Question about Konica Minolta DiMAGE Z6 Digital Camera
Konika minolta dimade z6
I get no view. The screen is either black or white. sometimes after fiddling the picture comes back and I can take it. But the next time it will be white or black again.
There was no shock, no fall, this happened when using the menu.
Can this be solved by down loading a firmware?
  • pitoche Aug 12, 2008
    I don't think there is any firmware available, I don't feel I can open the camera to check a cable
    Jakboy advised me to press the bottom of case to try resetting the cable myself
    so far I get a picture now, I'll see how long this lasts;
    Thank you
  • Konica Minolta Master
  • 19,396 Answers
Well you first try removing batteries from camera and putting them back in place, then you try updating firmware, as this are few operations user can do.
Most likely it looks like a faulty LCD or LCD ribbon out of place, this can happen even when there is no evident shock, both problems can be fixed by a technician at a repair shop.
Posted on Aug 12, 2008
  • Ginko
    Ginko Aug 12, 2008
    I do not think it is a firmware problem by the way, try removing batteries, to see if hard reset helps. Probably it is faulty LCD or ribbon cable out of connector. Ask a quote to a local camera repair shop or call the number printed on last pages of your manual and send camera in for repair.
    If camera is under guaranty, definitively call customer service number.
    Genius:
  • 1,847 Answers
Before check the firmware reset the camera by going into menu > settings.
  • Legin Varghese
    Legin Varghese Aug 12, 2008
    if still no go the the cable connecting the screen will be loose you have to open the camera to check.
Konika minolta dimage Z6
Hello
Thank you for using FixYa for your problem
Always check the batteries first but if is it still giving the same fault, your camera is faulty.
It should be taken to an authorized repair centre for a repair estimate. Very few digital cameras have any user-serviceable parts.
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
Dec 02, 2009 | Konica Minolta DiMAGE Z6 Digital Camera
Konika minolta dimage z6
This seems to be a loose connection if the screen ribbon cable.
Gentle squeezing of the lower part of the case may get it to sit aright
Aug 12, 2008 | Konica Minolta DiMAGE Z6 Digital Camera
Konica Minolta Dimage Damage
I had the same problem with mine, a minor fall cracked this, I disassembled the unit and one of the springs that hold the main sensor was broken, thus the sensor vibrates instead of "floating" when the camera is turned on. There are two possible solutions: The first is to get a faulty Z6 from eBay and get the parts (the main sensor assembly) and have it replaced. (If you are not comfortable working with 1mm screws, you'd better go with the parts to a camera repair shop and explain them the problem. The second solution is un-elegant but useful: If you disconnect the anti-shake circuit from the main board you won't have the annoying vibration at start, and the focus will work properly. I've done this and I am happy with the result (I rarely used the anti-shake feature, so I don't miss it). For reference, the anti-shake circuit ribbon is the one entering the mainboard just under the left side of the screen.
Ejoy.....
PS. if you have dark spots, chech that the sensor assembly is not too out of place or that a piece of the broken assembly is on the way. Realign it in place (and please don't touch it). and asseble tha camera back
Apr 05, 2008 | Konica Minolta DiMAGE Z6 Digital Camera
My minolta dimage X20 whern turned on is all ready to take a picture but is only showin blackness, i can preview pictures etc and do every thing else My Minolta DiMAGE X20 is doing the same thing and has...
thats called "vigneting" and is caused by misalignment of the lens.... has it been dropped or mishandled? if so, it needs re calibrating and setting up by a pro camera technician.
Mar 04, 2008 | Konica Minolta DiMAGE Z6 Digital Camera
Screen white
if you are changing the lever to different positions...the green/edit, red viewfinder, or the red lcd view and get nothing...chances are your camera has the same problem mine does. The lever is broken and is not engaging the mechanism internally to change the views or power the lens to fully extend.
you won't be able to take pictures like me. I don't know if there is a fix or not. I guess the camera is prone to these problems as there are a few similar to what u describe with yours.
Dec 28, 2007 | Konica Minolta DiMAGE Z6 Digital Camera
View is Black & White "Negative"
There is a Black Dail by the Eyepiece, try unjusting that, and should do you.
Happy Holidays
Bobby
Dec 08, 2007 | Konica Minolta DiMAGE Z10 Digital Camera
Camera shakes when turned on and when taking a picture there is a black area in upper left corner
This soundfs like a Zoom lens element problem May be expensive to get fixed Check out customer support
Jul 31, 2007 | Konica Minolta DiMAGE Z6 Digital Camera
Blurry Pictures
Contact Customer Support this is possibly a CCD problem- they may still fix it.
May 29, 2007 | Konica Minolta DiMAGE Z6 Digital Camera
Konica Minolta DiMAGE Z6 Digital Camera Logo
Top Konica Minolta Cameras Experts
Greg Cann
Greg Cann
Willem.
Willem.
Are you a Konica Minolta Camera Expert? Answer questions, earn points and help others
