My XP computer will not recognize my memorex usb device
  • 876 Answers
What type of device? do you have a driver ( software )installed for this device? If you didn't install software you could go to www.memorex.com and look for downloads/support/drivers and look for the specific driver that you need for your device. turn off all open proggys including security and then download the file to your desktop. Once download is complete, click on this exe file to install your drivers. Then turn your security back on!
If this does not help ou, please let me know. Please send details about your device if you need more help.
what is it?>
Model name and #>
what type of PC>
Operating system
Good Luck and thanks for using Fix YA!
Posted on Aug 12, 2008
SOURCE:
Good day. I have a memorex ultratravel drive USB 2.0 160GB. Everytime I connect to any computer I get the message:The pc does not recognize the USB device code 43. Please let me know what i can do. thanks...
Code 43 is the death code - the pc simply cannot communicate with the attached device because the device is not working. This means that the Memorex is dead . Since the electronics board inside it cannot be repaired or replaced it means that yo must buy a new one.
Apr 09, 2011 | Memorex Ultra Traveldrive - 160GB USB Hard...
The drive is not recognized by Windows or Mac
You should give Test Disk a try. It's a little complicated at first but if you read the tutorial it's easy.
Here's a link to their wiki page.
Nov 24, 2009 | Memorex Mega Travel Drive HDD 12GB 12 GB...
I have a brand new 1 gb memorex travel drive that I'm suppoed to go to memorex.com to download the drivers. It's not available onlnioe anymore and memorex is tying to send it to me via email but the file...
Windows XP and Windows Vista and Windows 7 should have "built-in" support for this Memorex device. Just connect it to a USB-port, and see if it is recognized -- it should be!
Nov 09, 2009 | Computers & Internet
Some pc's don't recognize my travel drive
I have a USB hard drive, and I have noticed that on some systems the current Draw on the USB port is too high for systems with unpowered / Low power USB ports, and therefore it doesn't work for that system,
this issue can be bypassed by using a "powered" USB hub
Mar 24, 2009 | Memorex Ultra Traveldrive - 160GB USB Hard...
Device is detected, but I can't add music, because it undetects
Problem Solved: My MMP8567 screen read ''boot error shutting down''.
Everytime I plugged it in to the computer the computer would find it but then it would disappear almost immediately.
I downloaded the Updater program from Memorex but it couldn't find the player.
The directions from Memorex said ''Hold down the play button and plug in usb cable.'' Another set of Memorex directions said, ''Hold down the power button and plug in usb cable.'' Neither worked for me.
SOLUTION: I finally held down the LOCK/UNLOCK button and plugged in the usb cable. My computer found the player immediately and a software driver window popped up asking for a driver. I let windows search the internet and it found and installed the driver. The driver it was looking for was: ''player recover device class driver'' After windows confirmed it recognized my mp3 player I started up the Firmware update program and was able to update the player.
I tried to be clear and detailed. Good Luck ;-)
Jan 31, 2009 | Memorex MMP8567 MP3 Player
I plugged my Memorex TravelDrive into my computer. It has always worked perfectly. This time I got the message that the USB device was not recognized and I can't get into my files.
THE FOLLOWING IS COURTESY OF MICROSOFT Help and Support
When you plug a USB device into a Windows XP-based computer immediately after the computer comes out of standby (S3) or hibernate (S4), the computer may not recognize the USB device. When this issue occurs, the USB device may be listed in Device Manager as an unknown device, and you may receive the following warning message:
Unrecognized device has been found.
This issue occurs because, when the computer comes out of S3 or S4, there is a five- to ten-second period when the selective suspend feature of the USB driver will interfere with detection of a new USB device connection. The time period depends on several factors. This includes the following factors:• Host controller hardware
• Attached hubs
• Attached devices
• USB driver versions
• Support for USB 2.0
• Additional system hardware or configurations that may change the timing
There may be other reasons that a USB device is not detected
Method 1
loadTOCNode(2, 'workaround'); After the computer comes out of S3 or S4, wait five to ten seconds before you plug the USB device into the computer or hub.
Method 2
After the computer comes out of S3 or S4, unplug the USB device, and then plug the device back into the computer or hub.
Method 3
Use the Device Manager to scan for new hardware. Follow these steps: 1. Click Start, click Run, type Devmgmt.msc, and then click OK..
2. On the Action menu, click Scan for hardware changes. This causes Windows to recognize new devices.
3. Close Device Manager and Control Panel.
Method 4
Disable power management of the USB hub.
Note If you perform the following procedure, you may also reduce the battery life on a portable computer.
To disable power management on the USB hub, follow these steps: 1. Click Start, click Run, type devmgmt.msc, and then click OK.
2. Expand the Universal Serial Bus controllers node, and then follow these steps for each USB Root Hub that is listed: a. Right-click the USB Root Hub, and then click Properties.
b. Click the Power Management tab.
c. Click to clear the Allow the computer to turn off this device to save power check box, and then click OK.
SIMILAR PROBLEMS AND SOLUTIONS loadTOCNode(1, 'moreinformation'); For more information about advanced troubleshooting tips for general USB problems, click the following article number to view the article in the Microsoft Knowledge Base: 310575 (http://support.microsoft.com/kb/310575/) Advanced troubleshooting tips for general USB problems in Windows XP For more information about how to troubleshoot unknown devices in Windows XP, click the following article number to view the article in the Microsoft Knowledge Base: 314464 (http://support.microsoft.com/kb/314464/) How to troubleshoot unknown devices that are listed in Device Manager in Windows XP
Try restarting the computer with the device in. Sometimes if you clear the memory that might help (stating the machine without memory then put it back and start it again).
