Question about Cameras
Pictures wont down load
Trying to down load 138 pictures only one pic will down load
  • pallysjr Aug 12, 2008
    thanks any way I'm still cant down load anything. Its like the camara is telling the pc nuthing is on the memory card but the pictures are there..I'll keek looking around thanks for the help..pally
    Genius:
  • 2,985 Answers
If the camera software is loaded and you are connecting the camera to computer.
Remove the softwaree and.
Windows will see the camers as a removable memory device in my computer an put up the scanner camera wizard.
This may reveal more.
You may also have inadvertantly deleted stuff
download www.pcinspector.com
install it to recover any deleted images.
Also try the camera and card in another computer.
Posted on Aug 12, 2008
  • john ash
    john ash Aug 12, 2008
    If you have a digital processing ation near you wehy not take the card in and get them to make a CD.
    Then you will know if you have images or not.
SOURCE:
Can you send us a picture of the kawasaki zx750 carb
Now that that\'s out, this page is all about jetting a motorcycle. I will only apply one set of jets and make one series of adjustments. The motorcycle that this paper demonstrates is a California model 2002 Kawasaki zx-7r. The "Jet Kit" applied is by Factory Pro. For the series of pages I will cover California emissions removal, Adjusting the carburetor float height and a modifcation known as "The float bowl mod" as gleaned from the vast resource known as the zx7r Owners Club Discussion Forum, Perhaps the greatest motorcycle resource known to man.
Step 1 - Preparation
Airbox
Remove the gas tank and air filter until you are looking at the bottom of the airbox.(Upper Right) Clean out the inside of the airbox while you are in here, there\'s no time like the present. Disconnect the the PCV hose from the bottom of the airbox. (Upper Left)Turn out the three screws and remove the airbox (Lower Right).
Put all the screws in a box and get them out of the way! You won\'t be seeing them for a few hours so the further the better. (Lower Left)
Step 2 : Smog
Smog
Removing the California Emissions from your streetbike is *******. For race applications tho, it\'s all good. The California emissions is a bit more complicated than the 49 states setup(upper left), but you might notice that they have only added an evap system to it (Upper Right). Other than that I can\'t tell a difference. What we will be removing is everything emmisions, short the PCV hose that is mentioned above. When everything has been removed join the two reed plate hoses at the top. You can also buy a block off plate from Muzzy\'s or some other race manufacturer. When you have removed all the smog, you should have a box of junk similar to the one on the right, because I intend to put the smog back on, I will be keeping all the gear.
]Finally, plug off the four vacuum lines that go into the head benieth the carbs: Use 5/32" plugs.
Ken Waters\' Patented "Float Bowl Mod"
This modification is the brainchild of Mr. Ken Waters, who was clearly a brilliant technician who has passed away in an unfortunate accident. I don\'t know much about his passing. Speculation is that the accident was not motorcycle related. Reading thru Ken\'s posts on the Zx7r Owner\'s Club Discussion Forum has helped many motorcycle owners, and myself, understand a load more about how bike tuning is done.
Principle: (As paraphrased from Ken Waters)
In order to get the pressure in the float bowls equal to the pressure in the airbox, racebikes enclose the entire carb assembly in the airbox. As logic, fate would have it we are supplied with little hoses that run into the float bowls of our carbeurators. We are going to exploit these hoses to ballance the preasure throughout the fuel system.
Situational Information:
Now, as if knowing the two hoses that appear to come from the top of the carbs and indeed are attached to the top of the carbs are the ones we are going to use isn\'t confusing enough, I\'m going to tell you that they are connected directly to the float bowls which are at the bottom of the carb assembly. When we pull the carbs off later you will see that the tap is at the top, and the orifice is in the float bowl.
Application:
It\'s real easy. Just connect the two hoses that are discussed above directly to the airbox. There are many opinions about how to do this, I chose to destroy as few parts as possible in an effort to keep as many of the stock parts in tact as possible. I melted one end of a leftover vacuum "T" shut (Upper Right) and connected it to the hose that used to connect the evap cannister and intake silencer to the airbox(Upper Left). Again, trying to keep as many stock pieces stock, I plugged off the other line to the airbox with a screw(Lower Right). I do however, suggest using this other line to connect there, as it can provide a better seal to the airbox. I compensate for this by using a hoseclamp on the one I used.
