to other Bluetooth devices regardless of what type of device it is, if that's the only outgoing Bluetooth service your cell phone allows, this may or may not be the case we cannot even get into particulars because I do not know what type of device that you have also would like to know what did you do to try to connect, did you toggle the Bluetooth setting on, are you sure that the devices that you're attempting to connect to work, are you actually trying to use a service that the device offers? Is the phone new? Have you ever been able to use bluetooth?
Nov 27, 2015 | Cell Phones
Hello...i am using sony ericsson k550 i had a trouble in that i cant send any files through bluetooth my bluetooth is not working pls any one tell how to solve this prob
Make sure your phone and the other Bluetooth device are charged, switched on and within range of each other. Make sure Bluetooth wireless technology is turned on, and that the devices are set to be visible for other Bluetooth devices. Check that the two devices are paired, and have found each other. If there are still problems, you'll have to reset the connection and pair the two devices again.
In some Bluetooth installations, you must activate a COM port manually in your computer. This is done differently for different brands and models of Bluetooth devices. Please see the manufacturer's product documentation.
If a COM port is not activated
1. In many cases, you can right-click on your phone icon in the window where all found Bluetooth devices are shown, and select a 'COM port activation' item in the menu. Make a note of the COM port number of the activated port.
2. Open Sony Ericsson PC Suite and click Tools/Phone Monitor Options.../Com Ports. Enable the COM port you activated in step 1.
3. Keep the Bluetooth wireless technology turned on in your phone, restart the computer and try to connect again.
Feb 08, 2011 | Sony Ericsson K550i Cellular Phone
I RECENTLY PURCHASED SAMSUNG WAVE MOBILE S8500 AND ALSO NOKIA BH 505 BLUETOOTH HEAD SET. WHEN I TRIED TO PAID THE BT HEAD SET WITH THE MOBILE. THE MOBILE PHONE IS NOT RECOGNISING THE BLUETOOTH HEAD...
ya i have bought bh 505 yesterday and i am using samsung wave s8500...i have connected my phone with bh 505....its very easy...while turning on your bluetooth headset you have to press and hold for long time till a blu light appears then you turn on bluetooth in your phone and search...it will recognise and pair the device...thats alll ucan use it now...itss awesome....
Nov 10, 2010 | Samsung Bluetooth?® WEP200 Headset...
Pairing with a motorola bluetooth device
Hello, Barb.
Here are some instructions from the manual:
To set up a Bluetooth connection, do the following:
1. Select Menu > Settings >
Connectivity > Bluetooth.
2. To activate or deactivate the Bluetooth function, select
Bluetooth > On or Off.
Indicates an active Bluetooth connection.
3. To search for compatible Bluetooth audio devices, select
Search for audio enhancements and the device that you want to connect to the phone.
To search for any Bluetooth device in range, select Paired
devices. Select New to list any Bluetooth device in range.
Scroll to a device, and select Pair.
4. Enter the Bluetooth passcode of the device to associate (pair)
the device to your phone. You must only give this passcode when you connect to the device for the first time. Your phone connects to the device, and you can start data transfer.
Hope this helps.
Apr 19, 2010 | Nokia 6085 Cellular Phone
Bluetooth doesn't seem to work on my XoVision XO1945
First you need to check and see if your phone is compatible,Not all bluetooth devices can connect to each other,so check with the GPS documentation.
May 06, 2009 | XO Vision GPS
Get laptop to see ATT V521 bluetooth headset
I think you need to "unpair" the headset from the phone. Try turning off the bluetooth head set, and then deleting the headset from the list bluetooth devices on your cellphone. Then turn the head set back on, and once it discovers that it cannot connect to the cellphone, it will become "discoverable" again.
Jul 25, 2008 | Audio Players & Recorders
Samsung bluetooth handsfree password
  1. ASSURE THAT THE BLUETOOTH IS OFF
  2. PRESS AND HOLD THE MAIN BUTTON ON BLUETOOTH DEVICE UNTIL THE LIGHT ON IT TURNS RED
  3. RELEASE THE BUTTON
  4. SEARCH FOR THE BLUETOOTH DEVICE WITH YOUR PHONE
  5. WHEN PROMTED, ENTER CODE 0000 (4 ZEROS)
  6. COMPLETE
Jun 26, 2008 | Samsung WEP200 Headset
BT160 connect problems
while your in the phones bluetooth manager/program and searching for the device. press the bluetooths buttons to enable the 2 to syncronise. if you press the up/down volume buttons while searching with the phone, it should find it, and syncronise. by pressing different buttons, your giving the phone a chance to detect a bluetooth signal change, and receive the device.
Mike @ compurepair.
Apr 01, 2008 | Jabra COMMUNICATIONS BT160 Bluetooth...
Plantronics explorer 330
I just figured out how to reset the 3XXPlatronics 330. The guest might of of made it a little confusing for some:
1) TURN OFF bluetooth head set by holding the volume control button for about a few seconds until it flashes blue.
2) Make sure your phone's bluetooth is on and on discover mode.
3) Turn on the blue tooth head set (NOTE: HOLD DOWN THE VOLUME BUTTON UNTIL IT FLASHES BLUE AND RED)
4) Lastly, go into your search menu to find new bluetooth devices. The device should show up as "3XXPlantronics" (PASSKEY IS 0000).
P.S. Keep in mind this worked for me, but if it doesn't work feel free to email me at; [email protected]
Mar 15, 2008 | Plantronics Explorer 330 Headset
Sony Ericsson Z525a Cellular Phone Logo
104 people viewed this question
Top Sony Ericsson Cell Phones Experts
Damen Wong
Damen Wong
Ekse
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