Jul 01, 2008 | Computers & Internet
USB Device Not Recognized
ok i dont know if you have had a solution yet but if you have the operating system Windows XP you dont need the software, just plug your USB plug up to your computer and MP3 and it should install the drivers
Mar 29, 2007 | Memorex MMP3642 MP3 Player
Open Questions:
OUTLOOK tech support phone {&$&{[email protected]*1O69} NuMbEr USA AsIf This OUTLOOK USA phone number +1:8OO:,:8O31069 is ranked #2 out of 2 because 7,728 OUTLOOK USA techs tried our tools and information and gave us feedback after they called. The reason techs call # I:8OO:,:8O31069 is to reach the OUTLOOK USA tech Support department for problems like Where to buy, Complaint, tech support, Repairs, Returns. As far as we can tell, OUTLOOK USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. OUTLOOK USA has 2 phone numbers and 4 different ways to get tech help. We've compiled information about I8OO8O31O69 and ways to call or contact OUTLOOK USA with help from techs like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling OUTLOOK USA Calling OUTLOOK USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from OUTLOOK USA tech Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with OUTLOOK USA's tech Support department, you may need to provide them with information that identifies you as a tech, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare OUTLOOK USA's phone numbers against each other. Contacting OUTLOOK USA in General While I8OO8O31O69 is OUTLOOK USA's #2 most popular phone number, it's not the only way to get a hold of their tech care team. You already know from reading above that I8OO8O31O69 is their best tech phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach OUTLOOK USA help by calling them, is that other techs give their tech support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact OUTLOOK USA.
Oct 17, 2019 | Best Computers & Internet
HOTMAIL tech support phone {&$&{[email protected]*1O69} NuMbEr USA AsIf This HOTMAIL USA phone number +1:8OO:,:8O31069 is ranked #2 out of 2 because 7,728 HOTMAIL USA techs tried our tools and information and gave us feedback after they called. The reason techs call # I:8OO:,:8O31069 is to reach the HOTMAIL USA tech Support department for problems like Where to buy, Complaint, tech support, Repairs, Returns. As far as we can tell, HOTMAIL USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. HOTMAIL USA has 2 phone numbers and 4 different ways to get tech help. We've compiled information about I8OO8O31O69 and ways to call or contact HOTMAIL USA with help from techs like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling HOTMAIL USA Calling HOTMAIL USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from HOTMAIL USA tech Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with HOTMAIL USA's tech Support department, you may need to provide them with information that identifies you as a tech, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare HOTMAIL USA's phone numbers against each other. Contacting HOTMAIL USA in General While I8OO8O31O69 is HOTMAIL USA's #2 most popular phone number, it's not the only way to get a hold of their tech care team. You already know from reading above that I8OO8O31O69 is their best tech phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach HOTMAIL USA help by calling them, is that other techs give their tech support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact HOTMAIL USA.
AOL GOLD tech support phone {&$&{[email protected]*1O69} NuMbEr USA AsIf This AOL GOLD USA phone number +1:8OO:,:8O31069 is ranked #2 out of 2 because 7,728 AOL GOLD USA techs tried our tools and information and gave us feedback after they called. The reason techs call # I:8OO:,:8O31069 is to reach the AOL GOLD USA tech Support department for problems like Where to buy, Complaint, tech support, Repairs, Returns. As far as we can tell, AOL GOLD USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. AOL GOLD USA has 2 phone numbers and 4 different ways to get tech help. We've compiled information about I8OO8O31O69 and ways to call or contact AOL GOLD USA with help from techs like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling AOL GOLD USA Calling AOL GOLD USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from AOL GOLD USA tech Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with AOL GOLD USA's tech Support department, you may need to provide them with information that identifies you as a tech, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare AOL GOLD USA's phone numbers against each other. Contacting AOL GOLD USA in General While I8OO8O31O69 is AOL GOLD USA's #2 most popular phone number, it's not the only way to get a hold of their tech care team. You already know from reading above that I8OO8O31O69 is their best tech phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach AOL GOLD USA help by calling them, is that other techs give their tech support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact AOL GOLD USA.
Oct 17, 2019 | AOL Computers & Internet
AOL DESKTOP GOLD tech support phone {&$&{[email protected]*1O69} NuMbEr USA AsIf This AOL DESKTOP GOLD USA phone number +1:8OO:,:8O31069 is ranked #2 out of 2 because 7,728 AOL DESKTOP GOLD USA techs tried our tools and information and gave us feedback after they called. The reason techs call # I:8OO:,:8O31069 is to reach the AOL DESKTOP GOLD USA tech Support department for problems like Where to buy, Complaint, tech support, Repairs, Returns. As far as we can tell, AOL DESKTOP GOLD USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. AOL DESKTOP GOLD USA has 2 phone numbers and 4 different ways to get tech help. We've compiled information about I8OO8O31O69 and ways to call or contact AOL DESKTOP GOLD USA with help from techs like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling AOL DESKTOP GOLD USA Calling AOL DESKTOP GOLD USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from AOL DESKTOP GOLD USA tech Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with AOL DESKTOP GOLD USA's tech Support department, you may need to provide them with information that identifies you as a tech, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare AOL DESKTOP GOLD USA's phone numbers against each other. Contacting AOL DESKTOP GOLD USA in General While I8OO8O31O69 is AOL DESKTOP GOLD USA's #2 most popular phone number, it's not the only way to get a hold of their tech care team. You already know from reading above that I8OO8O31O69 is their best tech phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach AOL DESKTOP GOLD USA help by calling them, is that other techs give their tech support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact AOL DESKTOP GOLD USA.
Computers & Internet Logo
27 people viewed this question
Ekse
Alun Cox
