Question about Dryers
Air vent i need to fix a air vent to the outside for my tumble dryer going through a double cavity wall.once hole is made do i need a vent kit or can i just place my hose through the hole to the outside vent,or by doing this will it make my cavity wall insulation damp
  • 706 Answers
Many home improvement stores such as Home Depot , Lowes etc carry Vent kits. I would encourage you to pick up one of these and install it through your outside wall. Normally, the outside portion of the vent has a flapper to keep outside air and critters from coming into your house when that vent is not in use and also has a short section of ( typically) 4 inch vent line that projects through the wall cavity and into the living space. Most flex lines should be atteched to that. If you are usintg a gas dryer, it is strongly encouraged and may be code requirements in some areas to use only solid ducting to the outside. Electric Dryers do not have the same exhaust gases and can be ducted with a plastic flex line. Hope that helps...
Posted on Aug 12, 2008
SOURCE:
Do I need a kit or adapter to have the exhaust go to the outside instead of back inside?
Yes, they are sold at home improvement stores and consist of a hose and a vent. They require a hole be cut in the wall for the vent tube to exhaust outside.
Jul 04, 2017 | Dryers
Hoover Dryer Model D6792A. Trying to find a user manual or find out how to use the rear vent once its panel is removed
If I remember correctly, there is a venting kit that you purchase which consists of a fitting to go on the back of the dryer and a large diameter hose which you put out the window or door to vent the hot air from the dryer. There used to be another kit which allowed you to connect to a wall outlet which vents directly outside.
Apr 09, 2015 | Dryers
Our GE Profile DPSB613ED2WW dryer has been losing drying efficiency for the past few months. It now takes three cycles to completely dry a load. The dryer is heating (although we assume not correctly) and...
How is the vent discharge air flow out the back of dryer? If not very strong check out lint trap cavity for blockage or obstuction causing lint to build up, blocking air flow from drum cavity. Once found a pocket comb that had got into lint trap housing and created a lint dam blocking air flow.
Feb 14, 2011 | GE Dryers
The gas dryer will light but after a couple minutes goes off, it will tumble for awhile and then ignite again. I have replaced the thermal fuse and thermostat
your vent is plugged or the dryer is too close to the wall put unit on air only and go outside check for air if none come back indoors and gently pull the dryer away from the wall then go back outside to recheck air flow should have improve if not the lint screen housing is plugged
Aug 20, 2009 | Dryers
Creda dryer thermostat failed
you have an air flow problem
Aug 17, 2009 | Dryers
Still drys but not as fast as it once did
Hello.
You have one of two problems with your unit.
1. The vent hose is kinked behind the unit and restricting air flow from the dryer.
2. The vent going outside is clogged somewhere between the wall and the outside.
Once you fix either of these two problems the dryer will work good again.
Jul 14, 2009 | Dryers
Change the venting from internal to external?
Hello staufferbi,
It is possible to redirect the vent to the outsied but it is not a simple task. First off, you will need to remove the micro from the wall cavity and reposition the blower so that it vents out the top and not the front, then cut a hole in the cabinet above the micro ( lined up to accept the rectangular duct ) These tasks require fairly good carpenmtry skills and may not be suitable for the novice.. In any event, if you do attempt this.. then once you have the duct vented through the cabinet from the top of the microm you will need to attach that to wall vent feedthru. This normally means converting the rectangular duct to 4inch round and using an elbow. Needless to say, it can be done but is fairly involved. I did not mention anything about getting a 4 inch hole thru the outside wall and not thru a wall stud.,. Outside walls are typically bearing walls and although your roof won't cave in if you cut a hole thru a stud, it isn't advisable. Then you have to make sure it is sealed thru the wall cavity and properly cut into your siding. As I said before..it can be done but don't think it is a little job..
Good luck
Rick
Jan 09, 2009 | Microwave Ovens
How do you fit a dryer vent that has to go through the wall?
Unfortunatly you'll need to either knock, hammer and chisel, or drill, using a core drill, which you can hire from a tool hire shop, a hole through the wall. Then connect up the dryer hose to a vent kit which will fit in the hole in the wall.
You can buy the vent kits from most DIY shops and electrical shops (they don't cost much). This is the best way.
Alternatetivly you can buy a special filter box that the dryer hose fits into. This is best if the dryer isn't next to an outside wall. Again most DIY shops and electrical shops sell these.
Good Luck!
Nov 28, 2008 | Dryers
Venting a dryer outside
What do you need to reverse?
I understand that the wall kit is to blow the heated air from the dryer to outside therefore not humidifying the laundry.
Are you trying to draw air into the dryer from outside or blow the air outside?
Sep 14, 2008 | Fisher and Paykel DE06 Electric Dryer
DRYER WILL NOT GET CLOTHS DRY
A dryer needs only three things to dry clothes:
1. Tumble the clothes.
2. Blow the air.
3. Heat the air.
If your clothes aren't drying, you are missing one or more of these.
You've mentioned that the basket is tumbling. That's good. The blower is also running if the motor is turning. But that doesn't mean the air is blowing. It could be clogged up behind the lint screen, in the vent pipe behind the machine, or at the vent outside the house.
If it's blowing lots of cold air (go to the outside vent to find out) then your dryer isn't heating. This would mean some part inside the dryer has failed. If so, the first thing you want to determine is, does the ignitor glow? There's a hole at the very bottom front edge where you might see it glow. You may have to place a mirror in front of the hole to see it glow.
Write back with more symptoms, and I'll help you through the rest.
Mar 23, 2008 | Dryers
Dryers Logo
81 people viewed this question
Top Dryers Experts
Marvin
Marvin
paul
paul
