I'm almost done but there are few problems
I have a stack which inputs an infix algorithm, then when I hit ENTER it converts to postfix then checks if it is legal then if it is legal, then the arithmetic operation solves, else the error dialog message box will occur. But it only happens in one digit positive value. I want it also together with negative value, decimal value, exponential value and more than one digit value... Please help me
    Brigadier General:
  • 10,406 Answers
It has been almost 17 months, and nobody has helped you.
By now, you probably have failed the computer-course,
and no longer need any help.
Posted on Dec 03, 2009
Menc problem with my snaps .how i convert in jpg format
Open them with Paint and then click File -> Save As and there is an option "Save as type" ..select JPEG hit "Save" button and the job is done
May 06, 2011 | Computers & Internet
Tip
How to create a bootable USB using Vista or Windows 7
Having a bootable USB is very essential, especially if you are a Netbook user. Using bootable USB to install an operating system (OS) not only makes the installation faster, but also saves a DVD.Creating or using an USB drive to install Windows operating systems is very easy if you follow the below mentioned steps.
Here we assume that you are using either Vista or Windows 7 to create a bootable USB.
1. Insert your USB (4GB+ preferable) stick to the system and backup all the data from the USB as we are going to format the USB to make it as bootable.
2. Open elevated Command Prompt. To do this, type in CMD in Start menu search field and hit Ctrl + Shift + Enter. Alternatively, navigate to Start > All programs >Accessories > right click on Command Prompt and select run as administrator.
3. When the Command Prompt opens, enter the following command:DISKPART and hit enter.LIST DISK and hit enter.Once you enter the LIST DISK command, it will show the disk number of your USB drive.
4. In this step you need to enter all the below commands one by one and hit enter. As these commands are self explanatory, you can easily guess what these commands do.
SELECT DISK 1 (Replace DISK 1 with your disk number), CLEAN, CREATE PARTITION PRIMARY,SELECT PARTITION 1ACTIVE,FORMAT FS=NTFS(Format process may take few seconds),ASSIGN,EXIT.
Don't close the command prompt as we need to execute one more command at the next step. Just minimize it.
5. Insert your Windows DVD in the optical drive and note down the drive letter of the optical drive and USB media. Here I use "D" as my optical (DVD) drive letter and "H" as my USB drive letter.
6. Go back to command prompt and execute the following commands:
D:CD BOOT and hit enter. Where "D" is your DVD drive letter.CD BOOT and hit enter to see the below message.BOOTSECT.EXE/NT60 H:(Where "H" is your USB drive letter)
7. Copy Windows DVD contents to USB.You are done with your bootable USB. You can now use this bootable USB as bootable DVD on any computer that comes with USB boot feature (most of the current motherboards support this feature).Note that this bootable USB guide will not work if you are trying to make a bootable USB on XP computer.
on Dec 18, 2010 | Computers & Internet
Computer is very slow and every time i open wepsite it get stack
turn on the computer and keep on pressing the F8 key> select safe mode> login to desktop> go to run and type "temp" (without quotes) then hit enter and delete all the files> go to run and type "%temp%" (without quotes) then hit enter and delete all the files> > go to run and type "msconfig" (without quotes) then hit enter then goto the startup tab and uncheck all the unnecessary items hit ok and do not restart the computer> go to run and type "inetcpl.cpl" (without quotes) then hit enter then goto the advanced tab and click on reset to reset the internet explorer.
Then restart the computer it should work fine now.
Sep 06, 2010 | Computers & Internet
I installed fedora8 linux os after installation gcc compiler is not working(c programs are not working)
Most probably not installed with your OS --check-- see if you have "cpp" or "gcc"
Aug 27, 2010 | fedora Linux Operating System
My Network Places applet keeps disappearing and reappearing
It sounds very much like the operating system file have become corrupt.
Click on the the start menu and click on run. When the run box pops up type cmd and hit enter.
A command line window will pop up, in the window type sfc /scannow (leave a space between the c and / ) and hit enter. The system will now check for corrupt operating system files.
When its done (and this could take some time) check to see if the problem has been resolved. If it's fixed then job done but if not please post back and I'll give you another command to check the the disk itself.
Good luck.
Jan 11, 2010 | Microsoft Windows XP Professional SP2
How can we use the outlook express 6 to check
Open Microsoft Outlook and from the "Tools" menu select "Email Accounts." The email account wizard will pop up.
Choose "Add a new email account" from the list of options and click the "Next" button. Then, select "HTTP" and hit "Next" again. Now you are ready to input information about your Hotmail account.
Select "Hotmail" from the drop down menu at the right. Enter the name that you want to associate with this account in the "Your Name" field. This is the name that appears when you send someone an email from Outlook.
Input your Hotmail email address in the "Email Address" field. Your user name will automatically be filled in when you do this.
Provide the password to your Hotmail account in the "Password" field. Put a check mark in the check box below if you would like for Outlook to remember your password. This will save you from having to enter your password every time you download your Hotmail email with Outlook.