Note: No matter how you connect it, connect the line where the clean air is, between the air filter and the carbs.
Step 4: Install and Adjust
Finally We Work The Carbs!Disconnect the fuel line where it t\'s off into the carbs.(1) Open the throttle assembly on the handle bars and let the slack out of the throttle cable there. (2) Pull the two throttle cables off the carbs and lift the throttle cables from their pirches. Loosen the four mainfold clamps and remove the carbs by pulling out and up at the same time. (3)
Once they\'re out, turn the carbs upside down on the work bench and remove the sixteen screws that hold the float bowls on (4) and remove the float bowls. Place carb assembly on its side to remove any pressure from the floats and measure the float height with the floats resting lightly on the float pin so as not to push it in at all, but not rise above it either.(5) The floats stock should mesure 13mm. We need to change this to 15.5mm for our Jet Kit. Do so by bending the little tab between the floats and the float pin. (Right)
After you\'ve adjusted the float hieght, remove the main jets and emulsifier tubes and replace them with your choice of factory mains and tubes. I chose the 168 outer / 178 inner (Smaller) combonation because of my altitude.(6)
Remove the four black caps on the top of the carbs. (7) Be careful because they are spring loaded! Remove the needle jets and place shims "as necessary" (Consult with Factory Pro or a tuner in your area about this.) My favorite wrench jockey suggested two shims and so far it seems he was right, response is genuinly smooth all the way through. Replace the stock springs with Factory springs if provided.
To finish of the mods, I added a 4 degree Factory ignition advancer.(8) An easy install that smoothes out throttle response even further.
Oct 21, 2014 | Motorcycles
Can't see icon on computer with camera connected. trying to down load pics. Reloaded program from disc. Still can't see icon
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Canon ZoomBrowser or Picasa.
Dec 10, 2012 | Canon EOS 1100D / Rebel T3 Digital Camera
I am trying to get the pictures I took on my LG VX5500 phone off of my phone and onto my computer. Is there a way to download the pics from my phone to my computer or from the phone's memory to an SD...
Connect the phone with the usb cable or data cable.
And let windows down load the pictures from your phone.
Or select the album where your phone has the pictures
And down load them from there.
Good luck.
Mar 08, 2011 | Computers & Internet
How do you down load pictures
You need to use the supplied Sansa Media Converter program to convert pics (and videos) to a format the Sansa's small screen can handle.
Jun 21, 2010 | SanDisk Sansa Fuze MP3 Player
Purchased new computer trying to load pictures
Just buy a card reader to download your pics...don't worry about the driver.
Feb 18, 2010 | Kodak EasyShare M1033 Digital Camera
Can't load more pics to internal memory,past about 100 photos
Your jpg files(pics) may be too large.
reduce them (i use 800x600.)
Irfanview is a good resize pgm(free)
fred
Dec 11, 2009 | PANDIGITAL (DPF802) Digital Picture Frame
I I am trying to up load pictures PC
Blame Microsoft updates. Try using a card reader to download your pics to a folder you create on your desktop.
Dec 07, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Subwoofer option on my kenwood kdc 138 receiver
go to kenwood wesite to down load instruction manuals
Sep 13, 2009 | Kenwood KDC-138 FM / AM Receiver
Kodak easy share SV 811
I had the same problem. I use kodak easyshare software and load my pics on to that. Then put all the pics you want in the picture tray. Have your frame plugged into the computer with your usb cord. Then go up to File menu and drop down to "copy to". On my computer it is Folder "E" which is the drive the frame is connected to. Then pick from the Resize drop down menu " best for picture frame', then click copy. You will see the program loading all the pics to E drive. When done, unplug usb cord and you will see it loading on your pic frame. As easy as this is to do, I found it frustrating as well, but when it works, it is easy. Hope this helps
Aug 04, 2008 | Kodak EasyShare SV811 (8858946) Digital...
Computer help
i have a vista system on my computer disk for power shot s-30 is not compatiable with vista. how can i down load pics?
Dec 21, 2007 | Canon PowerShot S30 Digital Camera
Cameras Logo
113 people viewed this question
Top Cameras Experts
Marvin
Marvin
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you a Camera Expert? Answer questions, earn points and help others