Hit the "Finish" button to complete the setup of your Hotmail account. Now, when you select "Send and Receive" Outlook will synchronize with Outlook. Too see your Hotmail email, select "Inbox in Hotmail" from your list of mail folders.
Jan 03, 2010 | Microsoft Windows XP Professional for PC
How do i input my product key i have recieved a new product key from microsoft how do i put it into my system
Hello and thank you for using Fixya's services.
Go to the start menu, all programs and find activate license (it will be a set of key icons and may be also found near the clock on the bottom toolbar). Open this and hit, activate over phone. Choose, change product key and it will allow you to enter the new key. Once done, click activate.
Hope this helps!
Nov 19, 2009 | Microsoft Windows XP Home Edition
A c prog to convert decimal to hexadecimal number.
Sure, here you go:
int main(void) {
int input;
printf("Enter a decimal number: ");
scanf("%d", &input);
printf ("In hexadecimal, that is: %X\n\n", input);
return 0;
Oct 05, 2008 | Computers & Internet
Java programming
There are 2000 jpeg libraries in Java out there, easily searchable on search engines, sourceforge, maybe versiontracker, and secondly, you're asking for (what should be application-specific -output-; why would you hobble input) crop/resize without hinting at your algorithm? First, get a real programmer....
Java project for college applications? Gee, how about one to take a personality inventory (the INTJ type; only padded out) including areas of interest and make people little public/private spot codes (2D barcodes, like the ones in Japanese magazines) to indicate their type. The camera in a cellphone with J2ME can read the codes, maybe.... The cool part is that they're coupled with either P3P in wikis or java applets that help communicate with that person if you're an type that would otherwise take bothersome human care and preface to communicate.
There are all kinds of little systems you can build to thwart the draggy bits of Alzheimers' etc. with various little expert systems, that come up when you read a science journal (Nature, Science, Dr. Dobb's Journal, JAMA, JVNA....
You could invent something other than big-headed anime characters to add a personal visual reference to GUIs; emobots were cool, but maybe you can have a **** Cheney's Hands IM environment if it doesn't already exist (see also: Galludet University (for deaf students) stuff.)
Mar 20, 2008 | Computers & Internet
Open Questions:
How did I found UsA SuPPoRt{[1-877-778-89-69]} Nortan Antivirus Support Helpline Number? USA 1-877-778-89-69 Nortan Antivirus Support Helpline number is straightforward to use. Nortan Antivirus Support phone number is open twenty four hours daily and seven days per week. Nortan Antivirus support Helpline Number's agent will assist you with remote help.Nortan Antivirus Support Helpline Number 1-877-778-89-69 is one of the most promosing and helpfull number of any Antivirus issue's.We are open 24*7,ready to solve your problem with just a TollFree call:-1-877-778-89-69 .Our expert team finding your issues area and solve the problem in faster and easier way.We are Happy To Help You.We are Nortan Antivirus SupportUSA.Asingle call will change your life.just dial:-1-877-778-89-69. For any question or help:-1877~778~89~69. Norton Antivirus Support Phone Number, Norton Antivirus Customer Service Phone Number, Norton Antivirus Tech Support Phone Number, Nortan Antivirus support Helpline Number, Nortan Customer support Telephone Number.Nortan Helpdesk number,Nortan Tech support Telephone number,Nortan Antivirus Tech Support Number,Nortan Internet Security Customer Number,Nortan Customer Service Technical Support Number. Norton Antivirus Support Phone Number Norton Antivirus Customer Service Phone Number Norton Antivirus Tech Support Phone Number Nortan Antivirus support Helpline Number Nortan Customer support Telephone Number Nortan Helpdesk number Nortan Tech support Telephone number Norton Antivirus Tech Support Number Nortan Internet Security Customer Support Number Nortan Customer Service Technical Support Number. Norton Antivirus Support Phone Number Norton Antivirus Customer Service Phone Number Norton Antivirus Tech Support Phone Number Nortan Antivirus support Helpline Number Nortan Customer support Telephone Number Nortan Helpdesk number Nortan Tech support Telephone number Norton Antivirus Tech Support Number Nortan Internet Security Customer Support Number Nortan Customer Service Technical Support Number. Norton Antivirus Support Phone Number Norton Antivirus Customer Service Phone Number Norton Antivirus Tech Support Phone Number Nortan Antivirus support Helpline Number Nortan Customer support Telephone Number Nortan Helpdesk number Nortan Tech support Telephone number Norton Antivirus Tech Support Number Nortan Internet Security Customer Support Number Nortan Customer Service Technical Support Number. Norton Antivirus Support Phone Number Norton Antivirus Customer Service Phone Number Norton Antivirus Tech Support Phone Number Nortan Antivirus support Helpline Number Nortan Customer support Telephone Number Nortan Helpdesk number Nortan Tech support Telephone number Norton Antivirus Tech Support Number Nortan Internet Security Customer Support Number Nortan Customer Service Technical Support Number.
Jan 23, 2017 | Norton Computers & Internet
Computers & Internet Logo
26 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
